Question about RCA Scenium D40W20 40" Rear Projection HDTV
Rca d40w20 tv convergence and power on problems
Am unsure if my comment made it to you. you answered my convergence question but i live in nowhere arkansas and wanted to know if replacing both of the fuses you spoke of was a possibility. i only ask because i am sure it would cost me more to find and use a tv repair man than to buy i new tv. thank you for you help
  • pkmnjunky7 Apr 28, 2009
    Same convergence problem. Does anyone know the part number of the convergence board for a D40W20BYX1 chassis number ITC222?
  • RCA Master
  • 19,396 Answers
It is possible, if you do not have experience in fixing tvs is better replaceing the whole convergence board.
You should be able to find parts here.
Posted on Nov 07, 2008
I have an RCA D40W20 HDtv with the same 3d looking convergence problem. Is mine as easy to do as the Sony KP-51HW40 solution from 2 mnths ago?
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video or dead set) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. In some cases the TV will also not show any video. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D, wavy, or has a shadow or shadows
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION
You can get the correct parts, step by step photo instruction guides, and support from www.TvRepairKits.com or click here
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
Jan 26, 2011 | Sony KP-51HW40 51" Rear Projection...
Colors over lapping lll
convergence is off, convergence ICs need to be replaced
May 27, 2010 | RCA Scenium D40W20 40" Rear Projection...
The coaxial cable antenna broke on my RCA tv
The part is called a Female Belling-Lee Socket. Radio Shack, or anywhere that sells antennas, CB radios, repairs TV sets, should have one. Soldering it in, is another matter. Be careful.
Feb 04, 2010 | RCA Scenium D40W20 40" Rear Projection...
RCA R52WM24 NO CONVERGANCE
the convergence issue is caused by FL231, DL231 and CL230 the following link has the parts under the RCA category plus they help explain the repair procedure.
http://servicemanuals.vstore.ca/
Jan 30, 2009 | RCA Scenium D40W20 40" Rear Projection...
The problem is most likely due to a defective convergence IC.
There are two convergence STK ICs located on the convergence board.
You need first to test the ICS, by checking for continuity the pico fuses at the base of the ICs, then replace the faulty STK.
You should trying doing it yourself only if you are a proven electronic repairer.
Nov 07, 2008 | RCA Scenium D40W20 40" Rear Projection...
Have sound no pic. on 52 inch.
if you have some thin lines on the top of the picture probably you have a problem on the power supply for the convergence
Sep 29, 2008 | RCA Scenium D40W20 40" Rear Projection...
Rca d40w20 Hdtv
I suspect convergence ics part number startswith stks they are black and on a silver heat sink. if you could solder you could do it.If a tv shop fixed it the cost would be around 295.00. parts are 30.00 total. www.mcmelectronics has parts. to find out part numbers they are located on the board on the back.
thanks doctor video
May 18, 2008 | RCA Scenium D40W20 40" Rear Projection...
Problem
This is a terrible thing to tell you, but, what you describe is called dijitizing then the light engine failed Now it gets real bad ,,, This part 261589 is about $590.00 and is on factory backorder with no ETA in site. We have been waiting for one of these at our shop now for over 5 months. RCA knows about this problem and you might want to give them a call and see if they will do anything
Dec 17, 2007 | RCA Scenium D40W20 40" Rear Projection...
No convergence
Usually when that happens it is related to problems on the deflection board a diode or fusible link has opened making the set act like its a direct view thereby having no convergence option. It will take an experienced tech to properly diagnose that problem.
Nov 11, 2007 | RCA HD61W66 61" Projection HDTV
RCA Scenium D40W20 40" Rear Projection HDTV Logo
407 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
