Question about Samsung T809 Cellular Phone
T809 speaker problem
Hi - My T809 was dropped in a glass of water which was almost empty (mouthpeice Downwards). I think the water still entered the speaker because after that I was just able to hear it, but my voice was not reaching the other party. The water indicator is also still white and it didnt turned Red. After a day, it was better, atleast my voice was reaching, but it was very bleak. So I kept my phone in my car for about 2-3 hours in sun and after that it worked perfectly fine. but again after a day or two, the quality deteriorated. How long do I have to keep my phine in Sun so that it clears out. Any help appreciated.
Thanks
ppr78
  • 174 Answers
You can take the battery and the back off the device and place in completely submerged in a bag of white rice and leave it in there for 1 to 2 days this will help absorb the moisture, this should fix it if the water did not damage the circut boards if the water damaged the circut boards then the device is fried
Posted on Apr 04, 2010
I dropped my phone in a glass of water.
Remove the batteries, if possible.
Put the telephone into a bag of raw, dry rice.
Leave it for a few days.
See if it works.
Dec 15, 2013 | Televison & Video
I was wondering where the water goes or if it carrys any water at all. it is a window air conditionor
On a window a/c unit, the water drips outside, so be sure the unit tilts downwards as it goes out. The water is from condensation, sometimes you will get lots, other times almost nothing, both normal, related to actual relative humidity. The water forms due to temperature, it forms exactly like water on the outside of a glass of ice water...
Jul 06, 2011 | Fedders A6P09S2A Air Conditioner
Hi, victa 550 powercut, 10 yrs plus old, problem apart from old and used is it starts runs and dies then just when you think its gonna stop it revs up again and dies and revs and dies and revs and...
Take apart the carb and give it good cleaning maybe even but a rebuild kit if available. also disconnect tank hose from carb and empty tank into clear glass jar. Sounds like there might be some water in your gas. In the glass jar you will see a clear line of liquid at the bottom that would be water, even just a little will give these similar symptoms. Good Luck....
Mar 09, 2011 | Garden
Washer does not empty water
Hi!
This usually happens if the drain pip is clogged...
There are two types of drain 1. By garvity 2. By Pump....
If its by gravity please ensure that the entire drain pipe is facing downwards with NO upward bend or loop as this would stop the water from flowing out entirely ..hence leaving the clothes wet.
If its by the pump... again check if the outlet end is not clogged or stuck too close to the wall or any other object....
Try and see if you can hear the pump motor.. may be that the pump is not working till all the water is pumped out.
Regards
Berry
Feb 15, 2010 | Whirlpool Calypso GVM9959K Top Load Washer
Sears side by side fridge model# 10652542101. ice won't work but water works fine. have heard that icemaker screen may be the issue, but would like a manual so i can clean or repair it. sears has no...
There is no "screen". Most of these units have dual water valve on rear of unit (two valves on one mounting bracket) located on lower right side of unit. Follow inlet line to where it terminates, you will see water valve. First thing to determine, is the ice maker making ice and not dropping it thru door, or no ice dropping into bucket. Stick finger into I/M and see if you feel ice or if it is empty. If empty (no ice) chance are that I/M is problem, not water valve. Check I/M by pouring water from small glass into I/M,let sit for 2-3 hours and see if it drops ice into bucket, if it does, possible bad water valve, if it doesn't, bad I/M. Those are standard I/M & water valves, available at most applianc parts stores including sears.
Sep 23, 2009 | Freezers
Paging feed back
Or move the speakers that are next to the phones doing the paging.
It feeds back because the speakers are loud, and are blowing the sound into the mouthpeice of the phone that is paging.....
May 26, 2009 | Avaya Lucent Partner 616 Phone
TOUCH CONTROL HOB (SCHOTT CERAM) GLASS CRACKED
Hi. Yes you can buy a new glass. Most of the come with frame top now. If you get me the model # I can look this up for you and get you an idea on cost.
Vic
May 18, 2009 | Cooktops
REPLACING LCD FOR T809 SAMSUNG
all sliders are pretty match the same, try this video as parting guide :
http://www.youtube.com/watch?v=XUB2EZRsGfU
or try to google service manual for t809
be very carefull with flex cable and goodluck
Jul 12, 2008 | Samsung T809 Cellular Phone
Samsung T809, screen display is dull(week)
unfortunately, the board of your mobile phone has corroded. When the water dried up rust was developed. try cleaning the board of your phone...
Jan 02, 2008 | Samsung SGH-D820 Cellular Phone
Samsung T809 Cellular Phone Logo
71 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
