Question about Garmin GPS
Garmin forerunner 305 heart rate monitor goes very high for 3-5 minutes early into almost every run, then levels out and seems very accurate for the remainder of the run
In my experience this is usually caused by poor conductivity between the skin and the chest band. To solve it, just before a ride dampen your chest and the ribbed part of the band on either side of the centre transmitter. For me this is more of a problem on cool days when I don't sweat. I have no problems on warmer days.
Posted on May 14, 2010
How do i change a battery in a garmin 305
Hi David!
From your Owners Manual (Page 54)
http://www8.garmin.com/manuals/984_OwnersManual.pdf
REPLACE THE HEART RATE MONITOR BATTERY
"The heart rate monitor contains a user replaceable CR 2032 battery...
Locate the circular battery cover on the back of the heart rate monitor. Use a coin to twist the cover counter-clockwise until it is loose enough to remove. Remove the cover and replace the battery. Be careful not to lose or damage the o-ring gasket on the cover. Then use a coin to twist the cover back into place."
Hope this helps.
Jan 16, 2011 | Garmin Forerunner 305 GPS Receiver
Tip
Garmin Forerunner 305 manual.
Follow this link and download Forerunner 305 manual.
http://static.garmincdn.com/pumac/984_OwnersManual.pdf
on Feb 26, 2011 | Exercise & Fitness
I haven't used my Garmin Forerunner 305 for over a year - but have just started using it again. It wasn't picking up my heart rate from the HRM, so I changed the battery in the HRM but it is still not...
I found this on the internet......
In the battery compartment there’s a gold contact that touches the top of the battery (+ve) which was in a position that would never make contact with the battery. I bent it out slightly, made sure the battery was seated correctly (i.e. flat) and as if by magic my heart rate appeared on the large Garmin display!
Also found this..........
I Have had the same problem couple of times (and forgotten each time how I solved it). I figured it out just now and this is what I did.
1) turn on unit and put on heart monitor (make sure battery is good and wet heart strap)
2) using the mode button navigate the menus to: Settings: General: Accessories: Heart Rate Monitor
3) Once in the Heart Rate Monitor option make sure "Yes" is selected and then use the arrow buttons to highlight "Restart Scan" . Press the enter button to rescan for your heart monitor. (I had to rescan twice)
Go back to the main monitor screen to see if you are recieving heart rate signals.
I am not sure why a manual rescan needs to be done every time but it would be nice if Garmin fixed this issues in a unit software update (my unit has software version 2.80
Hope this helps......
Feb 09, 2010 | Garmin Forerunner 305 GPS Receiver
My garmin forerunner 305 HRM suddenly stopped working. I thought it was a bad battery so replaced that, and still nothing. Any other suggestions?
Nov 01, 2009 | Garmin Forerunner 305 GPS Receiver
When I start off the bpm goes up above normal then levels out after approximately 300 yds
This is basically the forerunners way of callibrating itself. It picks up the heart rate signal from the chest strap, sets itself high and then drops down until it matches the signal coming from the transmitter. This seems to be a feature in all the forerunner series though the Garmin reps I asked about it( I work in an outdoor store) weren't even aware of it and didn't seem too concerned even though staff who tested it had said it was annoying.
Oct 06, 2009 | Garmin Forerunner 305 GPS Receiver
Pulse meter died on forerunner 305
You may need to re pair the unit with the heart rate monitor. Settings/ General/ Accessories/ Heat rate monitor. RESTART SCAN. OR follow this link (Hope it works) https://buy.garmin.com/shop/store/manual.jsp?product=010-00467-00&cID=142&pID=349 Go here and click on owners manual. Go to page 46. Adding accessories.
Jun 15, 2008 | Garmin Forerunner 305 GPS Receiver
Garmin edge 305 heart rate sensor does not work
the rescan worked for me, didn't know it existed, briljant. Follow list below:settings/system/accessoires/rescan
I love google today;o)
Mar 21, 2008 | Garmin Edge 305 GPS Receiver
My Garmin 305 wont record calories when I'm in the Gym. I select the "Other" sport mode, the little guy skiing, and It doesn't recored or even register calories? It records during my Jog sessions while...
The 305 uses distance to calculate calories. They sell a "foot pod" that you can use indoors, and that will count your calories by calculating the distance you have traveled. The problem however, is that using distance to calculate calories is so inaccurate! The calorie count that the 305 provides is almost always WAY too high. Other heart rate monitors use heart rate to calculate calories burned, and it is a much more accurate measure. My garmin thinks i burned 700 calories an hour today while i was snowboarding, and, while that would be nice, there is NO way it's true!!
Dec 17, 2007 | Garmin Forerunner 305 GPS Receiver
Forerunner 305
my htc phone programs i had on my computer was interupting my connection between watch and computer,so as soon as i uninstalled the htc software it started working again, hope that helps
Sep 15, 2007 | Garmin Forerunner 305 GPS Receiver
GPS Logo
217 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
