Question about LG LH-D6230 System
Error dvd the dvd cannot play it write error d.v.d
  • Anonymous Nov 21, 2008
    my dvd with a new dvd's 's or a recent movies displaies " disc error. can not read"
  • macanunes Nov 21, 2008
    Can you help me pls?
    My DVD LG LH D6320, display it a recent dvd's ( new movies) the error: Disc error...
My emerson ewr20v4 plays cds with music but not dvd with movies. It keeps displaying disk error
check and see if the dvd player needs to be cleaned. you can pick up contaminates from other dvd's or cd's get yourself a dvd disk cleaner and run it thru seveveral times . and try to play your money then.
May 09, 2014 | Emerson EWR20V4 DVD Recorder/VCR
My 2001 Landcruiser will not play dvd/cd. It gets
I have the same exact problem:2001 Landcruiser will not play dvd/cd. It gets stuck. Display of dvd error shows. DVD can not eject. Please let me know if you got it to eject. I tried disconnect/connect the battery for full 5 minutes but did not help.
Apr 20, 2010 | 2001 Toyota Land Cruiser
DVD Player stops reading disc Error message :
usually this happens when lens cannot read the the disc. Due to few reason 1 Your disk is scratched 2 Your DVD lens is covered with dust 3 You need to replace DVD lens
Try another few CD/DVD to rectify whether there is any problem with dvd you are trying to play
if this error occurs on all the dvd you played then the most likely proble is with your DVD lens either its coverd with dust use Disk cleaner if not you got to replace a new DVD lense as per model
Feb 18, 2010 | Samsung DVD-V9800 DVD Player/VCR
Check disc error
When you get a please check disc error when playing a DVD in your DVD machine, this is a signal that the lens of the DVD machine is getting weaker. I would ask you to try and play a CD in that machine. If it plays that means the lens of your DVD machine is weak. You have to change or purchase a new DVD machine.
Oct 17, 2009 | Marantz DVD-930 DVD Player
Aspire one running cyberlink 8.0 plays dvd, but
Verify your DVD player and Sound card is listed without errors in device manager. If there are no errors, try to play the dvd with another program such as windows media player just to try and narrow down the possibilities
Aug 30, 2009 | CyberLink SW- DVD Software Power DVD...
HO3 error panasonic DVD-LS80 disc will not play?
como hacer funcional el lente del equipo, tengo un error h03 VDV-LS80
May 26, 2009 | Panasonic DVD-LS80
Solutions to incorrect disk error c105 & c104
Hello gjbrokke,
First make sure the disc is compatible with the dvd player (CD-R+ , or CD-R - )
Second make sure the region code of the dvd you burned is compatible with the dvd region settings on your dvd player.
One of those two are preventing the disc from playing in your sansui player.
May 19, 2009 | Sansui VRDVD4005 DVD Player/VCR
Cannot play error
I try to pay a dvd and the "cannot play disc" error comes up.
Mar 20, 2008 | Sony DVP-NS315 DVD Player
DVD WON'T PLAY ERROR CODE 17 &12
the d2 does NOT play dvd's,the dvd rom slot is for the navigation disc ONLY. you must hook a dvd player to the RCAs.
Oct 02, 2007 | Pioneer AVIC-D2 DVD Nav/6.5"...
LG LH-D6230 System Logo
64 people viewed this question
Top LG Audio Players & Recorders Experts
PNiss
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
