Question about Canon PowerShot S70 Digital Camera
Replacing a battery cover
Anyone have any idea if replacing a battery cover on an s70 is a complicated project. I've just ordered a new one but couldn't find a repair manual online.
  • oraclebooks Dec 26, 2008
    Battery cover replacement, how do I do this?
I have the same problem with my camera. Mind telling me where you got a new battery cover? :-) I need one!
Maybe you have already found out how to replace the cover, but anyhow, here´s what I think:
I have looked closely at the cover and it seems like you should be able to just loosen the only screw on the inside of the cover and then you should be able to just slide the cover off and replace it with your new one. :-)
Hope this helps! :-)
Posted on May 01, 2009
How do I replace the battery on my 2010 KLX250s
remove retaining strap and remove + and - wires then pull battery , fit new battery , connect red wire to + and black to the - which is indicated on the top of your battery ! re fit retainer , cover and start your bike !... P
Dec 01, 2013 | Motorcycles
V200d02 tail spin
The electronics are defective that control tail motor speed.
Jul 11, 2017 | Toys
I recently got a quote to replace all four brakes, install a new water pump and replace a bearing on the front tire for my 1998 s70. The quote for all of these was almost $1500. Is this at all reasonable?
Replacing all brakes - disks and pads included - about $600
Replacing a bearing on the front - about $350
Replacing a new water pump - pump included - about  $700
As you can see your quote is a good offer but if you search around you might get an even better one.
Jul 08, 2010 | 1998 Volvo S70
S70 instrument cluster not working
I had a similar problem. The speedometer didn't work. This is going to sound a little strange, but, at some point the battery died. When the new battery was put in, all of a sudden the speedometer worked again. Can't explain it, but it's true. Maybe just disconnecting and re-connecting the battery would help you, BUT BE CAREFUL about the radio. When the battery is disconnected (or dies) you have to put the radio code in again to use your radio. Make sure you have the 4-digit radio code before you disconnect the battery. If you enter it 3 times and fail, google what to do then.
Dec 04, 2009 | 1998 Volvo S70
I have 5 codes on my 98 s70 volvo. the codes are p0305,p0303,p0301,p0300, and p017. Needing suggestion on what I need to do in order to have this fixed. Thanks.
Try replacing the spark plugs and I HIGHLY recommend factory plugs, they run way better and last way longer. From LOTS of personal experience. Plugs are the most common cause of misfires in a Volvo
Aug 10, 2009 | 1998 Volvo S70
Sound but no picture after fixing fl231
Go back over to SSB board the one with tuners on it check fuses next to tuners ,if you have to order ssb board they are 252.00
Nov 27, 2008 | RCA R52WH73 Projection Television
PRO-520HD Tv will not stay on
you may have short in convergence circuit but this is a job for experienced tech after replacing ic's need to get in to settings and and is kind of complicated
Mar 18, 2008 | Pioneer PRO-520HD 53" Rear Projection...
How doi adjust convegence manually on phillips 55pp9401
Order service manual from ..........
procedure is complicated..............T.
Dec 08, 2007 | Philips 55PP9401 55" Rear Projection...
Canon PowerShot S70 Digital Camera Logo
104 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
