Question about Vacuums
Hoover telios 1600 dismantling - Vacuums
    New Friend:
To lynama
Brilliant! Thank you so much. This worked with a Telios 1700, after a little searching for screws, 2 of them in deep holes in the handle, 1 inside at the base of the small spring under the plate switch on the mains switch side. Thanks so much!
Posted on Sep 28, 2017
Remove the 4 screws in the Dust Bag compartment.
Remove the Power button and Cord-rewind botton. This involves using a screwdriver or knife to open/undo a plastic clip located under the bittons near the gril in the top-centre-back of the hover.
When holding the clip back, slide the button towards the bottom of the hover (IE: away from the bag compartment) till it pops out (this can be fiddley).
This will then reveal 4 more screws (within the springs and near the grill).
Then prise the hover open to reveal the motor and power-switch.
Posted on Feb 24, 2013
3 Suggested Answers
SOURCE:
  • 11 Answers
SOURCE: Hoover 1800 telios vacuum cleaner - fuse good but does not switch
there is a button left beside of vaccuum cleaner tube to pull it up & bag will open.
Posted on Mar 04, 2010
  • 190 Answers
SOURCE: telios 2000
This is normally caused by restricted airflow, causing the heat sensor switch to trip. Please make sure the hose and bag are not clogged, verifying you have good suction and airflow to the hose end when you initially turn it on. The heat sensor switch is intended to shut off the motor if sufficient cooling air is not present.
Posted on Mar 11, 2010
How do i open/dismantle a hoover telios vacuum cleaner ?
Hi there! Disassembling the cleaner beyond detaching the nozzle, wand and hose is not recommended. If you need further assistance we recommend taking your cleaner in to a Hoover authorized service center for inspection. Follow the link to locate the nearest service center to you. Service Center Locator
Thanks!
Jun 22, 2014 | Hoover Vacuums
Hoover telios keeps saying bag full when its not
Something is plugged up making it sense there isn't vacuum and saying the bag is full
Jan 31, 2018 | Vacuums
Hoover telios full bag indidcator
could be a hole or torn bag
Jan 02, 2014 | Vacuums
Telios 2000
Mar 09, 2010 | Hoover Vacuums
Mar 03, 2010 | Hoover U6437-900 / U6439-900 Windtunnel...
The hoover keeps switching on and off automatically.
Sounds to me like there is either a loose wiring in the pedal or mains power cord. Check that the plug is secure. Check both filters though - one behind the bag (usually square and slides out) as well as the main exhaust filter at the back between the power on and cord rewind button. I used to own many Telios models but they are known to have cheap shearing cords which can only be replaced by a Hoover repairer. Sometimes the On pedal can be affected as well particularly if it has been stamped on heavily.
Dont forget to rate, ty.
Mar 28, 2009 | Hoover S3330 / S3332 Straight Suction...
I need instructions for H30 bag and filter installation for Hoover S3332 Telios Canister vac. Where can I find the instructions. I have long since misplaced any instructions which came with the vacucum...
go to hoover.com,when the page comes up click on customer service at the top then when that page comes up look on the page for product manuals and info,you will get what you need there.
Dec 06, 2008 | Hoover Vacuums
Telios 1700
if you care to join my premium plan,I will tell you how I fixed it.
Sep 04, 2008 | Hoover Telios Canister Vac Vacuum
Vacuums Logo
247 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
