Question about Dell Movie Studio Plus (2x125)
Drivers have code 12-not enough resources
The driver for my IEEE 1394 host controller (texas instruments)and my driver for movie studio plus both come up with a yellow exclamation mark, code 12, which says the device cannot find enough resoures. I think this happened after I upgraded my bios from A05 to A08 for large disk support. I was installing a 300 GB hard drive as a second source of storage. After I did the bios up grade and HD installation, I was exploring my computer when I found these yellow exclamation points. I have uninstalled and reinstalled both drivers, (several times) and I have removed the Movie Stuio Plus IEEE 1394 card and put it into another PCI slot. I have also done a repair install of Windows XP (Professional). None of these procedures eradicated the problem. Thanks for your help. Jacquie
  • realq Feb 20, 2008
    i have the same problem
IB4G2008
  • 3587 Answers
SOURCE: USB drivers
ahuh..remove that usb controller, and then do a hardware scan for differences should work well
and by the way, got backup for that Dell?
Posted on Feb 20, 2008
ChipcircuiT
  • 157 Answers
SOURCE: Analog Video capture not working through Dell Movie Studio
try to use pinnacale software...
Posted on Jan 06, 2009
EricDaniels
  • 80 Answers
SOURCE: No Ethernet controller on Optiplex XP Pro SP3
Hey evolution200.
Heres the installer file for your Broadcom Ethernet Controller:
ftp://ftp.us.dell.com/network/R132254.EXE
Get back to me and let me know if that worked out for you.
Posted on Feb 03, 2009
  • 233 Answers
SOURCE: my drive crashed so i installed a new hard drive,
Try to manually update the drivers.
Go to Settings/Control Panel/System
Hardware tab
Then Device Manager
Click on one and update.
Let the OS search the CD with the drivers.
(You may have to navigate to the correct directory)
If this fails you will have to go to the DELL website and download the drivers for your machine.
Hope this helps!
Posted on Oct 31, 2009
  • 744 Answers
SOURCE: Can't get wireless card to install
This is strange, and it sounds like you've done everything right, but.....have you tried a reverse install?
Remove the card, un-install all the drivers and remove the device from the device manager if the uninstall doesn't do it.
Shut the machine down (turn it off)
Install the Linksys card in your available PCI slot.
Start the machine back up. When the Found New Hardware message pops up, follow the prompts from there instead. Your PC may be able to load drivers it already has. If not and if it asks for a disk, then use the CD you got with the card.
All of this assumes the card is ok to use with XP
Posted on Dec 12, 2009
Testimonial: "Although it didn't work, it was something I hadn't tried, which is always helpful. "
How do I connect my M-Audio Projectmix I/O to my PC running Windows 7 x64 via TI Firewire card? PC is not recognizing Projectmix.
Did you change the IEEE 1394 Host Controller to a legacy driver or did you just add one? You have to change IEEE 1394 to the 1394 OHCI Compliant Host Controller, specifically.
Did "Firewire Enabler" get installed in the Start menu? If so, give it a try. Make sure to download the latest PMI/O update from M-Adio if you haven't already.
Also, the old computer might of had a different PCI card. I remember there being compatibility issues with PMI/O and Express cards. Check the card type. There might be a firmware, patch or an update to fix the issues.
If the card is incompatible, just switch out with the other (if you still have it).
If the issue still exists, try Klinke's MCU plugin. It should work if nothing else. Maybe check for ASIO Driver issues. Other than that, it would have to be hardware or bad cables.
Aug 15, 2016 | M-Audio ProjectMix I/O Control...
Acer Extensa5620z originally had Vista, I wiped the hard drive and installed W7. Its not as simple as I thought. Now I need to update drivers and Acer.com doesn't have anything listed. In the det
Windows 7 should automatically install device drivers for the Audio, Video and Network, If you are unable to find/download a device driver that works on your computer and your computer is connected to the Internet then - 1. Remove the driver that isn't working if it was installed.
2. Set Win-7 "Windows Device Installation" to 'AUTO'
3. Windows will automatically search the internet for the driver.
4. Reboot your computer.
Mar 19, 2013 | AU Optronics Acer Extensa 5620-4801...
How can I get Windows 7 Movie Maker to recognise input from my Sony DCR TRV18E Handycam?
On page 230 of the user manual, it describes how to transfer movies from the camera to a computer using an i.Link (IEEE 1394) cable. You will need the 4 pin i.Link cable and an IEEE 1394 connector on your computer in order to do this. You cannot use the USB cable to transfer the video from this camcorder -- you can only transfer still images using the USB cable.
You will have to buy this i.Link cable and (if you don't have a IEEE 1394 port on your computer) a IEEE 1394 adapter card for you desktop computer. If your laptop computer doesn't have a IEEE 1394 adapter, then you're pretty much out of luck.
Once you have the i.Link and 1394 issues resolved, then Movie Maker should then recognize the camera.
Dec 27, 2010 | Sony Handycam DCR-TRV18E Mini DV Digital...
Unable to get dv input / output via ieee 1394 port
try an older version of pinnacle studio or another pc if still no capture, firewire camera board failed.
Oct 24, 2009 | Panasonic AG-DVX102AE DV Digital Camcorder
No sound in a reformatted computer
HELP what are you asking in short
Aug 01, 2009 | Computers & Internet
Download PV-GS39 cam recorder drivers
Hello. I also have the PV-GS39. I had the same problem as you have, here is what I DID to resolve my problem.
1.Go to: http://www2.panasonic.com/consumer-electronics/support/Cameras-Camcorders/Camcorders/MiniDV-Camcorders/Drivers-Downloads/model.PV-GS39.D
the above link will take you RIGHT to the web page to download the PV-GS39 Software & Drivers that YOU WILL HAVE TO HAVE. But if you have WINDOWS VISTA then you can use the WINDOWS MOVIE MAKER software that is ALREADY PRE-INSTALLED on your PC then you will NOT have to download the software from the above link.
2. You HAVE TO have a: FIREWIRE IEEE 1394 PCMCIA NOTEBOOK CARD. I got mine at: Best Buy for: $53.86 with taxes. the name of this card is: DYNEX FIREWIRE IEEE 1394 PCMCIA NOTEBOOK CARD.
3. You ALSO hae to buy the CORD that connects to the PV-GS39 and the DYNEX FIREWIRE IEEE 1394 PCMCIA NOTEBOOK CARD, the cord costs $36.79 ALSO at Best Buy.
I did ALL 3 of the above and now I'm copying my movies and videos from my tape in my camcorder onto my PC and BURNING the video onto DVD/CD Disks.
If you have any questions, you can email me at: uggyredmonster@comcast.net.
Sincerely,
Rick D. Michaels
Feb 28, 2009 | Panasonic PV-GS39 Mini DV Digital...
1394 Controller trouble
What service pack is on it? What does event viewer say?
Nov 22, 2017 | Gateway GT5426E Refurbished AMD Desktop...
Driver for IEEE 1394 BUS HOST CONTROLLER
Download Driver Detective and it will reinstall it and do updates for you.
Dec 12, 2007 | Toshiba G15-AV501 Qosmio Notebook
Televison & Video Logo
1,714 people viewed this question
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
CoppellTVRepair.com
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
