Question about AEG B1180-4 Electric Single Oven
Aeg b4101 single oven ,three years od
Hope someone can help!
Although the oven heats up fine ,the cooling fan now keeps on running way after the oven is turned off ,and wont cut out,I took off top panel and can see a blue covered part with two white leads and a blue lead from it,the blue head of this is burnt black?is this probabley the problem and what is this called,many thanks,confused!
  • AEG Master
  • 3,463 Answers
Sounds like a faulty thermostat.You will need a new one
Posted on Nov 17, 2008
AEG competence B4101-4 built-in electric oven, the fan is staying on continually even when not in use. Only goes off if the oven is switched off at the mains. Is there a way to fix this problem?
when i bake a chocolate sponge cake it rises well,when cooking the top becomes cracked like dry earth and when switched off it comes down about a third. with my previous oven baking thesame recipee for 30 years i never had a problem- please advise the reason for this problem
May 26, 2011 | AEG B4101-4 Electric Single Oven
The oven works fine as in it heats up but when turned off the cooling fan keeps going...used it last night and this morning the fan is still on...turned oven on and it is heating up but as I said the fan...
most ovens use a cut in limpet themostat(sometimes called button stat) typically normally open and closed at 40deg c. it will be this that will be not resetting to the open position at room temp. on rarer models the timer controls the cooling fan. some models of aeg and electrolux have a thermal delaying device located in abulb in the wiring loom. hope this helps
Aug 02, 2010 | Ovens
Aeg b4101-4 cooling fan for electronics does not turn off.
Probably have a thermostat inside the space that is bad telling the fan to stay on . If you cant find thermastat which I believe you can at appliance repair shop just hook up a switch to the fan.
Jan 18, 2010 | AEG B4101-4 Electric Single Oven
Oven keep cutting out
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Oct 07, 2009 | AEG B4101-4 Electric Single Oven
Oven temperature no controllable
runaway temp
very easy its just the probe on the back wall
should be about 30
and 10 minutes of your time
Oct 03, 2009 | AEG B4101-4 Electric Single Oven
FAN COOKING MODE ON COMPETANCE B4101-4 NOT WORKING FAN WORKING BUT NO HEAT CONVENTIONAL MODE OK
If fan is working o/k, then you need to fit a new oven element.
Please rate my solution.
Thanks.
Sep 26, 2009 | AEG Ovens
AEG over B1180 Keeps switching itself off after about half an hour
if oven is in fact overhaeting then fauklt will be the thermostat
Nov 05, 2008 | AEG B1180-4 Electric Single Oven
AEG double oven- fan assisted not heating up
you oven element has failed.
it is located at the back of most electric ovens sometimes at the top,,
the insulation of the element has failed and when you come to remove it you will see visually see the damage... its easy to replace as there are only wires attached to it and only a few screws to undue to get to it..
hope this helps cheers
the washdoctor
Aug 24, 2008 | AEG B2100-4 Electric Single Oven
Oven cuts out after ten minutes and comes back after cooling down.
We have the same problem with our oven, AEG B2190-1.It started on on Christmas day[worst day of year]gets up to temperature after 10-15 minutes cuts out everything switches off until the oven has cooled down, The oven is only 18 months old. We have been told that it is a thermostat problem.
Dec 10, 2006 | AEG B2100-4 Electric Single Oven
AEG B1180-4 Electric Single Oven Logo
235 people viewed this question
Top AEG Ovens Experts
ashburton
Sal De
Steve
Are you an AEG Oven Expert? Answer questions, earn points and help others
