Question about Canon F-502 Calculator
Reset? I wonder how I can reset the calculator without having to open and take the batteries out? Or how I can change the setting that does that the calculator round off by it self to 2 decimals?
  • Miss_Lavoie Nov 05, 2007
    My freaking calculator rounds off all the decimals! for exemple Pi is not 3.1416... it's 3! What can I do! Is it possible to reset my calculator or find a way to make it right? Please help me as quickly as possible!
  • ijuh Dec 10, 2007
    i need my calculator to round off to two decinal places
  • 3 Answers
Okay, I did what the best solution did and worked with it.
"1. press 2nd F (left top corner)
2. ENG/FIX (the button next to 2nd F)
3. press 0 (if you don't want calculator to round off any decimals)"
In order to get your exact value of pi, in step #3, instead of 0, press the decimal [ . ]
This should give you no decimals when entering a number and give you 3.141592654... when you input pi.
Hope that works/helps.
Posted on Nov 09, 2007
Posted on Oct 25, 2007
Hello , I seem to have a problem with my casio fx~9750GII module calculator. When I turn on my calculator , it stays frozen on the MAIN MENU set i.e consisting of RUN-MAT,STAT,GRAPH,DYNA,TABLE,RECUR,CONICS...
Checking the batteries is the first thing one should try. It is possible that for some reason the screen may be too dim.
Reset the calculator by pressing the button on the back. The screen should show the menus. To adjust the contrast you must press the E key (no need to press the ALPHA key for that.) then press F1 to access the contrast setting feature. Press the Right pointing arrow to increase the contrast.
Aug 14, 2013 | Casio FX-9750GPlus Calculator
Ti 83 will not power on replaced all batteries
When you clear memory, the contrast sometimes changes. If the screen
is faded or blank, adjust the contrast by pressing 2nd and up- arrow or down- arrow keys .
Resetting RAM restores RAM system variables to factory settings and
deletes all nonsystem variables and all programs. Resetting defaults
restores all system variables to default settings without deleting variables and programs in RAM. Resetting RAM or resetting defaults does not
affect variables and applications in user data archive.
Tip: Before you reset all RAM memory, consider restoring sufficient available
memory by deleting only selected data.
To reset all RAM memory or RAM defaults on the TI-83 Plus, follow these
steps.
1. From the RAM ARCHIVE ALL menu, select 1:ALL RAM to display the
RESET RAM menu or 2:Defaults to display the RESET DEFAULTS menu.
2. If you are resetting RAM, read the message below the RESET RAM
menu.
• To cancel the reset and return to the home screen, press .
• To erase RAM memory or reset defaults, select 2:Reset.
Depending on your choice, the message RAM cleared or Defaults
set is displayed on the home screen.
Mar 25, 2012 | Texas Instruments TI-83 Plus Calculator
Battery low message even though I changed three different sets of batteries.
Try to reset your calculator.
Press 2nd and then MEM it's right above the enter key on bottom right. Look for reset. Should fix your problem.
Jun 09, 2011 | Texas Instruments TI-83 Plus Calculator
My HP35s keeps flashing MEMORY CLEAR. I removed the batteries and reset it with a paper clip. Nothing works.
I'm not sure if it is the only solution, but I had the same problem and I replaced the batteries. My HP35S works fine now.
Previously, however, there was no "battery" annuciator on the screen. This calculator went four years without a bettery change. My HP48GII, on the other hand won't go two months without a change. Go figure.
May 11, 2011 | HP 35s Scientific Calculator
I've Tried Everything i put in new batteries, i reset it and i was wondering what else could i try to get it to turn on
Having gone over four months without a response, I assume my suggestion to adjust the screen contrast solved the problem.
Nov 05, 2010 | Texas Instruments TI-84 Plus Calculator
I just changed the batteries and the screen is black when i turn it on if its in direct light i can see what i am typing..
I had the same problem as this. This is because when you might have changed the contrast on your calculator when your old batteries were running low and you need to reset the contrast. Here is what you do:
press the orange "2nd" button, then press the "down arrow" button, then the orange "2nd" button, then the "down arrow". do not press the buttons at the same time only one after the other and KEEP GOING. The screen will eventually lighten up and you are all set.
Apr 26, 2010 | Texas Instruments TI-86 Calculator
Upside down display
I have read that to invert the LCD-screen you just flip the polarisation-plate (the plastic film that sits over the LCD display) 180º, that is, upside down.
Did you or someone opened your calculator? He might have reassembled it wrong. Or was it a prank?
If that was not the case, your best change is to reset the calculator and see if it solves your problem.
To manually reset your graphing calculator:
  • Remove all AAA batteries.
  • Remove the back up lithium battery.
  • Leave the unit empty for 5 to 10 minutes.
  • After the 5 to 10 minutes, place all the batteries back into the graphing calculator.
This process should restore the graphing calculator to the factory settings.
Good Luck!
Sep 10, 2009 | Texas Instruments TI-73 Explorer...
Canon F-502 Calculator Logo
1,255 people viewed this question
Clive
Clive
old marine
old marine
