Question about Sony XL-2100U Projector Lamp for KF-42WE610, KF-50WE610, KF-60WE610, KDF-60XBR950, KDF-70XBR95
Replace Lamp Flashing
Tv was fine last night, when we tried this morning to turn on it will not come on and the red replace lamp light is flashing then shuts off. Any suggestions other than the obvious? Had no issues with the picture last night. Tv was built on October of 2004
  • 2 more comments
  • brianoling Dec 07, 2008
    The exact same thing as above however I have had mine since Nov 2004 (4 years). Is this about the life expectancy for one of these lamps?
  • sudarsv Dec 27, 2008
    I too bought Nov 2004. Sony Wega 42" LCD Projection TV. Looks like it is time to replace. Thanks.
  • reagp Jan 10, 2009
    I have owned my Sony 42WE610 since January 2005 and it's almost like clock work - I need a new lamp every year around the same time in January. The symptoms include the TV shutting itself off with the red light flashing and then turning back on by itself. Or I have to unplug it and it resets itself, but I may have to wait a few minutes before plugging it back in. Another symptom is some kind of greek lettering across the screen. The picture and sound are great, but I wish it now had an HDMI connection and the amount of money I have spent on bulbs I could have bought a new TV. I would stay away as Sony is aware of the lamp issue.
  • mikekirk Feb 24, 2009
    Sony KF42WE610 will flash green 40 seconds then the red lamp light flashes for the same amount of time and goes shuts off. If I try this often enough the TV will come on and run until it's turned off. It doesn't appear to be the lamp but could it be a driver for the lamp?
  • 5 Answers
Clean the cooling fans, specifically the lamp cooling fan located inside the rear cover, above the optical blocker. This is easily blocked with dust and causes overheating of lamps/shortened life.
Posted on Apr 20, 2009
You need to replace lamp.
Posted on Nov 18, 2008
I am having issue with my TV it won't turn on and I have a flashing red status light keep flashing can anyone help
Hi, if your tv is between 1-4 yrs old and havent replaced the lamp it might be time to do so.Mitsubishis uses Osram lamps to light up the screen and tend to last from 3000-4000 hrs normally 1-3 yrs.The Red light indicator usually indicates its time to replace the lamp.Heres the lamp you would need On the same link it shows you how to replace it ,have a blessed day.
Apr 18, 2011 | Mitsubishi WD-73827 73" HDTV DLP TV
The fan dont turn on when i turn on the tv and the red light is flashing
Red light flashing on tv indicates that tv got some problem and shifted to protection mode to avoid further damage.
If Lamp light is flashing on tv then check lamp that would be dead or broke, replace lamp to solve tv problem.
If standby red light is flashing on tv then let me know how many times it is flashing after 3 seconds long pause to provide you helpful info.
Jan 22, 2011 | Sony KDF-E55A20 55 in. LCD Television
WD57732 purchased 12/06 and has worked fine. Turned off at 11 pm last night. No indication of trouble. Tried to turn on this morning and nothing. Did TV Reset, green light flashed for a minute like it...
Now,tv on?.Tv "LAMP" LED light indication flashes or stay on?How long the Lamp been inside this tv,been inside like 1 1/2 or 2 years and tv been on each day like 4 or 5 hours a day in used.The lamp life are over.Should replace another lamp.
Dec 10, 2010 | Mitsubishi WD-57732 Projection Television
My Samsung HLR5067 was working fine last night. I left the house open and it dipped in temp (only to 40 degrees or so though)...Woke up this morning and it wont turn on at all. Just beeps a few times,...
Tv projection Lamp might be some how the causes again.Tries unplug,replug tv back like about an hour later.Try it again,should work now.If not,yes the projection lamp,might have been kill by the cold weather.
Dec 06, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
Sony grand wega KDF-55wf655 TV goes into flashing green mode
I was having the same problem. I am no expert, but what I read on-line is that it was likely the lamp needing replaced, that the lamp toward the end of its life will flicker and cause the TV to "reboot". I had no Red Lamp replacement light, so I wondered if that was really the problem. But, I bought a replacement lamp for $110 plus shipping, and replaced it last night - TV is working great now. I would try replacing the lamp on yours first yourself (if the lamp is older than 2 yrs), then if that does not work, contact a service person. Don't have a service person replace it, because I have heard many people say they paid $400 for a replacement lamp service, and I did it for under $140 with overnight shipping charge for the new lamp. My original lamp lasted 4 years, so I was lucky to not have this problem sooner.
Dec 28, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Replace the lamp - they only last about 2 years with 4 hours use per day.
Jun 21, 2008 | Televison & Video
Hitachi Ultravision Digital 55" hdtv
Good Day;
Try this:
Symptom: All Front LED indicators are flashing in sequence: Power-->Temp-->Lamp-->Power......continuously
Cause: Replace Lamp . This symptom may happen all the time or it may be intermittent. It is normal if it occurrs from time to time, See OG under TV Front Indicators explanation notes.
Good Luck, big IRISH.
Jun 13, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Status Light Flashes Red
first did you getthe lamp from miths and if notyou could have bought a bad lamp. you need to get a lamp form mits if you did not buy from them. if you did buy from mits have them replace the lamp it has a 90 day warranty. try hitting the menu and device / input buttons for 5 sec and repost the blink code. it is a 2 digits blink code. (ex. 23 or 33 or 26 like that)
Apr 20, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Sony XL-2100U Projector Lamp for KF-42WE610, KF-50WE610, KF-60WE610, KDF-60XBR950, KDF-70XBR95 Logo
1,033 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
