Question about Canon CanoScan LiDE 25 Flatbed Scanner
Jes?s I need you the program installing the software of scanner now please
  • 435 Answers
Please click this link to download the software:
CanoScan Toolbox Ver. 4.9.3.2 (Windows Vista/Vista64/XP/2000/Me/98)
Thank you
Posted on Jan 07, 2009
I cannot get the scanner buttons to work. Nothing is showing up on my system tray to control the scanner buttons. The scanner works fine with software control thru Paperport. I have reinstalled One...
This is usually a symptom of either the basic driver being installed (not the OneTouch 4 software), the destinations for the buttons not being set in the OneTouch 4 software correctly or the monitoring program not being active. (For the X7600, the OneTouch 4 software comes with PaperPort programmed as the default destination for the scan button. If that setting got changed, it could cause the problem.)
The drivers and software are available here: http://www.xeroxscanners.com/en/us/products/drivers.asp?PN=X7600 . Scroll down for the manuals. If you have the basic Xerox driver installed, uninstall it (remove the scanner from the Device list by right clicking on it and choosing uninstall) then disconnect the data cable. Finally restart the computer and then install the One Touch 4 software.
If you have the OneTouch 4 software installed, check if the program is set to run on startup.
Click Start > Run then type "msconfig" (without the quotes) in the Open box. Click OK. Choose the startup tab and look for the Xerox software. Make sure the box is checked. Click Apply after changing the settings and restart the computer.
Next, launch the program (Start > All Programs) and try to launch a scan from the One Touch button panel on the computer. Adjust the settings if needed in the Configuration section of the software (see the manual for screen shots).
I hope this helps.
Mar 29, 2011 | Xerox 7600 Flatbed Scanner
I have never used a scanner please explain
If you are just installing the scanner, follow the setup instructions that came with it, and make sure the software gets installed. If it is already installed, then there should be a program in the computer that can start the scanner and get the image of whatever is on the scanner. Look where the scanner programs are at(usually this is a folder on the start menu). Also, there may be a scan button on the scanner itself. Pushing this button will start a scan and send the image to the computer.(the scanner program should start)
Feb 25, 2010 | HP Office Equipment & Supplies
I WANT TO USE THE SCANNER BUT, I DON'T NOW HOW, It go to the printer all the time, could you please help me ? I have the EPSOM STYLUS BX300F PROFESSIONAL, PRINTER,SCANNER,FAX,PHOTOCOPIER.
Basically, you can use the scanner in two ways. Please open the scanner cover and place the document or image you want to scan face down.
1. Press the SCAN button (color button = color scanning, black button = monochrome scanning). then your scanner will scan the document or image in the scanner tray.
2. Go to the scanner program installed in your computer when you installed the printer. Open it and then click the command button SCAN.
Note: Make sure that you installed the Scanner software when you installed the printer. Without the software, your scanner will not work. Please reinstall the printer including the scanner software.
Feb 06, 2010 | Epson Stylus Multifunction Inkjet Printer/...
HP Scanjet G3010 RE-INSTALL PROBLEM (WIN/XP)
hi hots2,
i ve been solving ur problem through live chat... when my power got cut.... pls respond to my omments to the chat.... u can go to ur "my profile" page and clik on the chat.... the entire transcript will be available.... though we might not be able to chat... we might still respond through comments...
thank you
May 04, 2009 | HP Scanjet G3010 Flatbed Scanner
CanoScan Lide 25 scanner
Why don't you try the CANON site? The have all the drivers available:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=351&modelid=11463
Mar 03, 2009 | Canon CanoScan LiDE 25 Flatbed Scanner
http://www.canon.com.au/products/scanners/scanners_low_medium_volume/canoscanlide25.aspx try this should give you what you need
Feb 09, 2009 | Canon CanoScan LiDE 25 Flatbed Scanner
Install CanoScan Lide 25 scanner via internet; lost CD installer
just want to know how can i install my scanner, i lost my cd i can't use my scanner since i bought this last july 2008. please help me to find the site to download the program of installing my scannerInstall CanoScan Lide 25 scanner via internet;
Thanks very much
Nono Setijono
Nov 05, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
Drivers and software are available at this link. Be sure and download and install both the driver and the Toolbox program (under Software)>
Oct 15, 2008 | Canon CanoScan N670U Flatbed Scanner
Install program my acer scan2web 3300u
i want my scanner install software so please send me install software
thaks
Dec 25, 2007 | Acer Scan to Web 3300U Flatbed Scanner
Canon CanoScan LiDE 25 Flatbed Scanner Logo
95 people viewed this question
old marine
old marine
