Question about Philips DVDR70 DVD Recorder
Dvd clock the clock display on my dvdr gains by 2 minutes over a day or two even when i go into installation menu and set it up.
    President:
  • 3,130 Answers
I see that this is a 50Hz unit from the United Kingdom.. I first thought that this was an issue as I have seen before. Inside the unit is a small clock or oscillator. The adjustment or the asociated componets are most liklk at fault. The Microprocessor could also be at fault. This adjustment cannot be done without a frequency counter or an ocilliscope. If the unit is less then a month or so i would say take it back to the store or take the unit intp a repair shop and get it fixed under warranty. Good Luck Ps Please dont forget to rate this thread.
Posted on Oct 17, 2006
How doI set the clock
Setting the Time (Without Date Display) If your vehicle has an AM/FM base radio with a single CD player and preset buttons numbered one through six, the radio will have a clock button for setting the time. You can set the time by following these steps: 1. Press the clock button until the hour numbers begin flashing on the display. Press the clock button a second time and the minute numbers will begin flashing on the display. 2. While either the hour or the minute numbers are flashing, turn the tune knob, located on the upper right side of the radio, clockwise or counterclockwise to increase or decrease the time. Instead of using the tune knob, you can also press the SEEK, FWD (forward), or REV (reverse) buttons to adjust the time. 3. Press the clock button again until the clock display stops flashing to set the currently displayed time; otherwise, the flashing will stop after five seconds and the current time displayed will be automatically set. To change the time default setting from 12 hour to 24 hour, press the clock button and then the pushbutton located under the forward arrow label. Once the time 12H and 24H are displayed, press the pushbutton located under the desired option to select the default. Press the clock button again to apply the selected default, or let the screen time out. Setting the Time (With Date Display) If your vehicle has a radio with a single CD player or a CD with DVD player, the radio will have a clock button for setting the time and date. To set the time and date, follow these instructions: 1. Turn the radio on. 2. Press the clock button and the HR, MIN, MM, DD, YYYY (hour, minute, month, day, and year) will appear on the display. 220 3. Press the pushbutton located under any one of the labels that you want to change. Every time the pushbutton is pressed again, the time or the date if selected, will increase by one. • Another way to increase the time or date, is to press the right SEEK arrow or FWD (forward) button. • To decrease, press the left SEEK arrow or REV (reverse) button. You can also turn the tune knob, located on the upper right side of the radio, to adjust the selected setting. The date will not automatically display. The only way to see the date is by pressing the clock button when the radio is on. The date with display will time out after a few seconds and go back to the normal radio and time display. If your vehicle has a radio with a six-disc CD player, the radio will have a MENU button instead of the clock button to set the time and date. To set the time and date, follow these instructions: 1. Turn the radio on. 2. Press the MENU button. Once the clock option is displayed. 3. Press the pushbutton located under that label. The HR, MIN, MM, DD, YYYY will appear on the display. 4. Press the pushbutton located under any one of the labels that you want to change. Every time the pushbutton is pressed again, the time or the date if selected, will increase by one. • Another way to increase the time or date, is to press the right SEEK arrow or FWD (forward) button. • To decrease, press the left SEEK arrow or REV (reverse) button. You can also turn the tune knob, located on the upper right side of the radio, to adjust the selected setting. The date will not automatically display. The only way to see the date is by pressing the MENU button and then the clock button when the radio is on. The date with display will time out after a few seconds and go back to the normal radio and time display. 221 To change the time default setting from 12 hour to 24 hour or to change the date default setting from month/day/year to day/month/year, follow these instructions: 1. Press the clock button and then the pushbutton located under the forward arrow label. Once the time 12H and 24H, and the date MM/DD/YYYY (month, day, and year) and DD/MM/YYYY (day, month, and year) are displayed. 2. Press the pushbutton located under the desired option. 3. Press the clock or MENU button again to apply the selected default, or let the screen time out
Nov 10, 2016 | 2007 Pontiac Torrent
How do I set clock on c3 picasso
Press the "MENU" button for access to the main menu , then press the " ^ " or " v " buttons to scroll through the various menus: - radio-CD, - vehicle conf guration, - options, - display settings, - language, - units. Press the "OK" button to select the menu required.
Once the "Display settings" menu has been selected, you can gain access to the following settings: - year, - month, - day, - hour, - minutes, - 12 or 24 hour mode.
Once you have selected a setting, press the " << " or " >> " buttons to change its value. Press the " ^ " or " v " buttons to switch respectively to the previous or next setting. Press the "OK" button to record the change and return to the normal display.
Mar 09, 2015 | 2011 Citroen C3 Picasso
SET CLOCK ON JVC KD-200
Press and hold SEL (select) for more
than 2 seconds.
"DEMO," "CLOCK H," "CLOCK M," "DIMMER,"
or "AMP GAIN" appears on the display.
Set the hour.
1 Select "CLOCK H" (hour) if not shown on
the display.
2 Adjust the hour.
Set the minute.
1 Select "CLOCK M" (minute).
2 Adjust the minute
Sep 28, 2014 | JVC Car Audio & Video
How do you set the clock
Hello
To set the clock to your SV-dvd 3E:
Your DVD-VCR contains a 24-hour clock and calendar used to:
Automatically stop programme recording
Preset your DVD-VCR to record a programme
automatically
You must set the date and time when:
You purchase the DVD-VCR
Do not forget to reset the time when you change
clocks from winter to summer time and vice versa
[1] Press SETUP on the remote control.
Result: The MAIN MENU is displayed
[2] Press the corresponding up/down button or Forward/Reverse buttons to select the
CLOCK SET option.
[3] Press the ENTER button to select this option.
Result: The CLOCK SET menu is displayed
[4] Press Reverse or Forward button to select the hour, minutes, day, month and year.
Result: The option selected flashes
[5] Press the Up/Down buttons to increase or decrease the value.
Result: The day of the week is displayed automatically
You can hold the Up/Down buttons down to scroll more
quickly through the values
[6] On completion, press RETURN twice to exit the menu
OK.
Oct 10, 2011 | Samsung SV-DVD3E DVD Player/VCR
How to set time on jvc kd-r210
Setting the clock
  • Press and hold SEL (select) for more than 2 seconds. "DEMO", "CLOCK H", "CLOCK M", "DIMMER", or "AMP GAIN" appears on the display.
  • Set the hour.
  • 1. Select "CLOCK H" (hour) if not shown on the display.
  • Set the minute.
  • 1. Select "CLOCK M" (minute).
  • 2. Adjust the minute. Using the Control Knob
  • Finish the setting. To check the current clock time or change the display mode.
  • Press DISP (display) repeatedly. Each time you press the button, the display changes as follows:
  • • During tuner operation:
  • • During CD operation:
  • • During power off:
  • The power turns on and the clock time is shown for 5 seconds, then the power turns off.
Nov 11, 2010 | JVC AM FM CD DET FACE CAR STEREO
I need to change the time on it.
You can try the following steps
Setting the clock
1 Press and hold SEL (select) for more
than 2 seconds.
“DEMO,” “CLOCK H,” “CLOCK M,” “DIMMER,”
or “AMP GAIN” appears on the display.
2 Set the hour.
1 Select “CLOCK H” (hour) if not shown on
the display.
2 Adjust the hour.
1 2
3 Set the minute.
1 Select “CLOCK M” (minute).
2 Adjust the minute.
1 2
4 Finish the setting.
display mode
• During power off:
Thanks for using Fixya
Proton
Jul 27, 2009 | JVC KD-G200 CD Player
How do you set the clock?
1. Press and hold SEL (select) for more
than 2 seconds.
“DEMO”, “CLOCK H”, “CLOCK M”, “DIMMER”,
2. Set the hour.
the display by pressing the |<< o >>| button
Adjust the hour by turning the select knob.
3. Set the minute.
Select “CLOCK M” (minute) by pressing the |<< o >>| button.
Adjust the minute by turning the select knob.
4. save your setting by pressing SEL (select) button.
Mar 30, 2008 | JVC KD-G210 CD Player
Setting the Clock
1.In the stop mode, press and hold down the MENU/STOP button for at least 2 seconds
The menu setting display appears.
2. Press the SKIP/SEARCH button repeatedly to select dAtE
3. Press the POWER/PLAY button.
The year display blinks
4. Press the SKIP/SEARCH button repeatedly to select the year. Then press the POWER/PLAY button. The month display blinks.
5. Repeat the same step 4 to set the month, day, hour display ("24 H or "12H") hour and minute. Note: "second" cannot be selected.
When the minute setting is completed, "dAtE" returns.
6. Press the MENU/STOP button.
Nov 01, 2007 | Sanyo ICR-B60 Digital Voice Recorder
Philips DVDR70 DVD Recorder Logo
55 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
