Question about Sharp AR-5320 Black and White Copier
Stopped working My sharp copier just stopped copying and displaying a U on the screen after running continuously for 3000 copies
  • Melvinji Nov 07, 2008
    Problem: Stopped workingMy sharp copier just stopped copying and displaying a U on the screen after running continuously for 3000 copies
Try to see if there is a number appearing after u, maybe its u2-40 which is a toner problem since you run it continously. You can check it by pressing the copy button(green) and the sub code will appear. try to replace the toner cartridge and reset the copier by turning it off and on again, hope it helps
Posted on Nov 10, 2008
Hello, how to enter SP mode at copier SHARP AR122 ,AR152 ,AR153 ,AR157 , i need reset service call and developper change after 30K copies, or have anybody service manual to download ? please
Hallow, mostly when you see signs on the machine, its always good to obey their meaning for copier reliability. When the copy quality is good and the service and developer signs appear, you can continue working and ignore them but if they offend you, then here is the way to reset;
  1. Press C then density then C then density keys in that order. Display must go off if not repeat till it does.
  2. For service call reset, enter 20 then press copy key then 1 then copy key.
  3. For developer reset, repeat 1 above and enter 24 then copy key then 3 then copy key.
  4. Turn the copier off then on and the signs will not appear.
Dec 10, 2010 | Sharp AR-153E Copier
I have sharp mx 2700 .mechine is working but no display in the screen.i can make a copy .no display in lcd screen
Most likely the back light is blown out....try shining a flashlight down on to the displat and you might be able to see the display but this will reqire a qualified tech to repair
Mar 22, 2010 | Sharp MX-2300N Color Copier
How do I reset the developer counter? My SF-2035 Sharp copier showed a blinking developer light and flashing 0. I installed new developer, but the blinking light continues. How do I stop it.
open front cover enter (C interrupt zero interrupt)led must go off ,then enter 25 then copy key 2 then close cover press copy,copier will work about 3 minutes ,when stops turn off then on
Feb 24, 2010 | Sharp Office Equipment & Supplies
I was faxing a document and all of a sudden my copier stopped. The copy/quantity display is flashing L 6, what can I do to restart the copier. Thank you.
with the code showing press the start copy key and hold it this will give you the rest of the code most likely L6-10 laser unit service tech needed for that
Jan 12, 2010 | Sharp Office Equipment & Supplies
Pixma MP750 stopped working. Screen dead. Power supply OK.
My printer stopped working and it turned out to be the power unit.
Jun 11, 2009 | Canon PIXMA MP750 All-In-One InkJet...
Continued cycling but will not copy
Hello sir; the copier it will stop, give them more time, if it stop with a triangle light on that's means you need a toner motor to replace.
Apr 23, 2009 | Sharp AL-1642CS Copier
Printer has stopped printing copies even with a new toner and drum. Help!
Try the old one back in it? does that work if so Faulty unit take it back
Apr 23, 2009 | Sharp AL-1661CS All-In-One Laser Printer
My sharp copier AR-5320 just stopped copying and displaying a H
check main power supply socket and plug for blown out fuse,if it doesnt work open the cover on the left hand side to access the power supply board check the fuses if blown replace with the same rating.
Nov 27, 2008 | Sharp AR-5320 Black and White Copier
F2 error
"F2-31" Image density sensor fault "F2-32" Drum mark sensor fault "F2-33" Grid voltage correction problem "F2-35" Grid voltage correction problem "F2-37" Drum mark sensor fault
Sep 03, 2008 | Sharp Office Equipment & Supplies
No Copies
It could possibly be your main charge assembly. If there is no charge on your drum, it can lead to blank copies.
May 20, 2008 | Sharp AL-1641CS All-In-One Laser Printer
Sharp AR-5320 Black and White Copier Logo
48 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
