Question about GE Profile Spacemaker Over-the-Range Microwave
GE Profile Microwave JVM2070SH001 Turntable quit
The micro still works, but the turntable tries to turn and maybe gives a few jerks. It also makes a reasonable noise while on. When I turn the turntable off in the settings, it still heats, but without the nasty noise. Is it a gear, motor, belt - something like that? Is this a do it your self job? The micro is off the wall now, so easy to access .
  • neilgphoto1 Nov 07, 2008
    Yes - very quick response! Will order the part today!
  • GE Master
  • 19,396 Answers
First of all , before replacing the motor you need to check the gears underneath the turntable, if the turntable run for a while, then it is not necessarily the motor.
Secondarily, if you do not have experience in servicing, taking apart, and fixing home appliances, then bear in mind that replaceing the turntable motor on a microwave it is an operation that should be performed by a technician rather than by a home user.
Thanks .
Posted on Nov 07, 2008
    Brigadier General:
  • 3,614 Answers
Well as i see on the problem DIY will not apply. you better call someone to do the work for you. it very delicate for you to work on the microwave.
  • micromaster
    micromaster Nov 07, 2008
    if you have no idea or experience before to repair such microwave. it was not advisable to service it by yourself.. this will avoid further damage ang danger too...
    thank you for using fixya.,
  • 1,543 Answers
Easy fix. Take screws off the bottom cover to reveal the stirrer motor. replace. fixed.
  • Carl Schulzetenberg
    Carl Schulzetenberg Nov 07, 2008
    If you have the model number JVM2070SH001 which you posted under, then the part number you are looking for is a WB26X10136
Why wont my GE Spacemaker JVM1650 turntable wont work?
replace the turntable synchronous motor
look to ebay search for
ge jvm1650
then add turntable motor or browse down youll find a new motor
the coils inside may be duff
Aug 12, 2014 | GE Profile Spacemaker Over-the-Range...
GE Profile Spacemaker XL1800 microwave turntable
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
On some, you have to cut the motor cover off with snips, then use a screw when reassembling it.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Oct 28, 2013 | GE WB26X10037 Microwave Stirrer Motor
How do you turn off the turntable in a GE profile microwave
Some models have this option available (we would need to know your model number) but otherwise the only way would be to take apart the microwave and unplug the turntable motor, which I only recommend is done by a licensed technician. Give GE a call for more info at 1-877-959-8688.
Oct 08, 2013 | Microwave Ovens
My GE 1800 microwave turntable has stopped turning
There is a motor underneath the microwave that rotates the turntable. The motor may not be getting power or the motor may have failed.
Feb 11, 2013 | GE Profile Over the RanMicrowave....
GE Microwave oven turntable wont spin bushing can be tuurned freely and tray will spin when manually turned.
The turnable motor must be replaced, go to www.ebay.com Type: make and model of microwave oven, refine search to turntable motor.
May 07, 2012 | GE Profile Spacemaker Over-the-Range...
No heating, turntable does not turn, but clock & lights work.
Check to make sure the plastic on the shelve holders or tuntable guide did not wear and expose metal. If these holders or brackets are wore and exposed metal it shorted out your micro wave. They need to be replaced and a fuse needs to be replaced inside the control panel,
Sep 17, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE PROFILE SPACEMAKER MODEL JVM1350BW
There is a turntable motor that maybe bad you can access it by removing the scres on the boyyom of the uniot it will flip down on a hinge NOTE: you do not have to take down the microwave to do this. the motor should be getting 110v when on also make sure on your keypad it says Turntable on Some models have an option to turn it off on the keypad
Jan 23, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Turntable repair? GE Profile model JVM1660BB
IF EVERYTHING IN THE OVEN IS WORKING BUT THE TURNTABLE YOU HAVE TO TAKE THE BOTTOM COVER OFF THE OVEN THE MOTOR HAS TWO WIRES ON IT, BE CAREFULL
WHEN YOU TEST IT AS THERE IS 110V ON THE WIRES.IF THE 110V IS THERE BUT THE MOTOR ISN,T RUNNING TAKE THE
TWO WIRES OFF,AND TAKE THE MOTOR OUT AND BUY A NEW ONE. YOU CAN DO THIS BUT DO BE CAREFULL.. YOU
MAY HAVE TO PULL ON IT A LITTLE TO PULL IT APART FROM THE PEACE INSIDE THAT TURNS THE GLASS TRY NOT TO BREAK IT!
Jan 20, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
My ge profile spacemaker xl1800 turntable stopped it turns once in a while. What do I need to replace. Where can I find the part number?
It's probably a bad turntable motor or coupler.
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
Jan 06, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Profile Spacemaker Over-the-Range Microwave Logo
134 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
