Question about Leviton 10 Brown Switch Outlet Receptacles 15a 5225
Electrical I own a very old home that has the old "2 slot" outlets. The house is so old that it has 'screw in fuses' not breakers. I want to upgrade all of the outlets in the entire house. My problem is that when I opened up one of the outlets, I don't see where to ground the new outlets? Can anyone help me?
  • 45 Answers
Older houses such as yours are wired with 2 conductor Romex. Since there are only 2 wires (120v "hot" & neutral) there is no ground wire.
In order to comply with the National Electrical Code (which is strongly advised), you are limited to the options that Tommy listed above.
The cheapest and easiest option is to replace the old 2 wire devices with new 2 wire devices.
Be advised that GFCI receptacles will not fit in many of the older junction boxes.
If you wish to "upgrade" your wiring to a three wire grounded system, you will need to find an electrical contractor, or an electrician. - Rewiring a house can be very expensive. (depending on its size)
Posted on Aug 25, 2009
    Problem Solver:
  • 19 Answers
Current electric code requires a ground or one of the following
A) Repace with GFCI recepticle, you maybe able to protect several pluge off one, depends on wiring.
B) Run a copper wire to a water pipe, you have to do this from most all plugs.
C) repace with new wiring or 2 prong receptcle.
Hope this helps
Tommy Master Electrician
Posted on Jan 05, 2009
    Genius:
  • 1,605 Answers
The old outlet or switch do not have "ground" per-say, if the junction box is steel and you have romax (steel jacket) cable. the casing is the ground.
you need a special cutter to cut the jacket, once you do that, you will see a steel wire inside, that is your ground.
if you have the present day 30wire cable (plastic jacket) then the green wire is the ground. it should be grounded on both end, on the switch or outlet and in the breaker box.
Posted on Nov 07, 2008
Old home, a electrical outlet actually has a fuse connected right to it. How to replace/install a regular outlet plug? I have a pic, but site doesn't appear to have a place to attach it.
electrical work is not for DIY
some one has messed with the electrical wiring of the house so get in an accredited electrician and consider having the house rewired using the correct ELB devices in the power box
Jan 11, 2017 | Microwave Ovens
Tip
Grounds? or Grounded?
When I bought my house was not a brand new one. my wife said "well you know about everything No?" So I had to prove myself. Fixer up houses could be a pain in our Royale ****! but us man will say yes I can do it!. One of the problem I address right away in my new use home was the electrical wiring. Old houses need to be upgrade their electrical wiring including main fuse breakers boxes. I went to my local hardware and found different gadgets & devices to help us Doit Yourself people. For a few bucks i found this plug in device that will give me different light blinking tones when you encounter a faulty wiring or open ground. It works, I found some open ground in my wall outlets and fix them. Open ground can cause electrical failure in your wiring which could affect all your electronics and appliances. Take your time to check for open grounds wiring in your home you won't regreted.
Call your local electrician for your electrical needs. Don't be a fool to try to fix things without the right knowledge & experiance in such matters.
on Jun 30, 2010 | Hammering
Do I need special electrical outlet?
You need to check with a licensed electrician for your area that would know the electrical codes. Most houses will all ready have an outlet for the stove and you will have to match it up with for the cord on your stove. Older homes that have not upgraded the electrical, typically will have a 3 wire outlet for the stove. Most newer homes, where the code requires, may have a 4 wire outlet. If you are replacing an existing stove I would recommend getting a new pigtail cord for the new stove so that you have new wires carrying the current instead of trusting old wires. Hope this helps!
Mar 20, 2015 | Ovens
Goldstar dehumidifier dh404ey7 starts and runs about 5 mins., then trips house breaker in all different outlets.
any appliance that trips the fuse or breaker should not be tried to use by homeowner this is a fire hazzard as an electric short is a dangerous situation to have in any home , replace unit ! ck with mfg for recalls first and warrentys as well then contact your power company sometimes they give rebates for appliance upgrades but they require old ones back in order to pay u money on them
Oct 02, 2014 | Goldstar Dehumidifiers
There s no power to my oven
Good Morning Friend,
I understand that you are not receiving power to your Frigidaire oven, model# FEB30T7FC, even though the power is on to your home and the breakers have not been tripped. Please try the following:
    1)Be sure the electrical cord is securely connected into the electrical junction box.
    2)There is a possibility that the service wiring is not complete.
    3)There is also a possibility that there is a short in the cord or plug. Replace the cord or plug.
    4)The house fuse has blown or the circuit breaker has tripped immediately following installation. The house fuse may not be fully engaged. Check the fuse and screw or engage circuit breaker securely.
    I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
    -Best Regards-
    WP
Jun 21, 2014 | Frigidaire FEB30T7FC Stainless Steel...
Blowing breaker
In general house hold circuit breaker of the house is 15 Amps or 20 Amps.
Either you have defected (weak) circuit breaker and wiring or bad Microwave oven.
The 99.99 % house hold Microwave ovens pull less than 15 Amps. They may have internal ceramic 15A fuse or 15 Amp internal circuit breaker.
To isolate your problem:
1. Plug your Microwave oven to different areas (different electrical circuit) if the different circuit breaker still trips... your Microwave oven has a short - Most of them has a small ceramic fuse 15 amps fuse.-also check some inter lock switches at door .
2. If the Microwave oven works Ok then you may have:
2a. You may overload the existing electrical circuit, try to unplug some other appliances
2b. You may have bad electrical outlet receptacle (Replace it with the same type , - may need helps from licensed electrician)
2c. Weak or defect house hold circuit breaker. (Replace it with the same type , brand - may need helps from licensed electrician)
Jan 24, 2014 | Goldstar Microwave Ovens
My frigidaire dryer LEQ642DS0 will not shut off by itself, would that be the timer or the knob? Also if it is the timer, is the kenmore/frigidaire part #131062300 (timer) compatable with my dryer
Instructions
Things You'll Need:
* Phillips and hex nut screwdrivers
* Replacement thermal fuse
* Replacement thermostat
1. Disconnect the dryer from the electrical outlet.
2. Slide a putty knife between the top panel and front panel on the left side. Slide the knife toward the center of the dryer to release the left-side spring clip. Repeat the process on the right side. Lift the top panel up and rotate toward the back of the dryer. The thermal fuse and thermostat are located along the dryer's back wall, attached to the heating element housing.
3. Disconnect the two wires from the thermal fuse. The thermal fuse is an inch-long rectangular plastic part, located near the top of the heating element housing. Remove the screw holding the thermal fuse in place. Remove the old fuse. Place a new fuse on the housing and replace the screw. Reconnect the wires to the fuse.
4. Remove the wires on the thermostat. The thermostat is a black, oval-shaped part located just below the thermal fuse. Remove the screws holding the thermostat in place and slide it out of its slot on the heating element housing. Slide a new thermostat into the slot and replace the screw. Reconnect the wires.
5. Lower the dryer's top panel and press down until the spring clips lock into place. Plug the dryer back into the electrical outlet.
Feb 24, 2011 | Frigidaire Dryers
Need to get replacement electric fan motors for bathroom exhaust fans. 1-Model # F33HXCFJ-1187 and 1-Model # F33HXBME-903. Both made by Emerson 1/100 hp, 120 v
Hello
Using a stool positioned directly beneath the inoperative fan, grasp 2 opposite sides of the plastic fan cover and pull cover down 2 to 3 inches until wire holding clasps on each side are exposed.
Squeeze the 2 wires on each clasp together until the fan cover is released and set aside fan cover.
Locate fan electrical plug and unplug the connection from the electrical outlet.
Locate the screw securing the fan unit to the ceiling. This is often found directly adjacent the electrical outlet. Some fan models will have 2 securing screws. These will be located on opposite sides of the fan base.
Use flat-head screwdriver to remove securing screw, pull fan out of the fan well and set old fan aside.
Align replacement fan in position to allow electrical plug to be inserted in electrical socket and plug into electrical outlet.
Insert fan into ceiling well and secure by inserting and tightening securing screw(s).
Test fan by turning on wall switch. If fan fails to operate, check to be certain that the plug is fully inserted into the electrical outlet. If fan still does not operate, check circuit breaker and reset if necessary.
Replace fan cover by holding cover in place with 2 wire clasps just below the slots in the fan base. Squeeze the 2 wire ends of each clasp together and insert these into the the slots on opposite sides of the fan base. Once properly inserted, the ends of the wire claps will spring into place.
Push the fan cover up allowing the wire clasps to be fully inserted into the slots on the fan base, at which point the clasps will spring open securing the cover in place.
THANK YOU FOR VISITING FIXYA
Jan 31, 2011 | Home
Right side stopped working
In the manual:
Check to see if the toaster is plugged in; if it is, unplug the toaster, then plug it back in again.
A tone will sound when the toaster is plugged into a live electrical outlet.
If no tone sounds, check the electrical circuit the toaster is connected to -
is a fuse blown or a circuit-breaker tripped in your home?
At least with "unplugging and plug it back again in the electrical outlet" the right side of our toaster works again. The tone that should sound with plugging in didn't work...
Aug 15, 2009 | KitchenAid KPTT890 Pro Line 4-Slice...
I bought a home with no home inspection and i have a little electrical problem in the basement area. the house was built in 1978. it looks like one of the previous owners did the basement.basement looks...
POSSIBLY THE EASIEST THING IS FIRST TO DETERMINE ALL THE THINGS THAT ARE ON THE CIRCUITS IN QUESTION AND WORK FROM THERE , AT LOWE'S OR HOME DEPOT OR A GOOD ELECTRICAL STORE YOU CAN PURCHASE A DEVICE CALLED A CIRCUIT FINDER THAT WILL HELP YOU FOLLOW THE CIRCUIT FROM THE PANEL TO EACH PLUG IN OR LIGHT FIXTURE , WHEN YOU GET IT ,It WILL COME WITH DIRECTIONS ON ITS USE IT SIMPLY PLUG IN OUTLETS IT WILL SAY TO PLACE OVER BREAKER BUT SINCE YOU ARE WORKING OUT OF A FUSE PANEL DO THIS PLUG INTO OUTLET YOU THINK IS THE FURTHEST FROM PANEL AND PLACE DEVICE OVER OUTLET NEXT CLOSEST CHECKING BACK TOWARD IF YOU NEED TO PLUG INTO LIGHT FIXTURE USE THE SCREW IN 2 PRONG PLUG LIKE YOU WOULD SCREW IN TO HOOK UP A EXT CORD ETC CHECKING FOR PROBLEMS ALL THE WAY BACK TO AND INC THE FUSE PANEL BY DOING THIS YOU SHOULD BE ABLE TO DETERMINE THE CIRCUIT ROUTING AND HOPEFULLY FIND THE PROBLEM ,HOPE THIS INFO USEFUL
Oct 20, 2008 | Champion 2000+ Household Juice Extractor
Leviton 10  Brown Switch Outlet Receptacles 15a 5225 Logo
192 people viewed this question
Top Leviton Electrical Supplies Experts
 Kenneth
Kenneth
Steve
Hippy_dd
Are you a Leviton Electrical Supply Expert? Answer questions, earn points and help others
