Question about Waring WMK300 Professional Belgian Waffle Maker
Falling Apart I,ve had mind for about 3yrs I was making waffles for my grandchildren when I poored the batter and turned it the thing fell apart when I was checking it the screw that holds the bottom plate came loose.It seems the female connection had expanded or the threads were stripped. Those people ain't worth the power to blow them to hell. this one guy was very rude he brushed me off and told me to go to the webbsite because we don't service them we sell them. boy was I pissed.Please help I want some waffles
  • jhaas6869 Mar 08, 2009
    I too have the same problem and also was fixing waffles for my grandchildren. Maybe we should stop cooking for the kids. Ha Ha! I doubt if Waring will do any good with service, so, I'm going to fill the screw holes with epoxy and re-insert the screws. If that doesn't work, I'll use a little larger course threaded screws. I guess the junk we get from overseas is our own fault. BUY AMERICAN.
    President:
  • 267 Answers
Your stuck . thats the most common problem with this unit , who would think of plastic that close to a hot element and NO PARTS MADE ......... and waring does not care at all ......... the only thing you can do is google "waring waffle reviews"
. and write reviews about what happend to yours and hope you can help someone else that is thinking about getting the appliance
Posted on Jan 26, 2009
I have a new kitchenaid mixer and both times i've used it the cake did'nt come out right, it was bland and it fell apart and that never happened before. what did I do wrong?
It could be that your over mixing the batter. It is very easy with a KitchenAid to push a batter too far, and you get too much air, or cream the butter too much into the flour, or press all the oil out of peanut butter. Try using the mixer for only as much to get the matter mixed.
Jul 03, 2012 | KitchenAid Food Mixers
Waring Belgium Waffle maker shorted out and blew house breaker.
The wire near the fuse is shorting out on the metal under the lower grill. Mine did that when I replaced the fuse and turned it on. If not under warranty, it is easier to replace it for $39.95 from Costco than the hassle of taking it apart and trying to replace the fuse, which involves the time to take it apart, buying a fuse and either the crimper and connectors or a soldering iron and high temp solder, since the regular solder melts shortly after it begins heating.
Nov 12, 2011 | Waring WMK300 Professional Belgian Waffle...
Cleaning your waffle iron WPLT4
Let me start by telling you WHAT NOT TO DO.
  1. Never clean a waffle maker while it's still hot. Let it cool completely.
  2. Never dunk your entire waffle maker in water.
  3. Never use scouring pads, steel wool or abrasive cleansers.
  4. Never use a knife or pointed object to clean your waffle maker(I've actually seen that advised on less reputable sites).
When it comes to cleaning a waffle maker, your first source of information should always be the owner's manual. There are many different kinds of waffle makers, so your buddy Mr Breakfast will gladly defer his expertise to the company that makes your waffle maker.
What I can speak about is my own favorite waffle iron. It's a modern electric waffle iron with non-stick and non-removable baking plates. That's the same kind you have? Oh good. It looks like you came to the right guy.
Cleaning the baking plates:
  1. Remove any small puddles of oil with a dry paper towel.
  2. Brush away any crumbs with a soft-bristled kitchen brush or old toothbrush.
  3. Remove any batter stuck to the iron with a rubber spatula.
  4. To remove really-stuck-on batter, douse the baked-on batter with cooking oil. Wait 5 minutes for the batter to soften. Dab the batter off with a paper towel or cloth.
  5. To prevent staining and long-term oil build up, wipe down the baking plates with a damp cloth or paper towel.
  6. Make sure the waffle iron is completely dry before storing.
To clean the exterior, wipe down the housing and handle with a damp cloth.
Keeping it clean:
There are a couple things to remember to make sure our kind of waffle maker stays clean.
  1. Unless stated otherwise in the manufacturer's instructions, you should never coat the baking plates of a non-stick waffle iron with cooking spray. Over time that will give you a gummy build up that will turn your waffle maker to junk. Today, when a waffle maker makes the claim that it's non-stick, they really mean it. The only oil you need is the oil in the recipe. If your waffles are sticking, it's your batter that needs more oil, not your waffle maker.
  2. Unless stated otherwise in the manufacturer's instructions, don't use soap to clean your baking plates. Soap can be the enemy of a non-stick surface. Oil - on the other hand - can be a great friend. It creates a thin layer that helps maintain the non-stick surface. Soap will completely obliterate that layer of friendly oil. Harsh soaps can deteriorate the manufacturer's non-stick surface over time.
Mar 05, 2011 | Salton WM4 Waffle Maker
When using a toastmaster waffled maker do you have to use an oil or butter pan spray?
Normally you mix oil in with the batter, but this doesn't keep the waffles from sticking. Even non-stick waffle makers stick some. Use a light spray of Pam (or similar) on the bottom tray, add your batter than spray the top pan and close. This gives you your best shot at a perfect waffle!
Enjoy!
--W/D--
Jan 17, 2011 | Toastmaster 217 Cool Touch Belgian Waffle...
Is there a way to turn the sound off? When we plug it in the high pitched sound makes our dog shake and squeal. If we can turn this off we'll have to get rid of it (the waffler not the dog!)
I struggle with the same thing, it's like an apocalypse alarm for my poor dog. I have covered with duct tape which muffles, but does not come close to silencing this culinary menace. May delve further and take the waffle maker apart to find the alarm source. It's a great waffle maker otherwise, we just don't enjoy them as much due to the noise and affect on the dog.
Dec 17, 2010 | VillaWare 2005 Uno Petite Waffle Maker
So frustrated. waffles separate even though I am following instructions for preheating, oiling etc. one thing that bothers me is the recipes included are not for belgian waffles (yet the product is...
Don't over mix the batter. Let it be slightly lumpy you don't want to mix every bit of flour to a totally smooth batter. Let is have a few lumps in it.
Aug 12, 2017 | Bella Cucina 13124 Waffle Maker
I bought a Krups Household Type Waffle Maker at a thrift store. It looks new, but doesn't have any instructions with it on how much batter to use or how to clean it. I got a recipe online and it was great...
I think this is why people make pancakes. =) Cleaning the waffle iron is a real pain. My waffle maker looks exactly like the one you have pictured. Mine also came with no instructions because its my fiance's. As far as how much batter to use, you should use a ladle and through trial and error figure out how much is the best amount. I would guesstimate approximately 1/4 c. For cleaning the overspill, from what I have read online, everyone says to unplug the iron (obviously) and wait until the waffle iron has completely cooled before cleaning. I have cleaned the back of the unit (where the coils are, which unfortunately got flooded with batter the first time) with a damp kitchen brush, damp sponge, and paper towels. Its messy and time consuming to clean up. You can get in the coils better with an old toothbrush or a very small bottle cleaner (like the kind you would buy to clean cake decorator tips). I just use warm water to remove the batter/gunk. I use a sponge (damp with warm water) to clean the baking plates. I towel dry everything after its clean, and clean the outside with a little windex so it stays nice and shiny. Good luck! I also recommend making lots of extra waffles and freezing them, so you can avoid as much waffle clean-up as possible. ;) You can heat them up in the toaster like Eggos. They stay good in the freezer for up to 6 months.
Sep 21, 2010 | Krups 65475 WaffleChef Waffle Maker
Seasoning Waffle Baker and Grill
FIrst, make sure there is some kind of fat or oil in the waffle batter recipe. This is the biggest difference between waffle and pancake batter. Go to Sams or a restaurant supply store and get a spray product like waffle-off. Spray lightly aftter every few waffles. Use lightly as heavy spray can cause build up. If you can't find this product use one of the PAM type sprays for BBQ grills or maybe an olive oil based product. Regular Pam sprays build up faster as they are not really designed for this. Don't try to wash the grids between uses as they need to keep the oil coating. (Like using a cast iron skillet) They will turn a dark brown. Just brush off crumbs or use a damp rag. Make sure the waffles are completely cooked as when not completely cooked they will seperate and be very difficult to remove. They are cooked when the steam stops coming from the sides. This will take 3 - 6 minutes. Don't preheat with the iron open or allow it to stand open for any longer than necessary. (It can overheat)
Apr 13, 2008 | Kitchen Appliances - Others
Salton Belgium Waffle Maker
I, too, was searching for that wonderful Belgian Waffle recipe and thought, no problem, I'll just look on-line. I couldn't believe it when Salton didn't have it posted on their site (if they did, I couldn't find it) and was taken to your requests for the recipe. So, I went the whole mile, or should I say traveled over mountains of files, and couldn't believe that my filing system still works after all of these years, the Salton Belgian Waffle Maker & Recipe Guide for Model No. WM-4 was right where it was supposed to be. (And my husband, and prior bosses I should add, have laughed at how I save and file everything. I'm glad I can share this with you all now...
Basic Belgian Waffle Recipe
1 cup all purpose flour
1 tsp. baking powder
1/2 tsp salt
1 tsp sugar
1 cup milk
1 egg, separated
1/2 tbl butter, melted
-Sift dry ingredients together in a bowl
-Add egg yolk and milk to the dry ingredients and beat together thoroughly.
-Beat egg white until stiff, stir 1/4 into batter to lighten it and then gently fold in the remaining egg white.
-Pour a scant 1/2 cup of batter onto the heated waffle mold. The light should be off. When batter is added, the light will go on. When the light goes off again, the waffle is done.
-Makes about 6 waffles.
Chocolate Waffles ("which make great ice cream sandwiches," says the recipe book.)
1 tsp baking powder
1/4 tsp salt
2 tsp sugar
2/3 cup milk
1 egg, separated
2 Tbl melted butter
1 1/2 squares semi-sweet chocolate (1 1/2 ounces)
3/4 tsp vanilla
-Add milk, egg yolk, and vanilla to dry ingredients and beat until well blended.
-Melt butter and chocolate together in microwave or double boiler. Stir chocolate mixture into batter.
-Beat egg white until stiff, stir 1/4 into the batter to lighten it and then gently fold in the remaining egg white.
-Pour a scant 1/2 cup of batter onto the heated heart waffle mold. (Hmm, the WM-4 isn't shaped into a heart??? Oh well, moving onward...)
Serve sprinkled with powdered sugar or cinnamon or topped with vanilla ice cream and chocolate sauce.
Aug 17, 2007 | Salton WM8BEL Belgian Waffle Maker
Waring WMK300 Professional Belgian Waffle Maker Logo
161 people viewed this question
Top Waring Kitchen Appliances - Others Experts
jdtech
Robert Weir
Robert Weir
Level 1 Expert
Are you a Waring Kitchen Appliances - Other Expert? Answer questions, earn points and help others
