Question about Philips 55PW9363 55" Rear Projection HDTV-Ready Television
Philips 55pw9363 factory default settings
Hi, Is there any way to set the Philips back to factory default settings for geometry? Reason for asking is that I fixed overscan but now on the left side of the screen the convergence is messed up. the red doesnt line up. it is at a diagnol to the other crosshair. this is only the case on the left side of the tv, extreme left. thanks
    Genius:
  • 1,694 Answers
Yes,there is almost always a way! you will need the CD ROM literature for your model--it will list the normal range of settings. My reserved question is what caused the overscan and why did you decide to go in the servicer menu to "fix" the problem???? You may have some convergence issue,also.
Posted on Sep 26, 2007
What are the default geometry values for 480P and 1080i FULL modes?
If you have the model listed have fun----Geometry values are depicted in the Convergence section---the grid of GREEN lines determines geometry and red and blue are then adjusted to the Green.
Primitive: Set had at one time two overlays available--clear plastic you attached to screen to line the that Green grid up against---one for 480 and one for 1080.
Once the geometry is set (best possible) you must align convergence and save it in both the modes one at a time.
By current standards a Fred Flintstone system--but in its day a real pain as alignment can take many hours with the correct remote via the tech menu for convergence.
Apr 27, 2012 | Philips 60PW9363 60" Rear Projection...
Watch movies from computer to tv
look on the back or sides of the unit. it should have a hdmi cable hookup, it will look like a monitor input, then you have to make sure you set the tv input to that. then you have to set your laptop to add another monitor to be able to use it.
Mar 20, 2009 | Philips 55PW9363 55" Rear Projection...
Pink and greenish lines creating a double picture
with your remote go to your menu and find convergence. Follow the instructions to auto set convergence. if that don't fix it the problem convergence panel if bad.
Mar 15, 2009 | Philips 55PW9363 55" Rear Projection...
Philips 55PW9363 need convergence grid dimensions
You may not need a template as long as the geometry has not been totally lost or corrupted. How is the image in red and blue? If any of the three convergence/CRTs has good geometry, you can align the others to it. You can simply cover over any CRT whose image you wish to block out while you are aligning the others.
Feb 15, 2009 | Philips 55PW9363 55" Rear Projection...
Dptv335 Philips 55PW9363
i would send the board in for repair... ptscorp.com
Feb 13, 2008 | Philips 55PW9363 55" Rear Projection...
Philips 55pw9363 next problem
Have you change the RGB setting to Y/Yb/Yr?
You can change this option in the menu - install then go all the way to the bottom
Nov 17, 2007 | Philips 55PW9363 55" Rear Projection...
Philips 55PW9363
Hi! ronogre,
This set has a defective SMALL SIGNAL BOARD.
Toprol
Jul 31, 2007 | Philips 55PW9363 55" Rear Projection...
Geometry settings all wrong
I wish I could help you but you will more than likely have to take your set to an authorized service center. Philips doesn't like to send service manuals to anyone except their service centers. Stargazer
Feb 20, 2007 | Philips Magnavox 32PS55S 32" TV
Philips 55PW9363 Service Menu - Geometry settings help, picture shifting at times???
If you are doing the labor you should wait and replace the new part and while you are at it check for loose conections in the horizontal drive circuit since all symptoms might be related,but they are doing all the work they should address all the problems you have,settings in the service menu dont just change on their own and are adjusted only when a major comp[onent has been change like the convergence.
Oct 03, 2006 | Philips 55PW9363 55" Rear Projection...
Philips 55PW9363 55" Rear Projection HDTV-Ready Television Logo
164 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
