Question about Fuji FinePix A345 Digital Camera
FinePix Problem were you able to fine the issue with your camera. I have the same issue.
    New Friend:
It is not responding it is comming memorycard protected
Posted on Sep 05, 2013
Half the frames I take with my Finepix HS30exr are either blank, incomplete or in a mosaic as if someone cut them into pieces and assembled those in random order. Is the camera to blame, or can it be
sounds like there is a problem writing to the card. can be a camera or a card issue. if you try another card and you have the same problem then its the camera, if you try the card in another camera and have the same issue then its the card.
Nov 19, 2014 | Fujifilm Finepix Hs30exr black Digital...
Fujifilm battery fully charged but camera says no charge or very little. Just bought a new Duracell Battery and Charger for my Fuji FinePix J10 Camera. Used the charge on the battery in the camera from...
Well you mentioned that it worked fine yesterday with the battery out of the box. That should tell you that the camera and the battery are both fine. The issue is likely the charger itself. Try recharging it again, and double check that you inserted the batteries correctly, and that any switches (such as for 2 or 4 battery charge) are set in the correct position on the charger. If this doesn't work, take the charger back to the store for exchange/refund as defective.
Jun 11, 2011 | Fuji FinePix J10 Digital Camera
My Finepix has a white screen. Help.
Hello
White screens or screens with similar issues (black, "staticy") are indications that the CCD sensor has failed. It is the image sensor that the camera sees with. The camera itself may be operating just fine otherwise, but you can no longer see anything (as the camera can not) via the LCD screen (as it is relaying what the CCD sensor sees).
Unfortunately, your camera will have to be repaired. However, with a camera of that age, you may be better served by purchasing a new one, which will have more features for around the same price as a repair.
Mar 12, 2011 | Fuji FinePix S5000 Digital Camera
I have a Fuji FinePix A330 camera and when I try to take a picture in the light, daylight or lamp light, lines appear through the picture. Sometimes fine lines but other times like a burst of light. This...
I have a Fuji FinePix A330 camera and when I try Problem with the Fuji FinePix A330 Digital Camera I have a Fuji FinePix A330 camera and when I try to take a picture in the light, daylight or lamp light, lines appear through the picture. Sometimes fine lines but other times like a burst of light. This just started happening recently. But when I take a picture in the dark with the flash the photo turns out fine. Any answer as to what caused this? Thanks
Dec 28, 2010 | Fuji FinePix A330 Digital Camera
Fujifilm FinePix S1000FD shutter button won't focus
There is an option in the menu to put camera on continuous auto focus. You must have the camera on manual setting to have this option available, but once selected, it should stay on in auto setting. It will wear the battery faster, but it should solve the issue you are having. Hope this helps!!!
Aug 03, 2009 | Fuji FinePix F30 Digital Camera
Studio utility crashing
What did you do or what changes did you make to your computer since all operated fine? Bad things just do not happen - you must have done something that is now responsible for the issue. Can you repair your Vista installation - your OS may be at issue. If you have other computer with Vista try installing there to see if it works. Maybe something is now wrong with the camera - it happens.
Aug 08, 2017 | Fuji FinePix S3 Pro Digital Camera
Communication Error
Try connecting the camera to another computer. Is the camera reading the same error? If not, it's a computer issue.
If the camera is reading the same error, see if there's a way to restore camera back to the factory settings, and try all over again. Good luck :)
Apr 07, 2008 | Fuji FinePix S5100 Digital Camera
FujiFilm FinePix A500 screen turns off when trying to take a picture
I had the same problem with a fujifilm finepix... It didn't take pictures with 2 sony batteries, just turned off after pressing the shutter. Then I tried 2 panasonic batteries and it worked fine....
My solution: try panasonic rechargeable.
Oct 24, 2007 | Nikon COOLPIX P4 Digital Camera
Finepix a600 not recognized
Remove the camera software entirely. Assuming you PC is 2000/XP no camera software or driver is required. It should simply come up as a new drive in My Computer Come back on this one
Jul 12, 2007 | Fuji FinePix S304 Digital Camera
Fuji FinePix A345 Digital Camera Logo
21 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
