Question about Philips ProScreen 4100 Multimedia Projector
Fuse holder I found where the fuse is on the 4100 projector and it is broken. It looks lik the fuse burned out and when it did it melted the plastic piece that holds the fuse. I have an extra fuse but the holder is no good. Does anyone have an old 4100 they don't need that they can take the fuse holder from and send to me?
My Sony TC WR 535 wont open doors, one cassette in deck B,lights blinked in display panel then unit shut down, not been able to turn it on since
Remove the cover after unplugging AC. Look for a plastic stop that keeps the eject button from going in farther. Move the plastic stop peice downward and the buttom will then move in all the way and tape will eject. On mine the plastic piece is white and rotates down.
Feb 18, 2012 | Sony TC-WR565RM Single Cassette Deck
When l looked at the reed valves. sitting on top of the valve was a broken piece of black plastic. what is it?
I find all kinds of debris inside of the head. Once I found what appeared to be tar but was a whole plastic bag that was sucked into the compressor and melted onto one piece of plastic sticky substance. Your piece could be a piece of the air filter left from mfg process. In another compessor, a clever mechanic used epoxy to try to seal one of the reeds on a multy reed plate to extend the life of the plate. In any event, glad to see that you are repairing it yourself.
Oct 20, 2011 | Stanley Bostitch CWC200ST 3HP Oil Lube...
Optoma EP719 projector broken circular glass disk
The piece that's cracked is called a color wheel. I spoke with the parts department at optoma and they want $300 for a new color wheel for my ep 732h projector. I'm not sure if it's the same part but you can contact optoma on their website and they'll get back to you with a price quote for that part.
Jan 16, 2010 | Optoma EP719 XGA DLP PROJECTOR 2000L...
Burned plastic part on refrigerator compressor
side by side refrigerator freezer, smelled melting plastic, found a plastic box connected to the compressor burned. What is this and how much does it cost to replace?
Dec 13, 2009 | KitchenAid Refrigerators
Toshiba MT200 videoprojector won't start
if there are no leds lit on the top, the power supply is gone. if there are leds on the top, which ones, are they blinking, how many times, and what color?
Sep 01, 2009 | Toshiba TDP-MT200 Multimedia Projector
Found a leak behind fridge,plastic hose is seperated
There is no connector . The plastic line pushes into the valve . If enough line is there , remove the short piece from the valve by pushing in on the white ring while pulling out on the broken line , and insert the main line into the valve with a little force . Check for leak by using water dispensor.
Aug 11, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
The fuse directly is broken when the power is on
The 5 leg black plastic chip part is a "VIPer100a" I have one with the same problem, but mine burned up pcb tracks and other parts.
Good luck.
May 29, 2009 | Compaq iPAQ MP2810 Multimedia Projector
Wont start
you may be having a problem with the connections on the battery or your selenoid on you starter is goin bad
Feb 16, 2009 | 1996 Chevrolet K1500
Washer wont spin
the the motor coupling ..unit want wash or spin,,,if you would lik to try your hand at replacing it lety me know,,onthejob
Feb 01, 2009 | Kenmore 24032\24036 Top Load Washer
Philips ProScreen 4100 Multimedia Projector Logo
Top Philips Office Equipment & Supplies Experts
Are you a Philips Office Equipment and Supply Expert? Answer questions, earn points and help others
