Question about Panasonic NN-S963BF Microwave Oven
Microwave turntable will not turn
Microwave works fine but turntable does not turn
Panasonic NN-S963
  • che76 Nov 07, 2008
    I am not sure what the "terminal control" is. The plastic center piece turns readily in both directions. I tried turning the microwave off for 1 hour. The turntable still does not turn when the microwave is on.
  • che76 Nov 09, 2008
    We ended up removing the case from the microwave, found the little motor and replaced it. The turntable works fine now. The biggest hurdle was removing the security torque screws that held the casing in place. Thanks for the help.
    President:
  • 1,952 Answers
When you can't adjust the power level, there's probably a defective triac (a type of electronic voltage control) or a problem on one of the circuit boards.
Posted on Nov 07, 2008
  • mohammed marika thambi
    mohammed marika thambi Nov 11, 2008
    tecnician basic instruments is available they call remove the screw
  • 1,543 Answers
Replacing the stirrer motor is very easy.
  • 899 Answers
The motor or power to the motor may have quit , you would need to be able to check the motor and power circuit for it
if the platistic piece spins free , then it is not a motor or power problem and will need to be looked at to see what has happend
can you do this or will you need the assistance from an electronic repair shop?
  • jason Nov 09, 2008
    glad you got it fixed!
    Sergeant:
    Novelist:
  • 196 Answers
Off the microwave oven.remove all the utensils if present inside.and then remove the plate carefully as its made up of glass and can break so keep it properly.below the plate in the lower area you can see the tiny wheels attached to the plastic material.check out that tiny wheels are they worn out or looks like cracked or broken from somewhere.if not no then they r not adjusted properly to rotate frequently.just try to rotate it manually if it rotate properly then place the plate on in.then ON the unit and check it should work thanks.
    Brigadier General:
  • 3,614 Answers
Check the terminal control. if you still have no problem on the control.
unplug the unit for an hour to reset the unit itself.
  • Panasonic Master
  • 19,396 Answers
Remove the plate and check the gears underneath, many models have a belt or a dented gear that may be out of place.
  • Ginko
    Ginko Nov 07, 2008
    See this diagram: Counter top
    The turntable gear has notches that must fit with the wheel dents, you find this gears under the plate.
    Check if the gears are well in place.
    When there is no problem in there, that means that the turntable motor is gone and must be replaced, this is a quite delicate operation and should be done by a technician.
    Check also: The carousel won't turn
  • Ginko
    Ginko Nov 07, 2008
    I am not sure either about the meaning of check the terminal control. Probably the expert comment was directed to a different appliance and problem. Sometimes this happens.
    From description it looks more and more like there is need to replace the turntable motor.
    You can buy replacement parts from Vance baldwin, or call support using this form.
Panasonic nn ct766 turntable locked
If everything cooks as normal but the turntable does not turn then I would say that either the turntable motor has failed or the supply for the motor, either way this is not a problem you could fix yourself & so I would recommend taking to a microwave repair centre or service engineer.
Dec 26, 2012 | Microwave Ovens
Panasonic NN-P794SFR microwave unit that spins not rotating
there is a switch to turn it on or off. the turntable is replaceable
Feb 07, 2010 | Panasonic NN-P794SF Microwave Oven
Panasonic Microwave NN-S935BF turntable and light do not work. Microwave still works. Bulb and turntable motor okay. No power to light or turntable. Any ideas?
Your description seems to be confusing turntable and light do not work
Bulb and motor OK
Which is it?
They could be separate incidents. The drive motor could be fused and the globe just blew its life away..
Aug 15, 2009 | Microwave Ovens
Have a panasonic nn sa616w oven - turntable refuses to turn. Have cleaned the oven thoroughly and can't understand why it won't turn.
not sure on panasonic but most of them turn with a little gear drive. maybe the gear is stripped or off location.
Jun 07, 2009 | Panasonic NN-S753 Microwave Oven
Panasonic NN P794SF turntable does not work. Turns freely, no resistance.
Probably its open circuit or the power to it has been interrupted on the inside. Needs an inspection to be sure.
May 12, 2009 | Panasonic NN-P794SF Microwave Oven
Panasonic Microwave Model #NN-T993 displays fine and when I push the start button, the display shows it should be working, but turntable is not turning and is not heating.
Sorry to tell you this but some ones has to. Your unit is shot. the cost of repair out weights the cost of a new one. you can get a basic unitn 800 wates for a bout 89.00 you cant repair for that. Try looking at Thrift store;s you can find good clean working microwaves for $25.00 or less no kidding. happy hunting DFD
Apr 12, 2009 | Panasonic NN-T993SF Microwave Oven
NN-A574SBBPQ - Microwave fans & turntable not working
2 fuses in a panasonic does not sound enough.
have you checked the main incoming power protection fuse normally 10amp or higher.
most panasonics have approx 4 fuses so keep on looking
Feb 10, 2009 | Panasonic NN-S961 Microwave Oven
Panasonic dimension 4 microwave/convection oven
Does this unit have a turntable? If so does it turn when on?
Sep 24, 2008 | Panasonic NN-C980 Convection/Microwave...
Panasonic NN-S963BF Microwave Oven Logo
166 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
SHARCNET-USA
SHARCNET-USA
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
