Question about JVC RV-B55 Cassette/CD Boombox
Power On Issue
The problem I have is when I turn off the boombox it will not come back on unless I unplug the power from it first. Then it will let me turn it back on. When I do turn it off the light on the screen is still on showing the clock but it will not power back on by pushing the power button. The power cord has to be pulled out before you can push the power button to make it come back on. For now I just leave it on all the time. Any help or suggestions would be great. Thanks
  • 1 more comment
  • ArmyUSMA78 Oct 20, 2008
    I have the exact same problem. It happens with both AC and DC (battery) power. There should be a way to "reset" the unit but I have not seen a posting to that effect. I agree with the others - it's very frustrating. So far help from JVC has no been "helpful."
  • Anonymous Dec 10, 2008
    Same here,still looking for a solution
  • dpicc Dec 29, 2008
    need help too! I lost my user manual...does anyone have a pdf copy they can share?
    New Friend:
My boom bladder dose not turn off stand by wats the problem
Posted on May 13, 2013
  • Jon Witton May 13, 2013
    The stand by will not turn off wow even come on
Me too. Do anyone know where the backup-batteries is placed in the boombox?
Posted on Nov 08, 2009
Had someone tried to put in new backup-batteries? (3x AA)
Posted on Aug 04, 2008
I have the same damn ERROR-.- . I didn't find anywhere an answer. -.-
Posted on Jul 15, 2008
Sony stereo protect mode
If "PROTECT" appears on the display: Immediately unplug the power cord, and check if anything blocking the ventilation holes on the back of the system after "PROTECT" disappears. After you have checked the ventilation holes and found to be all right, reconnect the power cord, and turn on the system. If the issue persists, contact your nearest Sony dealer.
The above is from the manual at http://www.docs.sony.com/release/MHCEC909IP.pdf
May 24, 2013 | Sony Mhcec909ip Mhc-ec909ip Mini Hi-fi...
Ikasu dvd boombox -no sound
If you have power to the unit but no sound, chances are the audio output ic has shorted causing a load, turn volume down, power off, remove speaker wires, power on, if standby light stays on audio output ic needs to be changed. If however the standby light changes or goes off it indicates a short in the wires or speaker issue, hook up one at a time to identify the problem one.
Feb 16, 2012 | Audio Players & Recorders
Unit will not work on AC power but does on batteries. Power outlet is good, power cord is good. Are there any external resets on the unit.
Not unless you see something labelled so - but power supplies don't tend to work like that!
It's either power supply circuitry thats died but it may have a replaceable long life internal fuse which a workshop (repairer) can replace, and should be real cheap to do.
Otherwise, for indoor use, to save on batteries, get a universal AC to DC adaptor. I think you'll find it has a DC IN socket somewhere about it (back or sides)
Sep 21, 2011 | Sony Xplod CD/Cassette Boombox with AM/FM...
When my receiver is plugged into my boom box, I get a display reading "check cradle for power"
It's not receiving enough power from the boombox so the voltage drops too low for the receiver to function properly. Check the cradle connector for bent or pressed pins and the power source of the box for proper functioning: measure the voltage it delivers and the status of its components, especially the filtering capacitors.
Jul 04, 2011 | Delphi Roady XT XM Radio Receiver
My Emerson 5812 Boombox will not turn on all of a sudden. I just bought it a couple months ago and it will not power on.
If its still under guarantee then take it back to the shop if you have the receipt. If not then it could be something as simple as a little glass fuse inside the boombox.
May 21, 2010 | Emerson (PD5812) Radio/CD Boombox
NB 90 will not power on after turning off unless i unplug it.
yes a little groove under to big batteries. AA i think
May 14, 2010 | JVC RV-B90 Boombox
My Lexmark x9350 only turns on and off if I plug and unplug...
This, probably, is a power issue on the printer. Unplug the printer from the computer. Unplug the power supply from the printer (it's the black box behind the printer where the power cord is attached). Try not to use any power strips or extensions for the power cord. If possible, plug the power cord straight to the wall outlet. With the power cord plugged in straight to the power outlet, plug the power supply back in the printer. That should refresh the printer. When everything's powered on, plug printer to computer. Hope this helps. If you need more assistance, leave a comment and I'll get back to it. Thanks.
May 13, 2010 | Lexmark X9350 All-In-One InkJet Printer
Hi...every time I turn off my RV-B90 I have to unplug it and plug it back in before I can turn it back on. Any fix for this?
This was happening on mine and here is how i fixed it.
I would hear clicking from the cassette area when i first turned it on, and the door would be jammed and i had to brute force it open. The kaboom would not shut down by using the power button or remote. Nothing!
I found the tape mechanism was getting jammed out of place because of all the gunk so I cleaned the inside with isopropyl alcohol and a q-tip then moved the mechanisms back and forth with my finger on the bottom where the tape goes over the sensor.
I powered it up with no clicking and was able to shut it off with the power button and remote again. My power issues had to do with the tape player whodathunkit.
Apr 19, 2010 | JVC RV-B90 Boombox
Overall Problem - Panasonic RX-ED707 won't work properly at all
only 1 reason for that faults :
there is a flat connects the top panel which has all the controls with the other circutes in the stereo...
so you have to open it and care for the cd unit it damage easily then check the flat for loseness or cuts
it happened to me also and that works perfectly
good luck
Nov 14, 2007 | Panasonic RX-ED707 Boombox
JVC RV-B55 Cassette/CD Boombox Logo
538 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
