Question about KitchenAid KERC500 Electric Kitchen Range
My front burner not working.
The front right burner gets warm however will not get red hot like the other burners when turned on.
  • jcnuss Nov 30, 2008
    I have a kitchenAid keri203 Elecric range with the same problem, right front only gets warm, only 2 yr old.
  • tlaura21 Dec 04, 2008
    Yes that fixed it! I can't believe we didn't check that first. Thanks.
Check to see that your simmer switch is in the off position, I just had the same problem and checked it back to the power connector and only had 120 V ????, I about to take the switch out and then saw the simmer switch that I never noticed. Clicked it to off and now my wife is happy again. Good Luck, hope your solution is just as easy.
Posted on Nov 30, 2008
4 Suggested Answers
garing
  • 998 Answers
SOURCE: Right front burner on range will only get warm not hot
adjust air hood
Posted on Aug 07, 2009
marka19
  • 1430 Answers
SOURCE: The front right burner gets warm however will not
This is usually the burner or the receptacle. There is a video that will walk you thru testing and replacing these parts. They are both inexpensive and easy to replace. http://appliancehelponline.com/elementreceptaclevideo.html It may be a different model but the testing will be the same. You can also enter your model # for diagrams and illustrations for your specific model. All parts come with installation instructions.
Posted on Jul 21, 2010
  • 557 Answers
SOURCE: The right front burner will not get hot. It is
the burner coil is bad
Posted on Oct 31, 2010
Oven gets warm but not hot?
This could be a thermostat issue or a burner issue. Most ovens have a top and bottom burner, if one of them is not working, the oven may not reach or stay at the right temperature. You should be able to get a replacement at home stores that sell appliances or order one online. They are fairly easy to replace. You may have to remove a couple of screws but otherwise they pop out and pop in. You can test the burners by turning the oven on bake and a few minutes later open the oven to see if the bottom burner is red, if not it may be burnt out. You can set the oven to broil and after a few minutes, look at the top burner, if it's not red it's likely burnt out. If both burners seem to be working, it is likely a thermostat issue. I haven't replaced one of them before, but you should be able to find instructions on youtube to determine if it is something you are comfortable replacing on your on.
Aug 11, 2017 | Ovens
Both front burners won't turn off.
Replace the switches for burners that are not turning off.
Sep 05, 2017 | Kitchen Ranges
My 30 year old Whirlpool electric stove burners are heating inconsistently, especially the right front. If turned on medium for a while, it will turn red hot. It happens even faster when another burner...
Each burner has its own switch. I suspect your switch on that burner is bad or going bad. Conracts probably burring up from the constant arcing associated with closing and opening. Here is how it works:
Mar 02, 2013 | Whirlpool RF365 Electric Kitchen Range
The right front burner will not get hot. It is only warm never hot. The burner doesn't turn bright red even when tuned up on high.
hello, try changing that front element(burner)if its easily removable to another side that is working normal. If the element is still dull not heating or glowing normal then replace the element, but if it does, then there is something wrong with the front right element switch or the receptacle.
Oct 30, 2010 | KitchenAid Kitchen Ranges
Jul 19, 2010 | KitchenAid KERC500 Electric Kitchen Range
Burner dosent get as hot as the others
If you saw a spark from the burner chances are that the burner has shorted out and is in need of replacement.
Apr 06, 2009 | GE Spectra JBP78 Electric Kitchen Range
Burner on range will not turn off
Look at the back of your range there should be schemetic for your power control board. look for defective burner wire going into relay. There should be 5 relays in rows. Realy is the problem. I had the same problem with my front left burner stuck on high.
After replacing everything works okay.
Apr 07, 2008 | LG LRE30755 Electric Kitchen Range
Problem w/burners & lights after self clean
You may want to re-seat the right two cooking elements, in case there is poor electrical contact. When you have them removed, clean the contacts with denatured 91% alcohol and a Q-tip. The removal procedure follows.
First, unplug the range.
LIFT–UP PORCELAIN COOKTOP
To lift:  When cool, grasp the cooktop front
edge.  Gently lift up until the two support rods
snap into place.
To lower:  Hold the cooktop front edge and
carefully push back on each support rod to
release.  Then lower the top into place.
COIL ELEMENTS
➢When an element is on, it will cycle on
and off to maintain the heat setting.
➢Coil elements are self-cleaning. Do not
immerse in water.
To remove:  When cool, raise element.  Carefully pull out and away from receptacle.
Check them for damage. They do wear out.
To replace:  Insert element terminals into receptacle.  Guide the element into place. Press down on the outer edge of element until it sits level on drip bowl.
COIL ELEMENT SURFACE
➢ On Canadian models, the two front elements will not operate during self-clean.To prevent the risk of electric shock or fire, never line drip bowls with aluminum foil.
If that does work, you may have a faulty control panel. In that case, call Maytag at the number below.
Maytag Customer Service
533 Benson Road
Benton Harbor,MI 49022
(800)688-9900 U.S.
(800)688-2002 Canada
Dec 03, 2007 | Maytag MER6772 Gemini Electric Kitchen...
KitchenAid KERC500 Electric Kitchen Range Logo
262 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
