Question about Roxio Easy Media Creator 7
Roxio dvd disk type doesn't match project type
When I try to compile and burn a dvd, I get an error message telling me the disk type does not match the project type - another window then pops up and tells me to insert valid media. I have used this program before and it worked fine. I have uninstalled it then reinstalled it. I have tried to repair it-it just reinstalled it again. I have converted my video clips from MPEG to WMV format and still didn't work. I installed an Express Burn program and it hangs up after it begins burning - about one-third of the way. I don't know what to do - help!
Les
  • Anonymous Mar 24, 2014
    I am trying to burn several songs unto a CD-R. The first song will burn. When I try to burn the next song I get an error that says: This Drive does not support this Disc type.
  • 73 Answers
Check the following parameters
- Type of disk--> it must be a DVD RW disk (Read and write), if the media is only DVD R, you can't burn it
- Your DVD driver--> Check if it accepts DVD RW(-) or DVD RW(+) or both. With this information, check if the media matches the driver capability
- Roxio settings--> In the Main Menu select--> Disc--> Disk information--> confirm that the right driver is selected (drive D or E or the letter your computer uses for the DVD driver)
Posted on Nov 07, 2008
I am having issues burning dvd or blue ray from my mac with adobe premiere elements. It is an external burner connected via USB works fine with final cut but has error message with elements. Says " device...
Try burning an iso image file instead from the program, then you can use the built in mac software to burn that disk image file to a disc. Sometimes in video editing there is a problem with the process of compiling the video to a disk. Try a simple very short project with a dvd-rw (reusable) disc to see if it still gives the error.
Apr 11, 2014 | ASUS Computers & Internet
In Roxio Creator 10, I attempt to burn a disk of a slide show. I receive an error message 8004520C When I check production it reports no problem. This is repeatable.
Generally, defragmenting your hard disk will resolve this issue. To defragment your computer:
  1. Go to Start--> Programs --> Accessories --> System Tools --> Disk Defragmenter.
  2. When the Disk Defragmenter window opens, choose Defragment.
If defragmentation doesn't resolve the issue, burn your project as a data file, and then burn your project as a data disc using Disc Copier or Creator Classic. To create a disc image/data file:
  1. After clicking the Burn button, the Burn Project window opens.
  2. You have two data burning options:
    • Image file - this option will save your project as an .ISO file. To burn this file you will need to use the Burn Image option in Creator's Copy section.
    • Folder Set - burning a folder set will create a Video_TS folder that you can burn using Creator Classic. Burning a folder set to DVD will create a fully functional DVD. Do NOT rename the Video_TS folder other wise it will not play! Simply place it in a folder that is the name of your project if you need to keep track.
May 25, 2010 | Roxio Easy Media Creator 10 Suite
I am trying to burn a project to DVD and I get halfway through 3 times now and get a windows fatal error that shuts down the program - help
1. Do a DISK CLEAN UP, then a VIRUS SCAN...
2. Uninstall and reinstall the application
3. Make sure you have enough space on the HD
4. Close all programs while trying to burn the DVD
Mar 14, 2010 | Roxio Easy CD & DVD Creator 6...
Invalid book address
this is to do with settings in Nero.
The book-Type is settings For CD/DVD et,c.
The actual Format the disk has to be written in. If you,ve got the book-type set to write a CD for example, and burned a DVD. it would error as it needs to write more data, than the Disk Allows.
CD 650mb. DVD 4370 mb or equivalent.
I,d uninstall-re-install nero, and ensure you select your type of disk to Compile. Which will automatically select The Correct Book-Type for The compilation required.
Mike @ Compurepair.
Oct 22, 2009 | Computers & Internet
I have spent MANY hours developing a nice video. When I go to burn to an image file I get an error message: "Encoding Error 8004520c". I have tried many times. I have defragged. Updated video and...
Here You can find a free mpeg converter for any type of files. What kind of file do You have? If it's .avi, probably Roxio creator cannot burn it because it is too big, and if You nave the menus on Your future DVD, I'm sure the reason is the size. On Mac it's easy. With toast titanium, You can select an option fit-to-DVD, and the video fits on standard DVD. Probably, the default compression options in Roxio aren´t sufficient. Try to search in advanced options compression level, or, You can convert with the MPEG Streamclip the video to mpeg video, by selecting a different level of compression, and then You can offer this file to Roxio. Try this. If it not helps, drop me a message.
Sep 10, 2009 | Roxio Creator 2009 for PC
Cannot burn AVCHD disk. Get this error
The problem with creator 2009 has been fixed by the roxio people.
Instead of burning directly to the DVD disk as roxio software states,
one needs to first save this to be AVCHD movie as a file and then burn directly from the file. This works OK, but as stated this is different
from what the software claims. I'm happy. Thanks
Aug 01, 2009 | Roxio Creator 2009 Ultimate for PC
Error when attempting to write disk
Sometimes the driver that is used to burn CD's gets corrupted, you should try removing and re-installing roxio. The only other possibility is a bad CD burner drive, but these are dirt cheap to replace these days, you should easily be able to find one under 40$.
Jan 20, 2009 | Roxio Easy CD & DVD Creator 6...
DVD not copying
Try a different media brand.
Dec 30, 2008 | Roxio Easy CD & DVD Burning
Trying to copy a DVD
Sometimes different DVD software and DVD writers are picky with the type of DVDs that you put in. Try a different brand and see if that makes a difference.
Nov 26, 2008 | Roxio Easy CD & DVD Burning
Roxio Easy Media Creator 7 Logo
221 people viewed this question
Top Roxio Computers & Internet Experts
Are you a Roxio Computer and Internet Expert? Answer questions, earn points and help others
