Question about Maytag MER6772 Gemini Electric Kitchen Range
Burned on stain on burner will not come clean using cleaner and the blade
We bought a 4 yr old house and the smooth top stove has a burned on stain that the smooth top cleaner/blade will not remove it
  • sssnead Mar 30, 2009
    I have a dark stain on my smooth top and I have used all the products - it seems to be in the actual glass - did anyone ever get such a stain out? The blade does not work, windex, vinegar and Mr. Clean did not work. I have not tried the baking soda but I am not too hopeful at this point.
    Susan Snead
  • Anonymous Mar 12, 2014
    cleaning old food burn stains from glass counter top stove
    Scholar:
  • 48 Answers
There are some very effective commercial products available. One of the most highly rated is Cerama-Bryte, but BE SURE TO FOLLOW THE DIRECTIONS CAREFULLY....as once it dries it is impossible to remove!!!!! Work in small areas, rub consistently.
As well, mr. clean magic eraser also has worked magic on my mothers stove over the past few years also.
If you wish to stay away from the store-bought chemical....soaking the spots with water and ammonia OR vinegar..(not both) and elbow grease. As well....the razor blade in combo with the liquid.
Be sure to rank me.....please....especially if this Fix-ya`s....
Posted on Nov 07, 2008
How do I remove melted plastic from top stove burner, kitchen aid oven/stove, branch new
Clean the stove so all food residue is removed. Take a single blade razor blade and very slowly scrape the edges of the melted plastic. Blade should be held at a low angle, and only a small amount should be cut away at a time. It will take time, but the plastic will come off.
Once clean, use the manufacturer approved cleaner to clearn the area.
You may want to try to turn the burner on for about 10 seconds on high, and then off to help soften the plastic. Be careful to not burn yourself.
Mar 08, 2015 | Kitchen Ranges
Hi, I have a wonderful Maytag speckled black smooth top stove. Over Christmas someone caused a big (2 " diameter) stain. I've tried everything to get it out. is it possible to have a new ceramic...
Ceramic cooktop cleaning tips - especially for 2-in difficult-to-remove stain:
Best Idea: "Cerama Bryte" + plastic scrubbie
Cerama Bryte is specifically designed for this cooktop, works on stains, avail at Hardware Stores.
Other ceramic cooktop tips:
1. "Soft Scrub" plasic scrubbie
2. Comet cleanser + sponge
3. Single-edge razor blade held at 45-degree angle - scrapes off material
4. "Cook Top" cleaner (WalMart) + Mr. Clean "Magic Eraser" abrasive pad
5. baking soda on damp sponge
6. soak stain for awhile with Formula 409, Fantastic, or citrus degreaser ("Orange Clean")
7. ammonia + water - in a 1:1 solution
8. Easy Off oven cleaner - it foams on the stain and does the work for you - let it sit 20 min.
9. the nuclear option:
Cerama Bryte under a plastic scrubbie under an orbital sander with sandpaper removed
(just the pad down on top of the scrubbie), after pre-soaking in Citrus Degreaser.
The sander is a power tool which only saves your joints, and speeds up the chore.
Jan 17, 2011 | Maytag MER5775Q Electric Kitchen Range
I have a bad stain on my ceran top stove. It is like a hard glue, which boiled over while steaming broccoli. How do I get this out please?
This has worked for me when I've melted plastic on my stove top, or had other stains that did not come off easily. Use a razor blade to scrape off all you can. Then, when it is cool, use stovetop cleaner (I use Weiman's) and a no scratch scrub sponge. I don't know what your stain is, but the razor blade will probably work.
Nov 03, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
How do I clean my new electric Jenn-air cooktop with its glass top? Do I need a special cleaner for the glass?
  • Step 1 Wipe up spills as soon as they happen with a clean dry towel. According to the Jenn-Air website, for glass top cooking surfaces, you should do this even if it is hot since it will be harder to clean up later. Be careful not to get burned.
  • Step 2 Use a cooktop cleaner once it is cool. You can also use dishwashing detergent and water or just a baking soda paste (made with water).
  • Step 3 Apply the cleaner to a sponge, cloth or paper towel. For more stubborn stains, you can use a non-abrasive or "scratchless" pad.
  • Step 4 Rub the soiled areas until clean. Rinse well, especially if you used the baking soda paste as that can leave a residue.
  • Step 5 Use a razor blade for burned on and crusty stains that will not come off using the previous methods. Jenn-Air states to hold it at a 30-degree angle to carefully remove the stain.
  • Or you can use this on the link below.
    http://www.amazon.com/Blue-Ribbon-88100-Cooktop-Cleaner/dp/B000HM5INA
    Good Luck and please rate 4 thumbs up for the free answer
    Jun 25, 2010 | Jenn-Air 30 in. CCE3401 Electric Cooktop
    How can I clean my GE stove top burner and black stove cap???
    Soak the black stove caps in 1 part ammonia and 3 parts water. Let soak for several hours. I let it soak overnight. It should clean right up.
    Jun 11, 2009 | Frigidaire 30" Self-Cleaning Slide-In Gas...
    I had a 2inch by 2 inch black grease stain from a cast iron pot on my ceramic cook top. I used whirlpool cooktop cleaner and a razor blade to try to remove the black gunk. The more I used the cleaner and...
    You could try a little oven cleaner on it. That should take care of the mark. After that, if it did not work, clean off the oven cleaner well and then try a bleach solution.
    Post a comment with your progress.
    Tim
    May 03, 2009 | Kitchen Ranges
    Stains on glass top
    This is smooth glass - you can use a razor blade on it. Hope this helps!
    Jan 13, 2009 | GE Profile Spectra JBP95 Electric Kitchen...
    We have a maytag ceran cermaic top cooking stove with large black stain that seems to be spreading like cancer over one of the "elements". We have tried a couple different over-the-counter...
    try using the regular ceramic cooktop cleaner, apply and clean as you werewaxing a car, in samll circular motions, any stubbourn stains should be able to be removed by re-applying creme and scraping with razor blade( using flat side down not corners of razor)
    Nov 25, 2008 | Maytag Kitchen Ranges
    Cleaning stove top
    CERAMIC COOKTOP CLEANER.. its amde specifcally for it.. nothing else is needed. well exept for a good razor blade as well. clean the stove top as per the directions on the cleanre. small circular motions untill dry and then buff them out with the same circular motions, for the stubborn stains, reapply the cleaner and with the razor blade laying flat scrape of the spots, just dont use the points of the razor be sure to lay ot flat.
    May 05, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
    Glass top stove
    you can try a flat blade rasor blade, cerama brite smooth top cleaner and some elbow grease
    Feb 08, 2008 | Frigidaire FEF366 Electric Kitchen Range
    Maytag MER6772 Gemini Electric Kitchen Range Logo
    348 people viewed this question
    Top Maytag Kitchen Ranges Experts
    vince
    Sal DeAngelo
    Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
