Question about Fuji FinePix A330 Digital Camera
Fujifilm A330 My camera is doing something rather strange; it's always switched on by sliding the front shutter open all the way, and it's ceased turning on when I do that. My dad and I figured out that we can get it to turn on by holding the 'on' button in the back, but it won't get out of the menu/blue 'no image' LCD display for reviewing pictures. In the past, holding the 'on' button was what changed it from picture review mode to picture taking mode, and since everything has swapped around to making the 'on' button control power, it just turns off the camera now. Any idea what caused this change, or how to fix it? x.x I've checked the user's manual and can't find any reason why it's doing this, so I'm really at a loss...
My switch was dirty... very dirty. I took my camera apart (NOT SUGGESTED FOR THOSE WHO DO NOT KNOW) and cleaned it which was NOT the easiest job. I would take it in to get it serviced if youw ant to play it safe. Take it apart only if you expect to never get it working again. You may not have a camera anymore BUT you will learn a thing or two. Who knows, you may just fix it as well. DO NOT POUR ALCOHOL INTO THE CAMERA. It can leave a residue on the inside of the lens.
Posted on Aug 07, 2007
SOURCE:
Can't insert 8GB fujifilm card into Fujifilm fine pix A330
The A330 uses xD Picture Cards, which top out at 2GB. Your 8GB card is some other type (most likely SDHC) which will not work in the A330.
Oct 25, 2012 | FUJIFILM Cameras
I just got the fujifilm instant mini 7 and all the pictures are coming out black, is there something wrong with it, or am I just doing something wrong?
Check the ISO setting and that the lens shutter is actually opening when you take a pic. Black is underexposed and often relates to the wrong ISO setting ( film speed) I know its digital but ISO works like the old ASA and sets the shutter speed in relation to the amount of light.
Please rate my help++++Thanks for using FIXYA
May 21, 2010 | FUJIFILM instax mini 7 Digital Camera
Is the firmware for fuji finepix A607 the same
Heres the support site for that camera - theres no firmware listed http://www.fujifilm.co.uk/consumer/digital/digital-cameras/legacy-cameras/finepix-a607-zoom/support I would not use the A330 firmware although considered identical - Its NOT it is identical to the A330, except for the fact that it uses a Super CCD sensor instead of the standard / conventional sensor in the A330...
why do you want to update the firmware ?
Apr 10, 2010 | Fuji FinePix A340 Digital Camera
Fujifilm finepix A330 switches off after trying to take a picture fitted 2 new 1.5v batteries,and an external power supply
The sliding lens cover is also the on/off...... be carefull you are not moving it as you take picture.
Dec 29, 2009 | Fuji FinePix A330 Digital Camera
HOW DO I INITIALIZED MY OLYMPUS XD M+ 1GB ON MY A330
A330 needs to be upgraded with new firmware before it can use M or H cards.
The firmware is available here:
http://www.fujifilm.com/products/digital/download/a330/fupd.html
Read the instructions before updating.
Dec 10, 2009 | Fuji FinePix A330 Digital Camera
How do I initialize a new xD 2GB memory card for my A330 Fuji FinePix camera?
Your A330 is not compatible with the XD cards that start with an "H" or a "M" before the XD designation, unless you perform a firmware upgrade. You can do it yourself using this link from Fuji Canada. http://www.fujifilm.ca/x13573.xml
Apr 14, 2009 | Fuji FinePix A330 Digital Camera
Initialization of newMxd card
Follow this link:
3.Downloading the firmware upgrade
Read the firmware upgrade user license agreement and agree to the terms before downloading the upgrade."
Firmware Upgrade User License Agreement
NB The download link is on the User License Agreement page
Note all the precautions when upgrading the firmware.
Sep 16, 2008 | Fuji FinePix A330 Digital Camera
M1gm
In order to use Type "M" xD cards, you need to upgrade the camera's firmware.
Read here: http://www.fujifilm.com/products/digital/download/a330/fupd.html
-Kelly.
Oct 21, 2007 | Fuji FinePix A330 Digital Camera
Wierd pictures
This is caused by a shutter that is stuck open. Normally the shutter closes right at the moment that you snap the picture and allows the image sensor to record what it saw at that moment. When the shutter does not close as intended the image sensor cannot properly record the image. This is why here are the lines across your images. The shutter can stick either due to an impact knocking the delicate blades off their tracks, or due to dust or moisture contamination sticking them open or closed. If gently tapping does not free them; the camera will require professional repair. David Millier Advance Camera Repair
Feb 15, 2007 | Fuji FinePix A330 Digital Camera
Fuji FinePix A330 Digital Camera Logo
96 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Azam Ali
Level 1 Expert
KJ Soni
Level 1 Expert
Are you a Fuji Camera Expert? Answer questions, earn points and help others
