Question about Toshiba Satellite A205-S4777 Notebook
My laptop won't turn on
My toshiba wont start up after i used an aftermarket charger now i have the right one but it still doesn't work? did i fry it? the power and battery light still come when it's plugged in please help!
  • yoyoblahblah Nov 27, 2008
    i have the same problem!!
  • Anonymous Feb 10, 2009
    laptop won't turn on, power and battery lights either help......
  • 157 Answers
Remove the battery and power cord for a few minutes then try again. if that doesnt work, remove the ram and put it back in. there is a good chance you friend something. do you have the power ratings of the aftermarket charger you tried? and did it turn on at all with the aftermarket one?
Posted on Jun 16, 2009
Toshiba nb505 says battery is charging but its not.
By replaced battery, you bought one? Some aftermarket batteries do not work well with your laptop. I would return the battery as defective. Some aftermarket batteries are inexpensive for a reason. Make sure the Cord/charger and the battery are the EXACT same power specs, DC volt and Milliamps, or you may fry components.
Jan 27, 2013 | Toshiba NB505N500BL 1 GB Hard Drive
Frys chargers
You need a genuine Dell charger not an aftermarket one.
If the problem persists with a genuine Dell charger (and if the laptop is out of warranty, otherwise if it is still in warranty, send it back), the problem lies in a faulty voltage controller on the motherboard. Dismantling the laptop and putting a multimeter across the terminals that exit from the charging port will indicate if you are getting a voltage fluctuation through the charger. Aftermarket chargers especially those bought from the far east are very risky as they are often poorly built and badly insulated. Given the problems you describe, I'd be inclined to take it to a reputable repair shop to be on the safe side. NEVER attempt to dismantle the charger though!
Jun 02, 2012 | Dell Inspiron Laptop 1440
Sony laptop dead problem
Could be many things. Let start with a couple of easy ones.1) Unplug charger from computer and outlet, take battery out press power for at least 30 sec. Plug every thing back power on. 2) charger bad won't turn on or charge battery, try diferent charger if don' know how to use a voltmeter. 3) power jack loose or broken. 4) last and worst mother board circuits transitors etc... btw processor, video card or input devices fried. Buy new board from ebay. Don,t fix it. Not worth it. This is Only if laptop gives completely sign of not turning at all. No lights, no hardrive or no working or fan. No signal of life. If couple of lights do turn on it can be the ram or video card, play with ram a bit. Good luck.
Dec 09, 2011 | Computers & Internet
The laptop doesn't start but the charger works.
Take out the battery and connect the charger.
Then try to turn on the computer.
If it works, there is no problem with your computer.
After that insert the battery, plug in your adapter and try turning on once more.
If it doesn't work, you need to get a new battery.
Oct 01, 2011 | Toshiba Satellite Pro L300 Notebook
My PSP won't charge since yesterday when I mistakenly used the charger for my HP notebook,after that when I used the PSP's charger there's no orange light, USB connection doesn't work...
It is possible that when you connected your charger to your laptop, it fried the capacitors in the charger. The best solution would be to take the PSP to gamestop (or like store) and see if they can use a charger to verify that your PSP is still in working condition.
Aug 23, 2011 | Sony PlayStation Portable (PSP) Console
My laptop wont charge when charger is plugged in it will turn on but the computer will stay at 0% battery what is the problem?
HI there, IS it a new Laptop. If yes what you can try is removing the battery and then switching it on.. Once its started just reseat the battery while its on power. You might have to try it 2-3 times if that doesnt help then your battery is broken..
Kind regards
Jul 23, 2011 | Toshiba Satellite L305-S5908 Notebook
Hi, My l305-s5875 Satellite laptop stops working when the power adapter is plugged in and the battery doesn't last more than an hour.
I've seen this happen on several different cases. There could be one of two things that can be going on.
1. Your Charger is bad (but not completely bad). I mean that it took an inverted charge and every time you plug it in, instead it turns off your computer, or drains whatever power you have in it. It can rightfully explain the lowered usage of your battery.
- Sometimes taking a magnetized object (like a screwdriver) can be touched to the tip of the charger and it can reverse the polarity. WARNING!!!! UNPLUG THE CHARGER BEFORE DOING THIS!!! YOU MAY GET YOUR BRAINS FRIED IF YOU DON'T!!!
I would say that maybe 60/40 chance it would work. Otherwise try another charger. Universal chargers can be bought at Compusa.com or Best Buy relatively cheap. As low as $35-45.
2. On the motherboard, there is the plug-in area where the charger goes. It might be experiencing a short. This can usually happen due to faulty wiring, or a fall, bump, hit, or crack to the computer.
On a side note. If your computer is over 1.5 years of age, the battery is going to start lasting less and less. Most Lithium-Ion batteries have a primary lifespan of 2-2.5 years. Some go out before, some go out after. It's all a bell-curve.
Thanks
Please Rate
Jul 08, 2011 | Toshiba Satellite L305-S5875 Notebook
My Toshiba wont turn on. I tried holding the power
Hi there, Your ac adapter is damaged & that's why power does not transfer in your notebook. The capacitor of adapter is burned & that's why the noise started. Thanks & waiting for your feedback.
Feb 19, 2010 | Toshiba Satellite A60 Notebook
I Have an Acer Aspire laptop and evertime you plug in the charger it will show no signs it's connected and the laptop is now out of battery so it will not turn on at all. Even when my charger is plugged...
Please Please Please change your charger right away .. I Got 2 Acer laptop last week and both had same probelm ..if there would be any fluctuations in voltage from your adaptor it will fry up your laptop and you will be in big trouble. Please dont do any experiments on your adapter and change it right away. I Got one laptop last week and customer tried so many angles like you did and fried up his laptop's motheboard already.
Hope you will listen to my suggestion. new charger is not very expensive.
Good Luck !!
Sep 30, 2008 | Computers & Internet
Toshiba Satellite A205-S4777 Notebook Logo
198 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
