Question about LG WM3677HW 3.7 cu.ft. Front Load Washer and Dryer
Tub filling with water after cycle is finshed
My Front load LG washer has been filling up with water after the cycle is finsished. There is a small trickle of water come out of the rubber door gasket. Would this be cause by a bad tube?
  • Anonymous Mar 17, 2014
    metlting the rubber on spin cycle smoking it up
  • 1,543 Answers
If your washer fills with water, usually slowly, after the cycle is over you have a inlet water valve which is not shutting off completely. LG usually uses a separate valve for the hot and cold. If you turn off the valve where the hose comes from the house and observe for continued water fill, first one, the reopen it, then shut off the other you should be able to see which (hot or cold) is the culprit. If you post your exact model number I should be able to list the part numbers for you. The inlet valves I am speaking of are the part where the hoses connect onto your machine.
Posted on Nov 07, 2008
My LG front-load washing machine does not completely wet the clothes in the speed cycle. I set to heavy soil and three extra rinses. How do I get more water?
When I was looking for a new washer, I looked at front loaders and was told that they are not really for dirty clothes, it is more for sprucing up an outfit or shirt. They are supposed to be energy efficient read this less water and shorter wash cycle.
I would go for a top load heavy duty, stainless steel tub.
You are just wasting money trying to get this one to wash over and over again. good luck.
Jan 03, 2017 | LG Washing Machines
Lint, and debris not going to filter
Generally speaking grass clipping etc will stay in tub on a hi efficiency washer. That's why the water level is very low also-high efficiency,low water use. Most LG washers have an extra water button to add a small level of water per wash.
Jan 16, 2018 | LG SteamWasher WM2650H 27" Front-Load...
Tub fill half way up with water
Possible fault with the water level sensor, since this is a new machineit is best to refer to delearship before you do it yourself as this is under warranty.
Jun 27, 2012 | GE WBSR3140DW Top Load Washer
LG WM2277HW washer not filling with water. All filters and water pressure checked, still not enough water to get the clothes clean. Any ideas?
PRESSURE SWITCH
Your pressure switch stops the water and allows it to start the next cycle. It's a switch either in the control panel or at the top of the tub with a small tube connected to it which goes down between the inner and outer tub. As the water level increases the air in the tube is compressed until there is enough pressure to "make the switch" stopping the water from filling. This tube can get clogged and the switch won't work. Remove the tube and clean it out. Blowing on the tube when it's still connected to the switch will make the switch if it's working and clear.
Water inlet valve
If it fills with water and starts the cycle and the water keeps running in then your water inlet valve on the back where the water supply comes in is sticking. It needs replacing.
Mar 24, 2011 | LG WM-2277HW Front Load Washer
LG washing machine WM2277H tub off center does not spin electronically, manually its spins but rubs sides
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems Washer noise when spinning
heatman101
Sep 02, 2010 | LG WM2277H Front Load Washer
My LG front loading washer makes a train noise during the rinse cycle. What could be the cause?
if it is right after the drain cycle; it then goes into a spin. It then starts to fill with water for the rinse while the tub is still turning. The water entering the tub while the tub is spinning, cleans the tub of soap and the water going through the holes in the tub are causing the noise. It is normal if only in the rinse cycle.
Aug 29, 2010 | Frigidaire GLTF1670A Front Load Washer
LG front loader - shower water filling up machine
your drain should have a backflow device in it. This can be very dangerous, you need a professional plumber ASAP.
Feb 17, 2009 | LG 4.0 Cu. Ft. 7-Cycle Front-Load Washer -...
Water runs into tub but does not fill?
be sure the drain hose is not lower than the wash tub this will caust the water to run out, 2nd be sure the drain hose is not pushed to far into the house stand pipe and the there is rome for air to go inbetween the drain hose and stand pipe eather of these will cause the machine to siphon mostly on rince cycle or on the 2nd and third loads you do. last your house drain could be starting to back up fill the washer with water and listen to it drain if you hear a gurggling sound in the house pipe you may need a plumber to cleanthis out for you.
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
Lg washer
funny enough LG water inlet valves are favorite for that problem. if you put the power off and the water still flows into the tub then the valve needs to be serviced. if it goes off when power is switched off but continues to fill after cycle is complete then board needs replacement.
May 28, 2007 | LG WD-1280FHD Front Load Washer
LG WM3677HW 3.7 cu.ft. Front Load Washer and Dryer Logo
346 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
