Question about DCS Grilling
DCS 30" Grill and Side Burner hookup to a Single Propane Tank
What is required to hook both the grill and side burner up to a single propane tank.  Is this hardware included by DCS with the grill and/or side burner.
  • 32 Answers
SOURCE: jenn air 32 in. 4 burner gas grill
HAVE YOU TRIED THE ORIIGONAL TANK? SOME COMPANIES HAVE SPECIFIC TOLERANCES FOR FITTINGS THAT MAY NOT WORK W/ OTHER ITEMS.
Posted on Apr 08, 2008
  • 398 Answers
SOURCE: I need to purchase parts for Electrolux E5760ESS Propane Grill
try this site http://www.stovepartsplus.com/Merchant5/merchant.mvc?Screen=CTGY&Store_Code=SPP&Category_Code=BBQBURNERS
Posted on Feb 27, 2009
Sounds like a problem with the regulator. Try turning on the burners 1st before opening up the propane valve. If that doesn't work unscrew the gas line from the propane tank with the tank valve open a little (burners off) then screw it back on.
Posted on Apr 09, 2009
  • 10865 Answers
SOURCE: Side burner on propane gas grill burns with orange
here is a link to a page that shows what the colors of the flame should look like and what causes the orange instead of the blue flame. http://www.appliance411.com/faq/gas_range_flames.shtml
I would begin by checking to be sure you do not have a spider or a cob web in the burner partially blocking the gas or the air intake.
Posted on May 12, 2009
  • 582 Answers
SOURCE: Outdoor grill with no gas pressure, little heat
TURN THE TANK OFF , THEN REMOVE BURNER ASSEMBLY AND CHECK FOR OBSTRUCTION IN THE GAS LINE AREA . IT IS NOT UNCOMMON FOR SPIDERS TO BUILD WEBS INSIDE THE TUBES AND CAUSE MAJOR PROBLEMS
Posted on Aug 22, 2009
The grill is too slow when grilling. It doesn't seem to get hot enough
Turn off propane. Disconnect propane tank from barbecue. Open burner valves for about 20 seconds. Close valves. Reattach propane tank. Slowly open propane tank valve. Turn on burner and ignite
Aug 01, 2014 | The Holland Grill HGG421408LP Epic Gas...
Grill troubleshooting
It's not getting hot enough.Turn off propane. Disconnect propane tank from barbecue. Open burner valves for about 20 seconds. Close valves. Reattach propane tank. Slowly open propane tank valve. Turn on burner and ignite
Jul 31, 2014 | Holland Grill Classic II (NG)
Poor flame after changing tank on gas grille
Jul 05, 2014 | Weber Genesis E-310 Gas Grill
I have a Cook by Number gas grill, model LG36C, that isn't cooking as hot as it should. I've disassembled all the gas lines and blew them out with compressed air. I cleaned the burner. I cleaned the...
Since your grill only has one main burner and it requires more gas to heat with than the side burner. I still suspect you have a grill regulator issue. But, if you've done your research, you know it's easy to solve. Turn the propane tank valve OFF. Disconnect the hose from the tank valve and wait at least 5 minutes before reconnecting it. Once it has been reconnected, turn the tank valve on VERY, VERY SLOWLY (slow motion, slow). Once the tank valve is fully open, turn your main burner on, light it and turn it to high. Do the flames appear to be higher than before? If so, light and turn ON the Side Burner. Now do all the burner flames appear to be higher than before? If so, you solved the problem. If not, either the grillhose/regulator assembly needs to be replaced or the Venturi Valve on the main burner needs some adjusting. As the air to gas ratio may be off sightly.
Hope this helps to solve your problem and Happy Grilling!
Mar 29, 2011 | Fire Stone LG36C Propane
When I light my grill only one side of the burner has a flame, on all 3 burners. I cleaned everything and even cleaned each hole in the burners. What's next?
This is a common problem with grills purchased after 2001. There is a new safety feature inside the regulator called a 'surge protector'. If you open your propane bottle valve too quickly or if you try attaching a tank with the tank valve in the 'open' position, the propane wants to 'surge' into the grill.
When the propane surges into the regulator (located on the grill hose) the 'surge protector' (inside the regulator) kicks on. When this happens you will not be able to get your grill lit, and if you do, it will be a small blue flame and the grill will not heat up.
So what to do if you trip the surge protector and can't get your grill to light or heat up?
Shut the tank off and shut the valves on the grill off. Disconnect the tank from the grill hose. When you disconnect the tank from the hose you will hear the excess pressure of propane release. This is an indication that you have re-set the regulator's surge protector.
Now that you have deactivated or reset the surge protector, reconnect the tank. Make sure the valve on the tank and the valves on the grill are in the closed and in the off position. After you reconnect the tank to the hose, SLOWLY open the tank valve (making sure the valves on the grill are in the OFF position).
Since you have slowly opened the valve on the tank, the propane did not surge into the regulator and the surge protector did not activate.
Now open 1 valve on the grill and light it. You should get a nice flame. If your grill has more than one valve, open each following valve in sequential order to extend the flames to the other burners.
Thanks for reading and I hope this helps.
Ben Gaetani
Tanks 2 You Propane
propanetanks2you.com
Tanks2youpropane@gmail.com
Mar 02, 2010 | Grilling
I can not get any gas pressure in main burners or side burner, i have a new propane tank, just a trickle of gas not even enough to keep side burner going when only using side burner, will only produce a...
Look for spider webs in the venturi tubes, check the orfices or it could be faulty controls. Verify the tank working properly by trying on another grill.
Eric
Jan 24, 2010 | Brinkmann Charmglow 810-7400-S Propane...
Is not heating properly , the flame is not as strong as it used to be.
Ben Gaetani
Tanks 2 You Propane
Jan 18, 2010 | DCS BGB36BQARN (NG) Stainless All-in-One...
We moved from ohio to las vegas had the grill in moving truck. got new propane tank hooked it up not getting much propane to burners. there is hardly any flames.
Try this turn tank off make sure all knobs are in the off position check side burner if you have one disconnect tank reconnect tank make sure fitting is all the way on turn tank on and try again if this does not work you probably need new regulator and hose
Sep 02, 2009 | Grilling
Low flame/ side burner dosen't light
I just read this online and it worked for me. Hope you have similar luck.
Newer propane tanks contain a self regulating feature that will automatically slow down the flow of fuel if it thinks it's too high. This can be solved by turning the tank valve off completely and disconnecting it. Open the control valves (on the grill control panel) and ten close them. Reconnect the fuel tank and slowly turn on the valve. Now light the grill to see if that fixes it.
Dec 02, 2007 | Weber Genesis Silver C Grill
Grilling Logo
Top DCS Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a DCS Grilling Expert? Answer questions, earn points and help others
