Question about Rio DDV2110 Dual Deck VCR
Tv codes I HAD A GO VIDEO#DDV2110 VCR AND I AM TRYING TO PROGRAM MY NEW SYLVANIA TV WITH THE RE MOTE OF THE VCR, BUT THERE IT NO CODE. HOW CAN PROGRAM MY TV TO MY VCR? DO YOU HAD LIST OF CODES I CAN TRY? -MY NAME THOMAS-- EMAIL----------TOMTHEMAN@OPTONLINE.NET
    Brigadier General:
  • 3,614 Answers
TRY:
004 008 009 062 068 069 074 075 076 077 133 161 163
Posted on Nov 07, 2008
    Sergeant:
  • 207 Answers
There are no Sylvania codes listed in the manual. So your only option is if a code search helps you out. Here is the procedure for a code search.
Programming the remote control
Automatic code search
This method can be used to automatically find the most appropriate code protocol for your appliance.
1. Switch on the appliance you wish to use the remote control with.
2. Press the relevant button for this appliance on the remote control, and while holding this button down, press
the standby button until the remote control light comes on. Release the two buttons.
3. Point the remote control at the appliance and press PLAY. Wait until the light stops flashing. If the appliance
has not gone into standby mode after five seconds, press the PLAY button again to continue the search for the
next set of codes.Repeat this operation until the appliance goes into standby mode. There are 20 sets of codes.
4. When the appliance goes into standby mode, press the standby button on the right up side to switch it on
again. Then press the REV button to put it back in standby mode, and if necessary, keep pressing until the
appliance goes into standby.
5. Press the STOP button and hold it down until the remote control light goes off.
Note: you can cancel the programming operation at any time by pressing the EXIT button.
Hope this Helps you Out
Dave
    President:
  • 2,712 Answers
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
  • 2 more comments
  • Swilin Sampson
    Swilin Sampson Nov 07, 2008
    Sorry, please ignore my previous post. You remotes uses 2 digit codes, and although I could not find one specifically for Sylvania TV, the best advice I can offer is to try all numbers from 00 through 99.
  • Swilin Sampson
    Press and hold the TV key on the VCR remote control while entering the 2-digit code for your brand of television with the 0-9 keys (see table below). If there is more than one code for your brand of television, try them all until one works.
    You can download the manual from here:
    http://www.retrevo.com/support/GoVideo-D...
    Page 4 gives you details on how to set up the remote..
    Dont forget to "ACCEPT" this solution if it helped!
  • Swilin Sampson
    Your remote does not have a 'standby' button, so the solution offered by teknowolf may not work..
  • Swilin Sampson
    Go through the manual:
How can i program a universal remote control for my sylvania tv?
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search
If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
Jun 16, 2012 | Sylvania Televison & Video
Tip
Dish Network Combo TV/DVD Remote Codes
CODE Broksonic TV/VCR 748 Goldstar TV/VCR 747 Panasonic TV/VCR 747 Quasar TV/VCR 747 Samsung TV/VCR 738, 755 Sylvania TV/VCR 756 Zenith TV/VCR 747 Aiwa TV/DVD 751 Apex TV/DVD 757 Broksonic TV/DVD 752 Konka TV/DVD 753 Panasonic TV/DVD 734, 765 RCA TV/DVD 749 Sansui TV/DVD 754 Sylvania TV/DVD 764 Toshiba TV/DVD 750 Go Video DVD/VCR 692, 693 JVC DVD/VCR 689 RCA DVD/VCR 690 Samsung DVD/VCR 738, 667, 691 Sony DVD/VCR 768
on Jun 06, 2009 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
I have no remote for the tv Sylvania 6313ce 13" TV/VCR. I am trying to program a rca remote for it so I can change the channel to 3 so the converter box will work, how do I do that
This particular TV may have the same code as a Magnavox,Emerson, Funai ,or Zenith. You will have to look in the remote control manual for these codes. This TV was put together by other manufacturers. And in many cases they program these to their origin! Thanks for asking and show a few hands of support!
Jan 11, 2011 | Sylvania 6313CE 13 in. TV/VCR Combo
I need the code for to program a universal remote to my tv
Hello
Three digit remote code for sylvania are:-
004/ 008/ 009/ 062/ 068/ 069/ 074/ 075/ 076/ 077/ 133/ 161/ 163
Four digit remote code for sylvania are:-
0062 0004 0009 0135 0189 0183 0227 0456 0008 0068 0075 0141 0161
Direct Code Entry
NB: Switch OFF and Switch ON the TV by its front panel POWER SWITCH [not by remote control handset] each time before trying an other code.
OK.
Jan 07, 2011 | Sylvania 6419TC 19" TV
Need Sylvania program codes for (CRK59B)RCA
I have the manual for the RCA TV that the CRK59B came with. The Sylvania VCR program codes are 08, 29. If you're trying to control a Sylvania Cable -TV Box, the code is 11.
Aug 28, 2009 | Televison & Video
Looking for the code for sylvania tv/vcr combo with a radio shack 3 in 1 universal remote
with most combo's try the VCR codes and then also program the tv code for the volume controls
if you are missing the programming instructions go to the RS website - support
Mar 14, 2009 | Sylvania 6313CB 13 in. TV/VCR Combo
Comcast Universal Remote code for Sylvania LC370SL8
10030 or 10054
  1. Turn on your device (i.e. TV).
  2. PRESS the button for the device you want to program (TV, VCR, CABLE, AUD, etc.) then RELEASE.
  3. PRESS and HOLD the SETUP button until the red LED for the selected device flashes twice, then RELEASE.
  4. ENTER the 5 digit code for your brand from the list above.
  5. You should receive 2 quick flashes on the LED for the selected device after entering your code.
  6. PRESS the POWER button to test the code. (On VCR,LD,and CD players use PLAY)
Dec 04, 2008 | Sylvania LC320SS8 32 in. LCD Television
Sylvania 27 in. tv/vcr/dvd combo remote code
find out who sales sylvania, look at what other tv they sale and try there codes. sears is good for this to.
Jan 07, 2008 | Sylvania 6727FDE 27 in. TV/VCR/DVD Combo
Need code for universal remote Sylvania LC320SL8
We bought a Sylvania LC420ss8 HDTV.
Our current universal remotes would not work, I followed the advice on this site and got a Sony
RM- VL600 Sony Untergrated Remote Commander, use page 16 in the manual to teach the new remote off of the remote that came with the TV. It really works. I am happy with the tv and remote.
Dec 07, 2007 | Sylvania LC320SL8 Television
Rio DDV2110 Dual Deck VCR Logo
70 people viewed this question
Top Rio Televison & Video Experts
Rommel Balcita
SHARCNET-USA
SHARCNET-USA
Jaime Hernandez
Are you a Rio Televison and Video Expert? Answer questions, earn points and help others
