Question about Cameras
Lately when I record a video on my camera and play it back it plays back in high speed and I can't figure out how to set it back to normal
  • andyb81 Nov 07, 2008
    Yes just found the reset button of settings - thanks
  • Cameras Master
  • 1,879 Answers
Make sure that the speed setting is set to normal when you are recording.
might as well check the playback speed.
Posted on Nov 07, 2008
    Scholar:
  • 155 Answers
Can u please provide me your perfect model number to give u the proper instructions
  • Cameras Master
  • 19,396 Answers
The camera will reset simply by removing the batteries and putting them back on.
If this does not reset settings then that means that there is a fault.
Give me the exact model to get more help.
    Guru:
  • 558 Answers
Let us know the model number so we can figure out the and give you demo for this.
    Master:
  • 763 Answers
Try to look for a reset of your device or remove your battery to back into defaults. try to look also the settings on your camera from the menu.
thank you for using fixya
CHARCOIS
Canon ixus 75
Unfortunately, no. By recording in fast mode, the camera captured fewer frames than usual. When played back at the normal speed, the action appears faster than normal. Because the camera recorded fewer frames, there is no way to make up for the images that were not captured. You could slow down the playback, but the result would be a jerky, jumpy video.
Now, if you had accidentally captured the video in slow motion, you could then throw away some of the intervening frames and recreate a normal-speed video.
Feb 15, 2012 | Canon PowerShot SD750 / IXUS 75 Digital...
When I record a video using my Nikon Coolpix s4000, when I try to play it back the sound plays at normal speed but the picture is in slow motion! This happens everytime I record a video, is there anything...
Look for a Menu then FPS (Frames per second) option.30 fps should solve your issue. sometimes in order to keep file size low the setting is slower causing this issue.Good Luck.
Jul 29, 2011 | Nikon Coolpix S4000 Digital Camera
When I play back video. It only plays super fast. a 1 minute video plays back in 2 seconds. I have looked, but can't figure out if I have a camera problem or a setting has been clicked on that...
This occurrs when youu have the recording setting on time lapse with no sound. All you can do is to set the recording on to standard by turning the round wheel at the back of your camera.
May 12, 2011 | Canon PowerShot SD790 IS Digital Camera
I expected that the RCA leads from my turntable would just plug into the back of the RCD-W500C, but the manual indicates a somewhat complex cabling arrangement through the amplifier. I have not been able...
Your new cd player/recorder is a "component piece" as is your turntable,cassette player, reel to reel or CD player. Connect it as you would any other component piece of stereo equipment. Set up your recorder to "record" in real time(not high speed or synch record). Your tape recorder records anything that is playing through your reciever to your speakers. So, treat your "CD" recorder as you would a "CASSETTE TAPE" recorder. Play your vinyl record on your turntable and record to CD on your CD recorder ! Pay special attention to the dubbing speed, you will not use "synch or high speed !! Good Luck
Feb 26, 2011 | Audio Players & Recorders
Video records at high speed
You need to change your video settings. You have it set for time lapse. Turn your camera to the video mode on the top of the camera and then turn the dial on the back of the camera to the size of video you desire.
Aug 07, 2009 | Canon PowerShot G9 Digital Camera
Play back is double speed. Record is normal.
Found the trouble in the data coding head that is seperate from the video drum.  A loose connection on the logic board was not allowing the tape electronic markers to be set but a few times.  Therefore, even though the record speed was good, it could not retrieve the right referrence to set the play back speed.
Jeff
Mar 18, 2009 | JVC Televison & Video
Recorded video segment plays back in fast motion. How do i reset
This is a really simple problem and easy to solve.  Unfortunately the videos you've recorded cannot be changed back because they have been recorded in Time Lapse mode.
With the camera switched on in Video Mode turn the control dial on the back (this is the dial to the right of the LCD screen).  This will change the settings from TIME LAPSE to STANDARD.  There are actually 6 different modes but the best one for normal videos is STANDARD.  There is a HIGH RESOLUTION setting,  however these record fewer frames per second (fps) so whilst the quality is better per frame,  there are half the amount of fps so the the movie will look at bit jerky.
It's really easy to accidentally twist the dial when holding the camera,  so always check the icon in the top right of the LCD before recording to make sure its just a yellow camera in a yellow square.
This should be problem solved for all future recordings.
Jan 23, 2009 | Canon PowerShot G9 Digital Camera
Canon powershot 9
This should be problem solved for future recording.
Sep 20, 2008 | Canon PowerShot G9 Digital Camera
I have a canon SD 580. When I playback the video clip it's always in fast forward mode and I can't play it normal speed. Any help?
Make sure you are shooting your movies in "Standard" mode. If you have the mode set to something else, especially "Time Lapse", the playback may not match 'natural' motion.
In any case, you can control the speed of the playback. When you first enter the movie playback mode, there should be a movie control bar along the bottom of the LCD. Instead of the "Play" button, select the "Slow Motion Playback" button (single arrow with single bar next to the normal Play button), and control the speed with the left or right arrows on the multi-controller.
May 02, 2008 | Cameras
How do I pause while recording?
As far as I can tell, and yes the documentation is skimpy, when you press the 'record/play' button the video recording pauses. Make sure you press the video icon button, not the 'record/play' button to get it started again. If you press the 'record/play' button, it goes into a 'play back' mode.
Hope this helps...
Dec 26, 2007 | Jazz DV-179 Digital Camera
Cameras Logo
23 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
