Question about Canon PC-920 Black and White Copier
Canon PC-920 toner cartrige stuck in the copier.
I open the cover, and try to pull out the toner cartrige. Nada. Is there a release? The diagram on the copier shows no release.
Open the cover fully 90degrees up to disengage the cartridge motor and it will pull up easily
Posted on Feb 19, 2009
Where are the cartridges located to install new ones?
http://software.canon-europe.com/products/0010476.asp
try to download the manual from the above link and check there.
Howver you can also check it on the lid. instructions are given. This should be very easy as we need to pull out the tray and replace the cartridge. signs and signals are given on the printer itself.
Apr 29, 2011 | Canon iR 2022i Printer
How do i clean my canon pc 921
these isnt toner problem. The toner when is out, gives light pictures.
These is optics problem or drum unit problem.
You need to clean beneath copy glass, clean mirrors on scaner rail assy, and beaneth zoom lens cover.
If the problem still occurs replace drum unit. Beare in mind that you after replacing of drum unit must do initialisation under service mode.
Jul 21, 2010 | Canon PC-920 Black and White Copier
How to install toner cartridge in a Canon 920
On your Canon PC 920, there is a recessed gray latch located on the left side of the machine towards the top front...press upwards on this latch to release the top part of copier (same as removing a misfeed or clearing a paper jam). The copier opens up.....now, located in the top unit, about center, is the drum / toner unit. It has a black plastic handle on it. Grasp this handle and pull towards you...slowly...until it is free of machine (support the rear of the unit with your other hand) Open new cartridge (unit) and install in reverse order (there should be instructions with the new cartridge) The copier has rails that the cartridge mounts on. Another note, before installing....gently shift the cartridge from side to side.....this distributes the toner evenly (again, covered in the installation instructions packed with the cartridge) There is a tab that needs to be removed to allow the toner to get where it needs to go for copying....attatched to this tab is a strip of plastic, pull all the way out. I have a PC 940...it uses the same cartridge.
Mar 24, 2010 | Canon Office Equipment & Supplies
We have been sent a toner cartridge for our ir3300 but despite directions on the side of the box it does not appear to fit
Canon toner type GPR-6, correct? Open the front cover. Rotate lever to release toner/developer unit. Pull the unit straight out until it stops. Insert new cartridge to line up with top of toner/developer unit at a slight angle (lower at back) Once the cartridge stops at the rear (I would hold the toner/developer unit with one hand while inserting the cartridge) then lower the front end of toner cartridge down on top of the unit.....press down until toner cart. clicks into place. You will know because a tab pops out the front with clear plastic attatched. Pull the tab to release toner and release top of toner/dev. unit. Keep pulling until it stops. Wait about 7 seconds, now tap on toner cartridge to release all loose toner (don't forget to shake toner before opening) After about 15 seconds, toner should be fully loaded. Now push top cover of toner/developer unit back in until it latches, you will know because the empty cartridge releases from the unit. Now remove empty cartridge, reinsert unit, turn latch handle and close front cover.
Oct 07, 2009 | Canon Office Equipment & Supplies
How to add toner
Open the front cover. Towards the right side about half way down, there is a plastic lever. This will rotate to release the Developer/Toner Unit away from the Drum Unit. Pull the Unit outwards...it should stop before coming all the way out (unless someone has removed the stopper) Please use the correct type of Canon Toner as it fits on top of the Unit and unlatches Toner cover to add the toner. (Canon Type GPR-2). The instructions should be in picture format on inside of front cover.
Jun 10, 2009 | Canon ImageRUNNER 330s Copier
PC 920 Faded sides
hi
try this open the copier and remove Toner Cartridges and shake side ways for 5 times and try to make copy,if faded gone its better to replace Toner Cartridges for better copy quality
Dec 12, 2008 | Canon PC-940 Black and White Copier
Savin Copier 3515
Hmmm.. try this
  1. Open the Front Cover
  2. Lift the large green handle up to its full extent
  3. Press and hold down the green lever to the left of the green handle
  4. Use the green handle to pull out the Toner Tray slightly then release the green lever
  5. Pull out the Toner Tray to its full extent
  6. Push the toner bottle towards the front of the black housing where the green lever is located
  7. Push the green lever down while continuing to hold the toner bottle towards it.
  8. Slide the whole assembly back into the device until it clicks into place
  9. Close the Front Cover
  10. The device should now attempt to Add Toner
  11. If the Add Toner indicator light does not go out repeat
Oct 31, 2008 | Microsoft Office 2003 Basic Edition...
Copies are blurred in center but good quality on both ends
change your toner cartrige , your can change the upper hivoltage charger wire on the cartridge old cartridge.
thanks
Sep 30, 2008 | Canon PC-920 Black and White Copier
Canon PC-920 Black and White Copier Logo
136 people viewed this question
old marine
old marine
Corne Viljoen
