My Intertherm, electric ignition furnace will hum and hum but not click on. There are two yello flashing lights until we reset it by turning off the gas and turning down the thermostat. The unit resets itself and I get a steady red light when its working. Is this a pressure switch issue?
  • 1,420 Answers
That blinking yellow light is an error code. If you look behind the main cover there will be a wiring diagram and error code chart. This will give you an idea what the problem is.
Posted on Nov 07, 2008
Intertherm gas furnace in mobile home..igniter comes on then nothing tries to fire byrners but nothing
by igniter I assume you mean the thermocoupler. are you turning the control button to run after you light the pilot light? Normally when those furnaces quit it is the thermocoupler that has quit. Get a new one and leave it in the furnace compartment as a spare.
Jan 06, 2015 | Intertherm Heating & Cooling
WHEN I TURN ON THE FURNACE ALL IT DOES IS HUM NOTHING ELSE
This is a house furnace with ducts?
If so if the pilot light on?
Do the burners light?
Do you hear a clicking?
There is a reset button on the top usually between two screws.
On mine the ignition solenoid went out, had to order online. This is the thing that clicks. If it clicks for a while but the burners do not light that is the problem. Mine would click for five minutes before lighting the burners.
I hope this helps.
Oct 21, 2013 | Heating & Cooling
Intertherm feh 015ha
either the heat strips, fusible links on elements or sequencers.
Sep 21, 2013 | Intertherm E3EB010H Electric Furnac
Intertherm furnace burner comes on, but blower does not. If I turn thermostat off then back on until it clicks the fan will then come on. It does not do this all of the time, just now and then.
Furnace burner and heat element are not the same. I think the fan time delay, a sensor that turns the fan on when this sensor senses heat, is shot and needs replacing, for a furnace type heat ( gas heat)
Aug 08, 2017 | Intertherm E3EB010H Electric Furnac
Intertherm furnace model # MMHB-070ABHR-06 red light blinks two times
Number of flashes mean different things for diff models. The meanings of those flashes should be posted somewhere on the unit; usually inside front of the bottom service panel. Though you can't truly diagnose a problem by number of flashes they can give you an idea of where to look for a problem. There are a ton of videos and how-to's about furnaces on youtube by real service techs. Most modern furnaces have basically the same set-up and features so don't worry about your paticular brand; but of course that would be the best place to start looking. You could start here to familiarize yourself with your brand of furnace:
http://www.youtube.com/results?search_query=Intertherm+Gas+Furnace+&oq=Intertherm+Gas+Furnace+&gs_l=youtube.12...62316.62316.0.63907.1.1.0.0.0.0.202.202.2-1.1.0...0.0...1ac.Ko9QBdxK6OM
And then here:
http://www.youtube.com/results?search_query=gas+furnace+won%27t+light&oq=gas+furnace+won%27t+light&gs_l=youtube-reduced.3..0.5619.10061.0.11544.11.5.0.6.6.1.741.1982.0j1j2j5-1j1.5.0...0.0...1ac.1.5-0zJyxNMEo
Hope this helps.
Dec 21, 2012 | Heating & Cooling
Problem with Goodman furnace electric ignition
Power is there, or no lights would blink. Steady blinking or flashing three times, stop, three times Etc
Nov 23, 2011 | Goodman Heating & Cooling
Furnace has does not ignite flame
how often do you replace your filter?
On the limit switch that protects your unit when it gets to hot the number one reason is dirty filter.
The pressure switch is located in the upper side of cabinet has a rubber hose connected to it. They very rarely go out though. So find your vent fan the first fan that comes on and follow the rubber hose to the switch.
Feb 09, 2009 | Intertherm P3RA-048K Air Conditioner
Weak flame in intertherm furnace
Ok, so we can rule out the ignitor. (standing pilot systems can develop problems that will cause such symptoms.)
Check the gas pressure, make sure you are getting 11 to 14 PSI.
You need that after the regulator all the way to the manifold.
Also check for cracks in the heat exchanger, causing the wind from the blower to distort the flame pattern enough to cause improper contact with the flame sensor.
Make sure the burners and flame channels are clean of rust, and dibri build up, allowing the flame to properly contact the sensors.
Jan 18, 2009 | Intertherm P3RA-048K Air Conditioner
Intertherm model e3eb020h electric furnace won't start just hums
Check fuses. one may be blown, and the other one not, Therefore you are getting only 110V to a 220v circuit.
Dec 03, 2008 | Intertherm Heating & Cooling
Heating & Cooling Logo
301 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
