Question about HP DeskJet 6540 InkJet Printer
Arrow light and Power light keep blinking
The green power light and the orange downward arrow light keep blinking.
When I push the orange downward arrow, the cartridge slides to the left,
then back to the right, then stops.
Then the blinking starts again.
How do I fix this?
  • missymiss424 Jan 02, 2009
    The arrow key and power button keep blinking, very frusterating when unsolvable. Wont print
  • 33 Answers
Take out all the cartridges and the papers..
unplugg the power cable from the printer..
manually slide the carriage from left to right and vice versa and roll the rollers in upward direction from the back after opening the back door..
if doesnt slide or roll..press & hold the power button for 60 seconds and then try again..
clean the inner area of the cartridge slot and the copper contacts of the cartridge with a soft lint-free cloth..
close the back door...
dont put the cartridges..
connect the power cable and power on the printer...
Lights will blink..
Insert one cartridge in the respective slot and close the cartridge door and check if any light blinks..
then remove the cartridge and insert another one and check the same thing..
If light blinks..it will mean the respective cartridge is not good and replace it--
Posted on Nov 28, 2008
  • jimatmn Aug 25, 2010
    solved my problem when printing stopped suddenly while printing individual pages, error message was "data error cylic redundancy check"
The light is constantly blinking on arrow pointing downward? No paper jam, also unplugged and still blinking
Give it a piece of paper and hit the blinking arrow. It means it is out of paper and will not function until it completes its task.
Sep 24, 2010 | HP Deskjet D4100 series
Alarm lights keep blinking after I changed my printer ink.
E5 means cartridges error - to fix press the "stop\reset" button for 5-7 seconds and then release it.
You can also try this:
1) With the printer power turned off but connected to a power source, while pressing the Resume/Cancel button, press and hold the Power button.
(DO NOT release the buttons. The Power LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power button.)
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and
Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the Alarm and Power LEDs light
alternately, Alarm in orange and Power in green, starting with Alarm LED.)
4) When the Power LED lights in green, press the Resume/Cancel button the specified number of time(s)according to the function listed in the table below. (Each time the Resume/Cancel button is pressed, the Alarm and
Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm LED.)
4 times----Green (Power)------Waste ink counter resetting
Apr 07, 2010 | Canon PIXMA MP240 All-In-One InkJet...
Cant get the orange arrow button to stop blinking
TRy HOLDING the power button (green) down and pressing the resume button (orange arrow) 10 times. Release both buttons. You may get a self-test print out of the printer after which, the resume button should be off.
I just tried this on my printer and it worked. I do not know if fewer than 10 presses will work. I know 4 presses did not.
good luck
Mar 28, 2010 | HP Deskjet D4160 InkJet Photo Printer
Its stop printing and the LED power light green and orange at the center blink, like there is a paper jam.
Feb 11, 2010 | HP DeskJet 1280 InkJet Printer
Compaq armada 7400 does not turn on
Please turn off the Computer and disconnect the AC Adaptor then remove the Battery. Next, try cleaning the metal contacts on the Battery and reseating the RAM modules.Then, connect only AC Adaptor to the Computer and try to turn it ON without the Battery. If the Computer doesn't turn ON then disconnect the AC Adaptor and insert the Battery then try turning ON the Computer. If the issue persists even after performing all the above steps then service will be required.
Jun 23, 2009 | Compaq Armada 7400 Notebook
Engine light and orange arrow
If an orange arrow is blinking that means that there is a problem with your transmission i have the same problem with mine. Bring it too a mechanic there is a relay switch on the transmission they have to replace it cost about 150$$. Have you had any problems with the transmission before?
Oct 29, 2008 | 1996 Volvo 850
Error number 1700 canon s9000 printer
knowing printer manufacturers I doubt they even have a sensor to detect that its full at all, they probably based on something crumby like print count. here are some instructions to reset the waste ink tank, the instructions vary so try them until one does the job :
Waste Ink Tank Reset
1: Power off printer
2: Hold Resume button then press and hold POWER, the beeper will sound once.
3: Hold POWER and release RESUME
4: Press RESUME twice, then release all buttons
5: When the indicator lights steady, press RESUME three or four times. The indicator should be orange.
6: Press Power to set data
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
1. power off Printer
2. Push and hold resume button and push power button
3. Hold Power button and release Resume button
4. Push Resume button twice ( 2x ), and now release resume button and power button
5. Green light will blinking and stop.
6. When green light on, push resume button 4 x
7. Push Power button and printer will off, if that isn't off, push power butto again until print off position.
Aug 20, 2008 | Office Equipment & Supplies
HP DeskJet 6540 InkJet Printer Logo
2,158 people viewed this question
Seeker5211
Seeker5211
