Question about Acer Aspire 5610-4648 Notebook
ERecovery is not working
I have acer 4720z .i downloaded erecovery manangement from acer site.i installed it,but it required D2D system.i searched on google but i cant installed now i can do now plz solve this problem
  • saurav mani Nov 07, 2008
    & erecovery is not be installed and also it isn't working
I need a acer aspire one happy recovery disk
The Acer Aspire One Netbook has a hidden partition on its hard disk drive which allows recovery of
1. operating system to original factory image (with no recovery disk required)
2. applications (selectable)
3. drivers (selectable)
If the netbook came with pre-installed Windows XP, use Acer eRecovery Management by
1. pressing start button at bottom left corner of Taskbar
2. hover cursor over All Programs then Acer Empowering Technology
3. then click on Acer eRecovery Management and follow subsequent recovery instructions
Alternatively, on powering up, press Alt and F10 together while Acer logo is showing.
If this doesn't work, there is the possibility that the D2D recovery is not enabled for startup.
To enable D2D recovery,
1. press F2 on powering up to get into the startup utility
2. cursor over to the Main tab
3. cursor down to D2D and enable it.
4. save changes when exiting - system will reboot
5. again, press Alt and F10 together while Acer logo is showing.
Jan 15, 2011 | Acer Aspire One Netbook 8.9" Notebook
D2d recovery miss, in my hd, what I do?
If the computer you are recoverying the Operasting System on does not have an internal optical drive an external USB optical drive will be required to use the Recovery Media.
  1. If applicable, ensure the external USB optical drive is properly connected to the computer and powered on.
  2. Power on the computer.
  3. Press the F2 key to enter BIOS Setup during Power-On Self-Test (POST while the Acer logo is being displayed).
  4. Using the keyboard arrow keys, arrow over to Boot.
  5. Refer to on screen instructions to set the first device to CDROM or USB CDROM.
  6. Press the optical drive drive eject button and insert the System CD.
  7. Close the optical drive tray.
  8. Press the F10 key, and then the Enter key to save the changes and restart the computer.
  9. The computer will boot from the Acer Recovery Media, follow the prompts to reinstall the Operating System.
Note: If you do not have a set of Acer Recovery Media they may be purchased at our Acer Recovery Media Order Form.
Drivers for Acer products may be found on the Acer Product Support. Search for the product and download the drivers.
Alternatively, the factory installed drivers and applications can be re-installed by using Acer eRecovery by following these steps:
  1. Click Start, and then All Programs
  2. Click Acer, and then Acer eRecovery Management
  3. You may be prompted to enter or create a password. This password will be required to use eRecovery in the future.
  4. In the next window on the left toolbar, select Restore.
  5. Choose Reinstall Drivers or Applications
  6. Choose Contents
  7. Choose the driver or application you wish to install
  8. On the right, click the Install link and follow the prompts.
  9. The computer may restart when installation is complete. If it does not restart, manually shutdown and restart the computer.
Note: For older Acer products, the Acer eRecovery Management program may not be available.
Dec 12, 2010 | Acer Aspire 5610-4648 Notebook
Not d2d system erecovery cannot be installed
DriversMax Is a free download and can help to find the compatiable drivers for your pc with web cam.
May 23, 2009 | Acer Aspire 4315 Notebook
Install the eRecovery drivers for aspire 5715Z
First ensure you have enabled D2D from Bios, If bios settings are OK then that message often comes up when E recovery partition is damaged.
Possible solutions are calling Acer and getting a disk to restore recovery partition (best way to proceed)
Or downloading and installing drivers from acer website
Here is recovery procedure from manual, to ensure you are doing corrrectly:
Create backup
You can create and save backup images to hard disk, CD or DVD.
1 Boot to Windows XP
2 Press Alt + F10 to open the Acer eRecovery Management utility.
3 Enter the password to proceed. The default password is six zeros.
4 In the Acer eRecovery Management window, select Recovery settings and
click Next.
5 In the Recovery settings window, select Backup snapshot image and
click Next.
6 Select the backup method.
a Use Backup to HDD to store the backup disk image on drive D:.
b Backup to optical device to store the backup image on CD or DVD.
7 After choosing the backup method, click Next.
Follow the instructions on screen to complete the process.
Restore from backup
You can restore backups previously created (as stated in the Create backup
section) from hard disk, CD or DVD.
1 Boot to Windows XP.
4 In the Acer eRecovery Management window, select Recovery actions and
click Next.
5 Select the desired restore action and follow the onscreen instructions to
complete the restore process
Here Acer download page: Acer Service & Support
May 05, 2009 | Computers & Internet
Acer eRecovery Problem
When you Formated the Dirve You Deleted The Hidden Recovery Partition
Oct 20, 2008 | Acer Aspire 4520-5582 Notebook
D2d recovery
Unfortunately once your original HDD has been replaced you lose all e-recovery features and there is no-way this can be reversed.
If you could get hold of the image from your old drive you maybe able to write it to your new, its a bit messy though.
The main reason for the "factory default image backup" you have not working now is because a snapshot of the C: drive is stored on D: drive so when you replaced the drive itself you basically made that disc useless for eRecovery features.
Sorry its bad news.
Jun 17, 2008 | Computers & Internet
D2d recovery
you can not use erecovery and d2d if your don't have the hidden d21 partition on your harddisk. and since you have replaced your harddisk you don't have it anymore.
mail to compurepair and see if he can fix it..
rate me if you want.
Apr 08, 2008 | Acer Aspire 5630 Notebook
Not d2d system
Format all None Hidden Hard Drives & it will restore the your purchase date
Mar 04, 2008 | Computers & Internet
Acer d2d recovery problem
Idiot. You deleted the partition containing the D2D.
Mar 03, 2008 | Computers & Internet
Acer Aspire 5610-4648 Notebook Logo
94 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
