Question about Panasonic NV-GX7B Mini DV Digital Camcorder
Cant playback tape
I record an event on a different camera from my Panasonic, checked everything was recorded on different camera it was fine. Took the tape out and put it into my Panasonic camera will not play. The tape will fast forward/rewind no problem, even putting the camera trough iMovie it will not play. Keep getting a flashing r in the left hand side of the screen, which after a while stops and says, RO:55
  • Panasonic Master
  • 6,033 Answers
Videos recorded on one camcorder very seldom play back in another, due to the internal codes put on the tape by the original machine.
Posted on Aug 09, 2017
4 Suggested Answers
SOURCE:
  • 76 Answers
SOURCE: Help it's going to fast
Your camera has a capstan servo problem which is more than likely being caused by the capstan motor itself.Nothing you can do youself,would suggest bring to service but reccomend getting estimate before repairing.
Posted on May 23, 2007
  • 33 Answers
SOURCE: Panasonic NVDS60 "no tape error"
Clean the heads - search the Net for 'wet' versus 'dry' tapes.
Posted on Feb 21, 2008
ctf1800
  • 4402 Answers
SOURCE: Help!! No playback!!
First try a cleaning tape, if that doesnt work it most likely the tape path is out of alignment and you will have to send it in for repair.
Posted on Nov 17, 2008
Panasonic HVX200 will not play back tape
Your playback heads might be clogged. I am not sure if this camera with give you a RF warning if your record heads get clogged. Also most professional machines drums are rated at 1000 - 1500 hours before they need to be replaced. If you are at 500 and never cleaned the heads it is time to. Run a cleaning tape a few times.
Dec 16, 2008 | Panasonic AG-HVX200A Mini DV Camcorder
No record or playback
had the same problem, it seems to do fine without a tape in it :so I took the tape in and out a few times and I guess the alighnment was better so it works for Now..So Give it a try
Dec 12, 2008 | Panasonic Palmcorder PV-DV203 Mini DV...
Tapes won't Playback in other deivice
Hello! If the recorded tapes playback ok on the camera and not ok on another devices, you need to readjust the playback on this camera using a tape which playbacks fine on the other devices. This means that is a small difference on the tape transport. So when the supply and takeup post rollers readjusted and the audio and video playback are good, then your camera is fine.
Sep 14, 2008 | Panasonic AG-DVX100A Mini DV Digital...
Playback problems with previous recorded miniDV
Just check your setting and make your camera in default setting try to use the recommended tapes only
May 05, 2008 | Panasonic NV-DS55B Mini DV Digital...
Solid blue lines through Picture on playback mini DV PV-gs19
One possible cause is that normal recording
could not be performed because the heads were
dirty at the time of recording. Clean the heads,
and perform recording and playback again. If
normal playback can be performed, the heads are
clean. Before an important recording, be sure to
conduct a test recording to make sure that normal
recording can be performed.
≥If the heads become dirty soon after cleaning,
the problem may be the tape. If so, try another
cassette.
≥During playback, the picture or sound may be
interrupted momentarily, but this is not a
malfunction of the Camcorder. (One possible
cause is that the playback is interrupted by dirt
or dust that momentarily adheres to the heads.)
Apr 21, 2008 | Panasonic PV-GS150 Mini DV Digital...
No playback
Can you see what is being recorded while recording on the screen?
Dan
Apr 16, 2008 | Panasonic NV-GS17 Mini DV Digital...
Ugh...another problem
First clean the drum, use a soft head cleaning tape, that might not fix it though it seems like one of the posts is off if the cleaning tape doesnt work then it needs a simple alignment.
Dec 24, 2007 | Panasonic Palmcorder PV-GS9 Mini DV...
Sep 19, 2007 | Panasonic NV-DS60 Mini DV Digital...
Audio meltdown!!
Use a head cleaner tape (available on eBay most likely) and clean the recording heads.
Mar 14, 2017 | JVC GRD650US DIGTL VIDCAM 32X ZOOM 16:9...
Pretend record issue
I've had this happen with a Panasonic when I went back out into the cold after going into a warm, humid cafe for lunch. The drum had picked up some condensation, but the condensation detector didn't shut down the camera.
Mar 30, 2007 | Panasonic AG-DVC7 MiniDV Proline Camcorder
Panasonic NV-GX7B Mini DV Digital Camcorder Logo
73 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
