Question about HP Photosmart C6180 All-In-One InkJet Printer
Two problems 1-when faxing, only one page can be faxed at a time. If we try and do multiple pages, they all go through together. 2-when receiving faxes, they are arriving blank.
  • 300 Answers
Issue 1:
  • Make sure that you fan or flip through the pages before inserting them in the document feeder. This creates air space between the pages.
  • Refer to this link for more information on this issue.
Issue 2:
  • Make sure that ink cartridges still have ink. Replace if needed.
  • Refer to this link for steps to clear faxes in memory.
Posted on Nov 16, 2008
Winfax hangs up after receiving the first two pages
I use win fax pro to receive and the sender use Epson fax equipment. I can receive 2 pages when the sender send continuously.Although I can see 2 pages success message in the inbox,only can see the second page when I double click this message.Surely is I receive 2 pages because this receive message file size is 54kb i.e 2 normal pages for our office daily use size.
Aug 08, 2012 | Symantec WinFax Pro for PC
We have a receiving problem with our HP Color LaserJet CM2320nf . The exact issue is that, sometimes the machine is unable to receive a fax with any number of pages from different senders Also, the...
Error Code 223 (ECM error)
The receiving product has been unable to receive an entire page even after multiple attempts to rereceive the parts of the page that contain errors. This is usually due to extremely poor line conditions.
1. Reattempt the fax reception at a different time when telephone line conditions have improved.
2. If the error persists, disable ECM. Errors may still occur, and may result in degraded image quality on the received page. However, the ability to receive the entire document will be improved.
Error Code 420
V.34 negotiations have failed from the originating product during phase four, which occurs after V.8 and before the first T.30 frames are exchanged. Compatibility problems have been observed in this area when sending to non-HP units.
Reattempt the fax transmission at a different time when telephone line conditions have improved.
Error Code 421
V.34 negotiations have failed from the originating product during phase three, which occurs after V.8, before phase four, and before the first T.30 frames are exchanged. Compatibility problems have been observed in this area when sending to non-HP units.
Jul 20, 2011 | HP Laserjet CM2320nf All-In-One Color...
I using a roller fax machine. today i had fax a documents that have 4 pages and i put together and let it run auto. i confirmed that i fax once only but the receiver received the first page more than 10...
By "roller fax" if you mean auto document feeder, so what's the problem? If you didn't see each of the 4 pages feed into the machine one at a time then what happened at the other end could be because something happened at your end. It's the reason we scan and email most critical documents today.
Carl
Apr 14, 2011 | Office Equipment & Supplies
Xerox 2218 - receiving multiple copies of the same
It is a problem machine was configure multiple page,please change default setting,or choice print only 1 not other.
Dec 08, 2009 | Xerox FAXCENTRE 2218 18PPM FAX
V40xi
Hi Debbie,
Open up the document feeder and clean the rollers and pad with alcohol.
Jan 31, 2009 | HP OfficeJet V40 All-In-One InkJet Printer
My IntelliFax 2480C is ''grabbing 2-5 pages at a time when faxing.
The separation pad is worn. Thats what keeps more than 1 from going in. It is a rubber rectangle shaped part probably on the upper part of the document feeder that you lift up. They ware out. Lawrence
Jan 01, 2009 | Brother IntelliFax-2480C Fax
Faxing multiple pages
reinstall the printer software. deleted the existing printer software first.
Sep 13, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Receiving multiple page fax on Brother Intellifax 4100e
it may be the memory, try switching to direct printing instead of going into memory, if it prints you should change the memory.
Jul 01, 2008 | Brother IntelliFAX 4100 Laser Fax
Faxing using the scanner glass, it would ONLY allow you to do it one at a time. You can Use the Automatic DOcument Feeder on the TOP part of your printer. load all those pages and try to do the faxing. That should work.
Please, let me know if the issue is resolve.
Thank you so much.
adonscott
Jun 27, 2008 | HP Officejet Pro L7680 All-In-One Printer
HP Photosmart C6180 All-In-One InkJet Printer Logo
85 people viewed this question
Ben Johnson
