Question about GE Profile WPSR3120WWW
GE Washer Spin Cycle Problem
My GE WPSQ4160T washer has gone through 2 clutches in the last year. It works fine in all modes except the spin cycle where it sometimes will not spin the tub with medium to large loads. The washer is NOT being overloaded. The motor is coming on but the clutch is slipping in the spin mode and gets very hot. The belt has also been replaced. Any help appreciated.
  • 3 more comments
  • Bruce Raymond Oct 30, 2006
    Catriver, Thanks for the feedback. The motor seems to be working fine as far as I can tell. The wash cycles work fine. When the spin cycle starts, the motor engages the clutch, but will not turn the drum do to the load. When I first replaced the clutch, it worked fine for about 2 weeks, then began slipping again. Does this sound like the motor? What is this update kit you mentioned?
    Thanks,
    Gnarley
  • Bruce Raymond Nov 01, 2006
    I finally solved this problem. It had nothing to do with the motor. The brake mechanism below the transmission was causing friction when the spin cycle started and was causing the clutch to slip. This was caused by a leaking tub seal earlier which apparently dripped on the brake. I sprayed the brake with ACF-50 anti corrosion spray and all is well. - Gnarley
  • Anonymous Dec 14, 2007
    Where exactly did you apply the spray to the brake?
  • daveyboy43 Feb 11, 2008
    This is the exact problem I have and I have replaced the belt,motor and clutch.
    I'd like to know what exactly was the spray lubricant that was used,where I can buy it and exactly where it needs to be sprayed. Please reply back asap.
  • Anonymous Aug 10, 2008
    My washer will not spin. At the end of the wash cycle it makes a clicking sound and still tries to agitate buy will not go into the spin cycle.
I have a GE washer and my problem is that do the washing just fine. but when it goes for the rinsing won't take water. I have to pur water manually with a hose so it can go then to the spinning..
Posted on Nov 04, 2009
    President:
  • 878 Answers
Gnarly, do you have the updated motor, harness and start cap? If it goes into spin and does this chunk a chunka chunka bit. Take a meter to the white and white/red wire going to the motor. If you have a steady 120V, replace the motor with the new kit. What the motor is doing is jogging between high to low speed. Catriver..post back.
Posted on Oct 18, 2006
My GE Top load washer. Is making a chunka chunka and or a loud clack, clack noise and is not spining or agetating very well. All the lights in my house are flickering during this time. What's the fix and will it break the bank?
Posted on Nov 08, 2009
Gnarley, did you try what was suggested about the updated motor. I am having the same issue, but am wondering how you tested your clutch for overheating vs. the obvious; touch.
Posted on Oct 28, 2006
The machine is not spin after wash, motor pump is work, and for wash is turn one shot left and one shot right and stop,...where is the problem???
Reasons Why Your Washing Machine Won't Spin
losangeleswasherdryerrepairservice.com > News
Apr 16, 2012 - When the washer enters the spin cycle but does not start to spin, you will need to see if there is ... West Los Angeles Washer and Dryer Repair Service ....After the water has drained, the spin cycle will start. .... Drive Motor, GE, Maytagwashing machine won't spin, spin bearing, washing machine clutch worn ...
Spin Cycle Not Working on Washer ' ThriftyFun
www.thriftyfun.com/Spin-Cycle-Not-Working-on-Washer-1.html
My washing machine will wash but the spin cycle will not spin or drain the tub what do I do to repair that? By Shelly H. ... Question: Washer Stops After It Fills for Rinse Cycle and Does Not Spin. By henryj ... Our GE washer will not spin when it has a load of clothes. It washes .... I have a Frigidaire stackable washer and dryer.
How to fix a washer that will NOT spin ONLY. THE EASY ...
? 3:56
https://www.youtube.com/watch?v=_8myOfPzGfM
Aug 4, 2012 - Uploaded by Brad Hyman
My washer did not spin but the belt drive worked to agitate the ...How to Fix a Washing Machine That Does Not Spin (Fast and Easy) - Duration: 8:45. ... Washer Top Load Not Spinning - Repair & Diagnostic- GE, General ...Missing: dryers
Feb 09, 2016 | GE Dryers
Washer will not spin in wash cycle
I have a Kenmore washer that will not spin or drain.
May 31, 2010 | GE WBSR3140DW Top Load Washer
Chugging like noise during certain cycles
your clutch need to be replaced as does the tub shaft bearings i;m sorry this is not a do-it-yourself job, try to make a deal to trade in your washer
Apr 22, 2009 | GE Washing Machines
Washer won't spin
Check the washer motor. Make sure that the motor is getting correct voltage and is working and spinning when you turn it on. It sounds like the motor is bad. You can remove the back cover to get to the motor to check it out
Feb 13, 2009 | GE Spacemaker Washer and Dryer Electric...
Makes horrible noise during spin cycle only
The bearings have most likely gone bad. This is a very common problem with the front load washer when powder soap is used.
Jan 28, 2009 | GE WBVH6240F Front Load Washer
GE WASHER WJRR4170G0WW-SPIN Cycle does not work- just make sound.
My washer is 2 years old and this is 1/2 the cost I paid for it new. My review of this product after 35 years of technical experience; GE products (Hotpoint)aren't worth buying any longer.
The problem is the Motor. There is an electronic PC Board attached to the top of the motor and under the drip protector, which protects the PC Board. On this board, there is a green flashing light which displays trouble codes by flashing. Unplug the washer, remove the 3 screws from behind the control panel. Slowly pull the control panel toward you and slide it to the right to release. Inside the washer, there is a diagram with the trouble codes printed in the lower right hand corner. Everything else is self explained. Flashes indicate the problem and the solution is all written. Since I have the same problem and a technician, this is a defective product GE has discontinued and re-manufactured. After phoning GE the motor # Normal 0 WH20X10051 cost $252.25 to ship to my location.
Jan 09, 2009 | Washing Machines
GE model WCVH6800JMS front load washer spin cycle
My washer is 1 1/2 years old and I have the same problem.
Nov 11, 2008 | GE WBVH6240F Front Load Washer
Won't spin
yes !! carefully with a flat screwdriver open the front panel, its snaps , hope it helps AJ
Jun 09, 2008 | GE WBSE2090A Top Load Washer
Kenmore 80 series washer not spinning
you need the gear box not the timer.
Dec 20, 2007 | Washing Machines
GE Washer WPSQ4160T
TRY REMOVING FRONT OF WASHER YOU WILL SEE 4 SHOCK LIKE PISTONS TAY GET DRY AND MAKE GRINDING NOISE OR SQUEEKS LUBERCATE ALL REAR HARD TO GET AT MAKE SURE YOU GET TOP AND BOTTOM (RAY)
Dec 07, 2006 | GE WBSE2090A Top Load Washer
Washing Machines Logo
8,996 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
