Question about Kenmore 25512/ 25513 Progressive Canister Vacuum
Kenmore progressive canister hose cleaning
Contractor used household vacuum during construction.
How do I clean the hoses and tubes? They are filled with spackle-dust, white and very powdery...blows everywhere.
Thanks.
    Problem Solver:
  • 16 Answers
Remove hose take it outside and flush with TSP solution then rinse with water (garden hose) let dry. spackle dust and drywall dust are water soluble and will not hurt your grass.
Posted on May 09, 2009
Kenmore 25614/25615 Progressive bagged canister vac won't start
sounds like there was a loose connection or loose wire that came in contact with another wire. check your cord for small burn holes, also could have shorted out in the hose or the wand. If you are comfortable to disassemble the vacuum i can walk you through the troubleshooting process so we can find out what actually went bad. id start with the cord though. let me know if you have any questions or need more assistance
Jan 04, 2010 | Kenmore 25614 / 25615 Progressive Bagged...
My Kenmore Progressive is making a noise that sounds as if something is blocking the suction. I have checked the tubes and can't find any obvious blockages
Have you changed out the bag? Checked the air filters? When you run it and hold your hand over the hose opening, do you feel suction?
Check the head for blockages, you said the tubes are good, so check the hose, if no obstructions there, open the canister and check the bag, if it's full change it, if not, pull it out and check the filter that's under the bag, if it's not clogged re-run the above steps but this time look for possible vacuum leaks. Let me know if this helps.
Oct 19, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Kenmore progressive canister bad connection from hose to canister
It could be, the female part of the connector is stretched open. You can usually insert something, like a dart, between the sleeve and the holder, to tighten it. If you paid with Pay Pal, see about getting your money back.
Jul 07, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Flapping noise behind where hose wraps up/suction but junk sticki
you have a clog in the hose take the screws out of the hose retainer and take a yard stick and run it into the hose to get the clog out
Jan 24, 2009 | Kenmore 31913 Progressive Direct Drive...
I have the upright kenmore progressive with direct drive and the filter canister stops bringing in air and picking up when hose is put into vaccum, when you remove hose and use as an attachment it starts...
Check the hose after the brushes. With this problem there is normally a clog in between where you disconnect the hose (to use attachment) and the brushes that clean the carpet.
Dec 21, 2008 | Kenmore 31913 Progressive Direct Drive...
Lack of suction
I use a broom handle..works very well
Nov 26, 2008 | Kenmore 23612 Progressive PowerMate Bagged...
Model 116 hose clog?
http://geeksquad.fixya.com/ThreadView.aspx?prdid=109459&thid=699656
Posted by rfrazelle on Jun 23, 2008
My old canister model 116 followed with numbers 2839580 marked Kenmore 3.9 with power-mate, worked fine until the bag got overly full. I have changed the bag, cleaned the filter, and removed a nasty hair/fur/dust clog :-p from the lower metal tube of the power mate. It now has very weak suction and won't pick up anything. I suspect a clog in the grey plastic flexible tubing attached to the canister but cannot get it apart. Advice?
RJ
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Kenmore 22313 Bagged Canister Vacuum. The best way to find a clog in an electric hose is to use a steel ball or a large marble to place inside the hose and to let it so threw as far as it can to determine where the hose clog is. Once you have determined where the hose clog is then you can use a small end of a broom handle of take an old wire coat hanger and place a hook on the end and try to pull the clog out of the electric hose – the electric hose is very expensive so try not to damage the hose in any way, shape or form. Or another way is that id you have another canister vacuum you can try to pull the clog apart by using two vacuums turned on and running. If you are successful then run the round marble or steel ball thru the hose again and the clog should be cleared.
http://www.sears.com/ Customer Service 1-800-4-MY-HOME 1-800-469-4663
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 23, 2008 | Kenmore 22313 Bagged Canister Vacuum
Kenmoore Canister 25812 Failure
Some of the powerheads have a circuit breaker on the top of it. Just push it to reset. May have a bad circuit pcb in the hose handle.
May 21, 2008 | Kenmore 25812 / 25813 Progressive Bagged...
Kenmore 25512/ 25513 Progressive Canister Vacuum Logo
138 people viewed this question
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
