Question about Philips 55PW9363 55" Rear Projection HDTV-Ready Television
Can APAC be disabled?
Hi, i was wondering if the APAC option be disabled on the philips? My set goes nuts all the time shifting the image and its annoying. Im watching tv and all of sudden the image shifts. thanks.
Yes, Turn off the convergance option.
Posted on Jun 02, 2007
CF letters on screen
Philips sets use a four digit code to control the v-chip. The override code for Philip sets is 0711, although it may say "Incorrect code" the first time to trick you. If "Incorrect code" is displayed, simply enter 0711 again. To use it hit the MENU key to get to the menus. Go up or down until you reach AUTOLOCK or SMARTLOCK, depending on the model, and push the "right arrow" key on the remote. Enter the override code, and enter it a second time if it says it is incorrect.
Once in the AUTOLOCK or SMARTLOCK menu, go to BLOCK, and push the "right arrow" key. Go to BLOCKING OPTIONS and press the "right arrow" key. Go to MASTER DISABLE and press the "right arrow" key so that it says "MASTER DISABLE ON". The v-chip is now reset.
Sep 26, 2012 | Philips 32PFL3403 32-inch High Definition...
Hi my TV has a picture of a padlock and i cant unlock it tried to use remote it wont work it is a magnavox 29inch
hi,
For unlocking you tv you have to reset its v-chip. Do the following for the same.
ok
Apr 11, 2011 | Philips Magnavox 20MT133S 20" TV
Unlock code for 3256
Hello
OK.
Feb 10, 2011 | Philips Televison & Video
What is the code for auto lock?
Hello
If your Philips TV is locked, just try this.
Philips sets use a four digit code to control the v-chip. The override code for Philips sets is 0711, although it may say "Incorrect code" the first time to trick you. If "Incorrect code" is displayed, simply enter 0711 again. To use it hit the MENU key to get to the menus. Go up or down until you reach AUTOLOCK or SMARTLOCK, depending on the model, and push the "right arrow" key on the remote. Enter the override code, and enter it a second time if it says it is incorrect.
Ok.
Dec 11, 2010 | Philips 25PS40S 25" TV
Some sites the scroll down speed is really slow. It seems like text pages are ok and ones with images really slows the scroll responce down. Any ideas??? Thanks!!
Sounds like you are having problems with your Internet connection speed.You could try some of these tips..
  • Step 1 Click Start > Control Panel > Network and Internet Connections.
    Select "Internet Options."
    Under Check for newer versions of stored pages, click "Automatically." Under browsing history, click "Settings."
    If you're using dial-up, set the number under Disk Space to Use to between 250 and 1024 megabytes (MB). If you're using a DSL or cable connection, set it between 50 and 75 MB. Click "OK."
  • Step 2 Select "Delete" under Browsing history.
    Click "Delete files..." under Temporary Internet Files to clear your browser cache.
    Click "Delete cookies..." to remove all cookies from your hard drive.
  • Step 3 Disable any browser add-ons you don't need. In Internet Options, click "Programs." Click "Add-ons currently loaded in Internet Explorer." Select the name of the add-on you don't want to load, and select "Disable" under Settings at the bottom of the dialogue box. Avoid deleting ActiveX controls as this will most likely cause the browser to prompt you each time you encounter content on the web, such as Flash animations, that use that control.
  • Step 4 Switch to a faster browser. While Internet Explorer is the most popular browser, it often causes pages to load slowly. Download a free browser such as Firefox, Opera or Chrome to get a quick speed boost to your browsing.
  • Step 5 Disable images in your browser. To disable images in Internet Explorer, open Internet Options and click the "Advanced" tab. Scroll down to "Multimedia" and uncheck "Show Pictures."
    To disable them in Firefox, click Tools > Options in your browser window and select "Content." Uncheck the box beside "Load images automatically."
    To disable images in Opera, open the arrow beside the camera icon at the bottom of your browser, and select "No images."
    To browse with Google Chrome without images, right click on the Chrome shortcut and place the switch "-disable-images" without quotes after the last quotation mark in the path of the file.
  • Step 6 Disable active content if you're still experiencing a problem with your browsing speed. Return to the "Advanced" tab in Internet Options. Uncheck the boxes beside "Play animations in webpages" and "Play sounds in webpages."
  • Aug 11, 2010 | Dell SP2309W 23-Inch LCD Widescreen...
    My Philips TV model 37PFL9604H1 was used in the
    Close, then you should go in the image settings and change the main setting from Store to Home
    Jul 06, 2010 | Philips Televison & Video
    Hello i was writing an email and held down the shift key for to long and an box came up with three options so i just pushed cancelled and now the keyboard is not working properly.capslock is back to front....
    It seems your sticky keys got turned on somehow. Press shift key five times and it should turn off the sticky keys feature and fix your problem.
    You might be wondering what is this feature all about, so here goes:
    StickyKeys is an accessibility feature to aid users who have physical disabilities, but it is also used by others as a means to reduce RSI (or a syndrome called the Emacs Pinky). It essentially serializes keystrokes instead of pressing multiple keys at a time: StickyKeys allows the user to press a modifier key, such as Shift, Ctrl, Alt, or the Windows key, and have it remain active until another key is pressed.
    Apr 19, 2010 | Acer Audio Players & Recorders
    I downloaded some pictures to my school computer and now my camera won't take any pictures. Message is Memory card write protected.
    SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
    If that doesn't work, try another card.
    Feb 26, 2010 | Nikon Coolpix 4500 Digital Camera
    Can't type anything without weird things happening the \'p\' prints,
    hi, check that Sticky-keys arent turned on.
    to toggle Sticky-keys on and off, press the shift key 5 times fast, then either Disable the sticky-keys tickbox, or click Settings for more configuration settings.
    when sticky-keys are enabled, you can press shift and release, and the shift key is still enabled. this also goes for Alt, and CTRL.
    so if it is enabled, pressing P will attempt to be Ctrl-P - which is print.
    Sep 10, 2009 | Acer NSK8458AN Keyboard
    Philips 55PW9363 Service Menu - Geometry settings help, picture shifting at times???
    If you are doing the labor you should wait and replace the new part and while you are at it check for loose conections in the horizontal drive circuit since all symptoms might be related,but they are doing all the work they should address all the problems you have,settings in the service menu dont just change on their own and are adjusted only when a major comp[onent has been change like the convergence.
    Oct 03, 2006 | Philips 55PW9363 55" Rear Projection...
    Philips 55PW9363 55" Rear Projection HDTV-Ready Television Logo
    32 people viewed this question
    Top Philips Televison & Video Experts
    matt martin
    matt martin
    Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
