Question about Power Acoustik GOTHIC OV2-1200 Car Audio Amplifier
Power acoustik gothic ov2-1600
My friend gave me this amp because it dident work, every time it would come on it would go in to protect mode. I took it apart a found one set of the output transistors where blown and the gain pot was broken, so I replaced all of that and hooked it up and it worked, but now as soon as its turns on one side of the amp starts to heat up and it gets realy hot. I thalt that mabe since I replaced one side of the output transistors, mabe the other side may have been going bad and heating up, so I replaced that side as well, but that still dident fix it. Any help would be great. Thanks alot!
  • 1 more comment
  • kforcum Nov 10, 2008
    I replaced Q111-Q115, Q118 first, then it started to heat up on the opposite around Q211-Q215, Q218 so I replaced them and it still gets realy hot on the same side.
    There are 6 A1694 and 6 C4467, I replaced them with the correct part and placed them in the correct spot.
  • kforcum Nov 11, 2008
    Thanks for the help, while I was taking the amp apart to check those parts i noticed a resistor that had broken and I must have over looked it, so I replaced it and it fixed my problem. Thanks again.
  • andy_lndmn Jan 30, 2009
    i need a circuit board schematic for power acoustik gothic 0v2-1600 amp
  • 631 Answers
What are the circuit board designations (Q111, Q112, Q211, Q212...) for the parts you replaced?
Did you replace the defective parts with identical transistors?
Which transistors are heating up?
Posted on Nov 08, 2008
  • Perry Babin Nov 10, 2008
    You need to pull Q108/208 and Q109/209 to see if they are damaged/defective.
How can I fix the pulley system on the Thomas and Friends Shipwreck rail set?
How can I fix the pulley system on the Thomas and Friends ...
www.fixya.com/support/t25901578-fix_pulley_system_thomas_friends
Oct 10, 2015 - We have a Thomas and Friends Shipwreck rail set. In the mast part of the ship the string has come off one of the wheels. Need to know how to ...
We have a Thomas and Friends Shipwreck rail set. In the ...
www.fixya.com/.../t26065033-thomas_friends_shipwreck_rail_set_in
6 days ago - Question about Thomas and Friends Dolls, Playsets & Toy Figures .... can I fix the pulley system on the Thomas and Friends Shipwreck rail set?
Fisher Price Thomas & Friends TrackMaster Shipwreck ...
www.soap.com > Holiday > Hot Toy List
Rating: 3.5 - ‎84 reviews - ‎$70.79
... return policy. Shop Fisher Price Thomas & Friends TrackMaster Shipwreck Rails Set at Soap.com. ... Second time the whole system of springs and pulleys blew apart.... In looking for a on line tutorial fix found out this is a reoccurring issue.
Thomas & Friends Trackmaster Shipwreck Rails: Amazon.co ...
www.amazon.co.uk/Thomas-Friends...Shipwreck-Rail...
Amazon.com, Inc.Thomas & Friends Trackmaster Shipwreck Rails: Amazon.co.uk: Toys & Games. ...
Oct 10, 2015 | Thomas and Friends Toys
Car amp has power but will not push subs
output blown on power supply - repair by tech required.
Jan 12, 2009 | Sony XM-SD22X Car Audio Amplifier
Denon AVC-A1SE in protection mode
The numbers of the transistors thay you need to replaced are on the transistor themselfs. Just take out the bad transistors and get the numbers that you need. I ALWAYS replace the output, driver and bias control transistor myself. One thing to keep in mind, if the number on the transistor starts with "A or B or C or D or K" you need to add "2S" in front of that number when you order it. Now that this problem has repeated itself, double check your wire and speaker. They can cause this problem.
Nov 09, 2008 | Audio Players & Recorders
DENON AVR 1906
Units dc protect mode is probably activating due to Blown channel (shorted output transistors) I work for a Denon Authorized repair Center in Michigan If shipping to Michigan is economical let me know kstahl65@att.net
Feb 05, 2008 | Denon AVR-1906 Receiver
Help!!!!
Check your ground wire! Relocate it to another place in the car and try to get a heavier ground wire aswell.
Apr 03, 2007 | Sony XM-2200GTX Car Audio Amplifier
Amp in protect mode
Check to see if the fuse is blown. If it's not, the amp is unfortunately fried. It would not be worth repairing the resistor in it
Apr 11, 2017 | Phoenix Gold Xenon-600.1 Car Audio...
Power Acoustik GOTHIC OV2-1200 Car Audio Amplifier Logo
613 people viewed this question
Top Power Acoustik Car Audio & Video Experts
Tygh Duval
Tygh Duval
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
