Question about Hitachi CP-X445 Multimedia Projector
Need to clean the filter on the projector
I did clean the filter but now I need to reset the time, how do I reset the time for the filter?
  • sweetbug Nov 07, 2008
    thanks for any help
4 Suggested Answers
JustAskMe
  • 29 Answers
SOURCE: Projector Reset
Hi Here is the info for you :: Caring For The Air Filter The air filter should be cleaned about every 100 hours. If the indicators or a message prompts you to clean the air filter, clean the air filter as soon as possible. If the soiling will not come off the air filter, or it becomes damaged, then it needs to be replaced. Please replace the air filter as soon as possible. memoWhen you replace the lamp, please replace also the air filter. Turn off the projector, and unplug the power cord. Allow the lamp bulb to cool for at least 45 minutes. Apply a vacuum cleaner to the top of the filter cover and the air filter to clean. If the soiling will not come off the air filter, or it becomes damaged, it needs to be replaced. If the air filter needs to be replaced, contact your dealer to prepare a new air filter. Tell the dealer your air filter type. Turn on the projector power, and reset the filter timer. (1) While the projector running, press the MENU button to open the menu. (2) Choose the ?OPTION? on the menu using the / button, then press the button or ENTER button. (3) Choose the ?FILTER TIME? using the / button, then press and hold theRESET button for 3 seconds. (4) Choose the ?RESET? using the button. memo Incorrectly resetting of the filter timer (resetting without replacement, or neglect of resetting after replacement) will result in incorrect message functions. Here is the link to the users manual :: http://www.aboutprojectors.com/Hitachi-CP-X1250-projector.html Further Questions ?? Email Me hartmansp@inbox.com Have a great evening.
Posted on May 05, 2007
  • 3 Answers
SOURCE: The change filter light keeps coming on
In the manual, it says you have to go in the menu to the OPTION submenu. Go down to FILTER TIME and hold the right arrow down for 3 seconds. It will then go into a mini-submenu that, when you press the up arrow, will reset the filter time to 0. The key is to hold down the right arrow initially for THREE+ SECONDS to get into the reset filter time menu. This is NOT the submenu that has RESET - EXECUTE. That is a different thing that doesn't reset filter & lamp time.
Here's the manual online:
http://www.hitachi-homeelectronics.us/supportingdocs/forhome/DisplayTechnologiesGroup/lcdprojectors/SupportingDocuments/01CP-S235-OG-ENG.pdf
Posted on Jan 21, 2009
SOURCE: cleaning the filter/blinking LAMP and TEMP
Goto Advanced menu and select option then lamp Time hold down the reset button on the unit for 3 seconds until a new screen comes up then hit reset. Do the same for resetting the filter time
Posted on Apr 27, 2009
How do i access the air filter on the PJ551?
Air-Filter
Cleaning the Air Filter
The air filter should be cleaned as described below at intervals of approximately 100 hours. When
the filter is used for approximately 100 hours, the message "CLEAN THE AIR FILTER" appears
when the projector is switched on.
1 Switch the projector power supply OFF, and remove the power cord from the power outlet.
2 Clean the air filter with a vacuum cleaner.
3 Reset the Filter Timer using the function of the FILTER TIME on the OPTION Menu. Please
refer to the description of the "FILTER TIME" on the Table 9: MAIN Menu.
Replacing the Air Filter
Replace the air filter if contamination cannot be removed, or if it is damaged. To order a new air
filter see page 26 for contact information.
1 Switch the projector power OFF, and remove the power cord from the power outlet.
2 Remove the filter cover and the filter.
3 Replace the new air-filter and the filter cover.
4 Reset the Filter Timer using the function of the FILTER TIME on the OPTION Menu. Refer to
the description of the "FILTER TIME" on Table 9: MAIN Menu.
Sep 26, 2011 | ViewSonic PJ551 Multimedia Projector
"clean and reset filter" alert is displayed even
You can reset the "Filter Time" on your projector and it will clear this error out of the system.
1) Clean Filter
2) Turn the power on
3) Hit the Menu button
4) Once the menu appears choose "Options"
5) Choose "Filter Time"
7) While the time is displayed hold the "Reset" button on the remote for 3 seconds
8) The "Reset" menu will pop-up and choose reset.
That should take care of it.
Mar 14, 2011 | ViewSonic PJ501 Multimedia Projector
After turning on the projector, I get a message that says clean the filter and reset the timer. How do I do that? I have cleaned the filter.
Procedure for resetting filter time.
Pressing the RESET button for about 3 seconds displays the FILTER TIME menu. Select the RESET using button to reset the timer. : RESET <- CANCEL Selecting the RESET resets the count of the lamp timer to 0. memo Perform this function only when you have cleaned or replaced the air filter. The filter timer counts the used time of the air filter after cleaning or replacement, to display the messages about the air filter. Incorrect performing causes incorrect operation of the messages. memo About caring for the air filter, please refer to the section "Air Filter".
Users manual located here. http://www.aboutprojectors.com/pdf/hitachi-cp-x1250-manual.pdf
Good info deserves a good thumbs up! Thank you!
Mar 01, 2011 | Hitachi CP-X1250 Multimedia Projector
After 2 mins on the bulb goes out
Need to change bulb and reset the lamp timer. When was the last time you clean the air vent filter. Clean it and reset the air vent filter cleaning timer
Aug 10, 2010 | 3M EP7630LK Projector Lamp for MP7630,...
I cleaned the filter, but keep getting "Clean the Filter" Message. Is there something else I need to do?
Hello :
In some projectors after cleaning the filter you need to reset the projector .
Please check this video .
Please don't forget to rate !
Apr 12, 2010 | NEC VT670 Multimedia Projector
My hitachi cpx201 projector says to check the air flow
Hi There Teacher!
the air filter unclips on the left hand side, lens facing out.
after vacumming out the filter see below for filter reset counter procedure
Good Luck!
Turn the projector on and reset the filter time using the FILTER TIME item in the EASY MENU. Before taking care of the air filter, make sure the power switch is off and the power cable is not plugged in, then allow the projector to cool sufficiently. Taking care of the air filter in a high temperature state of the projector could cause an electric shock, a burn or malfunction to the projector. Use only the air filter of the specified type. Do not use the projector without the air filter or the filter cover. It could result in a fire or malfunction to the projector. Clean the air filter periodically. If the air filter becomes clogged by dust or the like, internal temperatures rise and could cause a fire, a burn or malfunction to the projector. WARNING Please replace the air filter when it is damaged or too soiled. When you replace the projection lamp, please replace the air filter . An air filter of specified type will come together with a replacement lamp for this projector . Please reset the filter time only when you have cleaned or replaced the air filter, for a suitable indication about the air filter. The projector may display the message such as ?gCHECK THE AIR FLOW?h or turn off the projector, to prevent the internal heat level rising. NOTE (1) Press the MENU button to display a menu. (2) Point at the FILTER TIME using the ??/?? button, then press the button. A dialog will appear. (3) Press the ?? button to select RESET on the dialog. It performs resetting the filter time.
Jan 14, 2010 | Hitachi CP-X201 Projector
Clean Filter - NEC VT700 projector
Need to go into the menu and find the option to reset. Choose the "reset filter hours" option.---Rick
Sep 04, 2009 | NEC VT700 Projector
Air Filter and reset the timer settings
go into the menu. it should be in the same menu as the lamp timer. as for cleaning the filter, use canned air.
May 18, 2009 | 3M MP 7750 Multimedia Projector
Resetting Air Filter Timer once cleaned.
Menu, options, filter time. When the filter time is displayed, press the reset button for at least 3 seconds. The reset menu will appear and you can select RESET.
Feb 01, 2008 | Hitachi CP-X385 Multimedia Projector
Projector Reset
May 03, 2007 | Hitachi CP-X1250 Multimedia Projector
Hitachi CP-X445 Multimedia Projector Logo
70 people viewed this question
Top Hitachi Office Equipment & Supplies Experts
jasbo
jasbo
Chris Goulet
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
