Question about Acer AL1916W 19" LCD Monitor
My monitor will not stay on. When I turn it on it starts for about 5 second and then it turns off. I only have the time to see the ACER logo.
  • sofe Nov 10, 2008
    My monitor was working fine and one morning it just started doing that. The powering was fine per the screen, on my manual it was saying 110 volt and this is what I was using.
    Problem Solver:
What are you powering it with? I had that problem with a Daenyx which is 110 volt but uses a 12volt converter. The first time I tried it on 12volt was using a differnet cord and power from a charger. It would not work until I added a 12volt battery. The charger does does have a steady power flow it is sending 60 cycles per second - i wonder if your power source is not correct
Posted on Nov 07, 2008
My acer AL2416w monitor turns on to a black screen
I have 2 Acer AL2416W monitors that i have been using for 2 years. There has been a handful of times i would turn my computer on in the morning and the screen would be black and Acer would lightly flash on the monitor 1 time. Typically a restart would take care of the problem. Last week the monitor blacked out and i can't get it to work. Any suggestions?? I switched ports on the computer to verify it wasn't the video card and tried new DVI cables to verify it wasn't those? Is this fixable??
Sep 06, 2009 | AcerView 77E 17" CRT Monitor
Monitor goes black
Ok the issue with that is your hard drive has crashed so you need to get a new one for your laptop.
Jun 18, 2009 | Daewoo L700C 17" Flat Panel LCD Monitor
Acer AL1912 Monitor - Screen to black and light on yellow
I found some solutions other posted that didn't come up the first time I looked. I did a reboot and I'm good to go!
Dec 07, 2008 | Acer Computers & Internet
Acer LCD Monitor only displays "acer" logo
You are correct, it could be a power surge that has caused it.
Try this..
Unplug the monitor from the wall.
Remove all the video connections at the monitor end.
Wait 10 minutes then plug the monitor back into the wall (do not connect the video leads)
Turn it on and see if it goes past the ACER logo now. If so, replace the video cables and try the computer.
If not, then one of these will apply and a tech will be required..
  1. The internal bios has been corrupted.
  2. The power supply inside the monitor may have issues preventing the video board from starting correctly. This could be as simple as a few failing capacitors.
Number 2 is the most likely cause with an Acer monitor though. Any local tech will be able to correct it fairly cheaply, but phone around for quotes..they can vary a lot.
Jun 03, 2008 | Acer X193W LCD Monitor
My monitor turns itself off
If it's only a few months old then send it back under warranty.
The fault you have is the inverter circuit.
Hope that helps. =)
Apr 12, 2008 | Acer AL2032WD 20" LCD Monitor
Acer al1916 monitor goes black
You probably have a few dodgy caps on the power board inside. It's an easy fix if you are confident around electronics.
If not, pop it off to your local TV repair shop and have it taken care of now before it gets expensive with a complete failure.
Hope it helps =)
Apr 09, 2008 | Acer AL1916W 19" LCD Monitor
Monitor repeatedly flashes Acer logo and computer display in cycles
We had the same problem with the 17" we bought in Aug. Sent it back for repair. Acer sent it back without fixing the problem. Started doing it again in Nov. This time I called a supervisor and they sent me a new monitor. Well yesterday it started doing the same thing. You can fix it temp buy unplugging it and holding down the on-off switch for 30 seconds. Please let me know if you have a better fix.
Dec 13, 2007 | Acer AL1715 (Black, Silver) 17" LCD...
Black outs
May be your IP board is going out. Replace IP board.
Aug 25, 2007 | Acer AL1916W 19" LCD Monitor
Acer AL1916W 19" LCD Monitor Logo
137 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
