Yamaha Full-Size Keyboard Logo
Posted on Mar 04, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
CVP -303 We are trying to use some of the alternate instruments for our musical - clarinet in paticular. As we are playing it will suddenly "smear" to a new key. And we cannot chnge it back. We are not using the pedals and it seems to do it with out warning. HELP!! Susan Nelson
Becketts Music Ltd
Level 2:
Novelist:
  • Yamaha Expert 167 Answers
  • Posted on Aug 07, 2018
Becketts Music Ltd
Yamaha Expert
Level 2:
Novelist:
Answers
167
Questions
Helped
65923
Points
403
Hold down top C key whilst turning, this initiates a factory reset so any settings you have made resulting in the smear should be returned to normal.
1 Related Answer
caroldon
  • 17130 Answers
  • Posted on Aug 24, 2010
SOURCE: My Clavinova CVP 305 Piano will no longer play the
The EPROM IC might be defective and might need a change but with the help of the Yamaha service.
Howeverr leave the set ON ffor several hours if you have not used or sparingly used.Sometimes moisture within the set can cause these issues which ccan clear up when the capacitors charge up or the board warms up.The interface is having some errors /conflicts that cause this conectivity.
So keep playing , do not switch off .
Hope this tip helps.
2answers
Purchased clarinet new last week:-- so hard to play -- PLayed the Buffet e13 before is this normal for a new wooden one? I feel like a beginner and so does the tone seem incomplete???
You don't mention what type of clarinet you have bought. Without this info I cannot answer or even guess, my guesses are very well educated, what the problem is.
Jun 01, 2015 • Music
Clarinet serial numbers
The Ambassador was their most successful student instrument. The serial number is usually on the back near the tenon joints. Olds Sons Serial Number Listings The link takes you to a list of their serial numbers and the dates manufactured.
May 06, 2014 • Music
I have a Yamaha Clarinet serial number 004828 what does that mean?
Serial numbers used to be used to tell the age of instruments. It seems now with Yamaha they are used as a tracking number for accounts purposes.
Wiring diagram yamaha cvp 303 clavinova
i have a broken cvp-85a but the pedals are ok so?
Jan 14, 2013 • Music
Need manual for CVP-700 english version
how opening yamaha cvp-700
Jun 30, 2012 • Music
When I play my Bass Clarinet, the bottom joint won't play the higher octave. It will play everything except the 3rd octave B-E. I can't find any leaks.
usually If a certain note doesnot play the note before it is not seating correctly. Check all pads that they are sealing behind the bad notes, also make sure the octive key is sealing.
2answers
I have a clavinova CVP 409. If I try to record using an external memory device (external Hard drive or memory stick, a message appears; DISC ERROR. Can you please help me solve the problem or direct me...
I SUSPECT that the CVP 409 will ONLY talk to the Yamaha USB floppy drive, not a hard drive or memory stick.
The internal drivers for these musical instruments do not have the "smarts" to talk to the wide variety of peripherals that PC's are able to.
1helpful
Problems setting midi channels using KN3000 and Cubase
If you are sequencing midi tracks you can imbed the patch change in the track and the midi channel assignment and when the sequence plays the info will be sent to the keyboard. Do you have it set to receive Omni?
Apr 23, 2009 • Music
Top Yamaha Music Experts
Paul Bade
Are you a Yamaha Music Expert? Answer questions, earn points and help others
