Question about Kenwood DDX-6019 Car DVD Player
Mecha Erro I used to get this issue only once in a blue moon, where i would eject a CD and then the mechanism would not close after opening. It is an easy thing to fix, just give it a light push to help it on its way back up. Now, I am having an issue quite often where i will eject a cd and even after the cd is out of the player, it will keep trying to eject. If i try and insert a cd it will just immediately reject it. Then if i hit the eject button i get a mecha error. After messing around for about 5-10 minutes i am able to put a cd and resume normal functionality, but this is really annoying and I dont know what is causing this error.
    President:
  • 3,130 Answers
The problem could be a belt if the unit uses one for the CD try, a bad motor or the motor drive servo circuit. There are no user replaceable parts inside this unit as it is solid state and unfortanatly, there is no quick fix for this, except, taking the unit out of the vehicle and bench testing it. Im afraid you will need to seek out the assistance of an authorized servicer. Good Luck PS please do not forget to rate this thread
Posted on Oct 17, 2006
I have a sony computer, the model where every thing is built in behind the screen. a CD is stuck inside and i cannot remove. anyone have any knowledge on what to do to remove same?
The CD, DVD or BD drive tray may not open when trying to eject a disc. This can occur if there is a mechanical failure, or if there is a disk stuck in the drive.
Please follow the following steps to resolve this issue:
  1. Because some applications can prevent the drive tray from opening, close all open applications.
    NOTE: If the Roxio DirectCD software is running, eject the CD using the Roxio DirectCD software.
  2. Attempt to eject the drive tray using the eject command of the operating system.
  3. Restart the computer to the BIOS by continuously tapping the F2 key on startup and, while in the computer BIOS, press the EJECT button on the computer.
    NOTE: If the drive tray ejects in BIOS, but not in the operating system, reinstall the CD, DVD drive.
Sep 16, 2010 | Sony VAIO VGC-RB40 PC Desktop
Mecha error
Otherwise known as a mechanical error. The CD will not eject/insert without assistance. I have found a workaround for this, but have yet to fix it. If you take another CD and hold it inside the CD slot just beneath the ejecting CD, it will help to guide the CD out of the track. I also have to use a similar method to push the disc into the track as well.
Aug 14, 2009 | Kenwood DDX-6019 Car DVD Player
I lost the driver
It does not look like it burns CDs. Here is the Features of the LTN-486S.
  • 48x CD-ROM with Pure-CAV Technology.
  • E-IDE Interface, support all PIO, MW-DMA, Ultra DMA-33 modes.
  • Support Power Saving Function.
  • Support High Speed Digital Audio Extraction ( DAE ).
  • Support High Speed VCD Data Extraction.
  • Support Plug & Play; Emergency Manual Eject.
  • High Speed CD-Audio Playback Technology to Improve Audio Playability.
  • Access all format CD, CD-R, CD-RW Title & Disc ( support up to 99 mins ).Easy-TrayR Design for both horizontally & vertically use.
  • Gear-Driven Tray Loading Mechanism to improve reliability.ABS Auto Balance System ( 486, 485 ) Mecha to Reduce Vibration R Noise.
  • WSSR Wire Suspension System ( 483 ) Mecha to Reduce Vibration & Noise.
  • Jul 01, 2009 | Lite On (LTN486S) Internal 48x CD-ROM...
    Open/close doesn't work
    When you press Eject CD button, do you see CD display blinks as if its preparing to be ejected? If its true then eject switch is working and cd mechanism is stuck, requires service. Also check loading belt in mechanism.
    And if unit shows no response on pressing CD Eject button then switch is bad, replace it.
    Jun 30, 2009 | Aiwa NSX-A115 Shelf System
    CD drawer will not open or close
    Hi, The CD drawer mechanism needs a new belt. They have a motor that drives the tray mechanism, and there's a small belt that drives the main gear so that pushing the drawer in gently to close it doesn't damage anything. However, once that belt breaks/wears out, the drawer will stay in whatever position it was last in.
    Jul 24, 2008 | Audio Players & Recorders
    No Play No Eject
    COMMON PROBLEM
    OPEN IT UP AND REMOVE YOUR DISC AND THEN THROW THE PLAYER AS FAR AS YOU CAN.
    Jan 26, 2008 | Nakamichi MB-70 6-Disc CD Changer
    Shelf cds is blocked SONY CMT-HP7
    To get the cds to play, and 5 to eject, you can try taking off the sides of the consul and using compressed air. As for the shelf problem, I'm not really sure.
    Nov 09, 2007 | Sony CMT-HP7 CD Shelf System
    Mecha error
    I had the same problem. My unit would not eject CDs. I was able to fix it by hitting the reset button. That restarted the whole unit and reset all the settings as well, but now I'm not having any issues with ejecting CDs.
    Oct 22, 2007 | Kenwood Excelon DDX-7015 Car DVD Player
    Mecha error
    Mecha error is a Mechanical Error. This means that this is an actual physical malfunction of the unit. Sometimes pressing the reset button can realign some of the mechanics but most often this is a problem that requires to be serviced.
    Feb 03, 2007 | Kenwood KVT-717DVD Car DVD Player
    Disc wont change....or play....
    e-mecha appears to be nothing more than an interlock. hitting reset clears the interlock, but if the problem has not been fixed, then the interlock will trip again, preventing operation. Determine why the radio goes into mechanical failure to begin with. Once fixed, the interlocks will be made and the radio will play. There are a number of events that all have to complete sucessfully including feedback from sensors to maintain the e-mecha interlock. One of your sensors is not being made, either by a sensor problem or by a mechanical issue that prevents the sensor from tripping. -Steve
    Oct 22, 2006 | Nakamichi MB-100 6-Disc CD Changer
    Kenwood DDX-6019 Car DVD Player Logo
    385 people viewed this question
    Top Kenwood Car Audio & Video Experts
    xxxxxx xxx
    Marvin
    Marvin
    Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
