Televison & Video Logo
Posted on May 23, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a 56" Toshiba DLP TV, yesterday evening while watching the CNN news we have heard a cracking sound and the video disappeared, the screen went black. The audio was OK, but the two pilot lights on the bottom right of the sreen were flashing red first and then green. When the red light was flashing, the audio comes on and when the green light was flashing the click sound was heard. It kept doing that untill I turned the power off. What could be the problems? Thanks a lots, Xay Bounnapha
Russ Hill
Level 3:
  • Televison & ... Master 4,057 Answers
  • Posted on May 23, 2017
 Russ Hill
Level 3:
Answers
4057
Questions
10
Helped
1176552
Points
12696
Hi when was the bulb last changed as when the bulb goes it will do this. at the back of the tv is a panel, it will have vents an a sign saying something like bulb on it the bulb is in there and there is a screw holding this cover on and inside is a clip that holds the bulb in place, remove bulb and check it for its colour if its black then its blown and you just need a new one. if its damaged in any way replace it and do not touch the glass.
5 Related Answers
ginko
Ginko
  • 19396 Answers
  • Posted on Jul 26, 2008
SOURCE: samsung dlp
If you have have 40 vertical lines 16 pixels wide: DDP1011 or BCA, DMD panel interference: Replace the DMD board.
Anonymous
  • Posted on Sep 14, 2008
SOURCE: TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
Slinteriors
Sonny Berry
  • 8617 Answers
  • Posted on May 23, 2009
SOURCE: 5 red flashs on power/standby light on kdsr60xbr1 screen blank,
Thats the error for lamp driver error. Which means the Ballast is most likely defective. You can get the replacement ballast for your model at the following link which comes with installation instructions.
http://servicemanuals.vstore.ca/product_info.php/pName/kdfe42a10-ballast-assembly/cName/sony-parts
Anonymous
  • 5138 Answers
  • Posted on Jul 20, 2009
SOURCE: zenith 56" DLP Z56DC1D won't turn on
Replace Lamp and CK both Fans to make sure they are running.If Fan behind Lamp does not run TV will not light LAMP.
Chi Chu
  • 8457 Answers
  • Posted on Jul 17, 2010
SOURCE: heard a pop and picture is black and white
This tv have a colors wheel.The colors wheel is dead.The tv have squiling,motor loud noises and back&white picture.All the indication problems of the colors wheel is dead.Call the tv tech.to fix this problems,because have to take out alot of manchanical parts.Before even can get to the colors wheel out to replaced it.
I have a Toshiba 1080i DLP hdtv.. my son & i were
the lamp exploded it happens u need to replace the lamp ensure its the exact type, the lamp is the light source and without light the dmd cannot sync colours nor pix
I was watching my Toshiba 56mx195 DLP tv and heard a popping noise and the screen went blank but the sound was still on, is it the lamp or something worse?
You are correct in this assumption it is more than likely the lamp that blew after too many hours or getting to hot.
My 65 inch flat screen Toshiba tv has tiny white spots all over the screen. Can I change anything to save the tv? Any help is appreciated.
This is an easy fix, just change the DLP chip.
I bought one on Friday and it got here yesterday, I followed the video instruction on Utube. I spent maybe 1 hr, because I kept going back and forth from the tv to my PC to watch the video.
The chip is soooo easy to replace, and only cost about 150 bucks at shopJimmy.com
http://www.youtube.com/watch?v=eWRE_k62Ylg
http://www.youtube.com/watch?v=erHUzDulS4c
http://www.youtube.com/watch?v=MZfIJ_PBUaQ
3helpful
2answers
I have a Samsung 50 inch DLP - I heard a pop and the picture immediately disappeared. The 3 lights were flashing on the front which according to the book said it needed a new lamp installed. I ordered it,...
Sounds like the color wheel may have also gone bad. I recently saw a 56" Samsung where the bulb and color wheel went at the same time. The color wheel could produce a crying noise while trying to spin up.
Samsung HLR5067W goes from a normal picture to snowy green color
Greetings!
I hate to be the bearer of bad news, but it is not something that has a quick fix. Without inspecting it myself it is impossible to say, but the last three of these that I have seen have been bad digital boards and can be a real bear to change, even when you have experience.
I would get slightly different video symptoms when I would switch between the coaxial input to the component input to the HDMI input. But in all cases my on screen display and menu were anomally free. Hope this was helpful, even though I don't think it is something you should attack yourself.
Rob
It Quit!
call or contact samsung
Color
heard a crack & black and white picture is ok please check chroma ic & its related parts of chroma portion of that IC
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
