Question about Canon i860 InkJet Photo Printer
Canon i860 "printer offline" but light is blinking
The printer says "offline" and there is no option to put it "online". Also, when I go to print, the light flashes green as if it's about to print, then it stops and I get the "Error; printer offline" thing. When I go to print monitor, the Canon i860 is there twice. The main one isn't an option, though there is a green check mark next to it. The one that is a highlighted option is the Canon i860 Copy1. Frustrated..... Any suggestions?
  • wendywendy Mar 20, 2009
    I have the same problem, but I have a Mac... I can't find a menu or control panel where I can switch it to online.
  • Anonymous Mar 12, 2014
    My Canon MG3222 printer keeps going offline. It is ok for a couple of days, then this happens. What do I do to keep it online?
Move mouse pointer on to your printer icon in the Printer folder. Does a right click and click on the sixth line of the menu (“Use printer on line”). Then it will change as “Use printer offline”. Make sure the printer is set as default printer.
Posted on Mar 21, 2008
    Scholar:
  • 161 Answers
Printer off line means it is not set to print. You need to set it to online either with a lever or a button. It will go online and then it will print. It doesn't mean online like on the net just online ready to print with your computer.
Posted on Aug 07, 2007
  • Jessie Goss Aug 07, 2007
    You may just need to make it your default printer. Click on printer in the control panel and choose this printer as default. Delete any other printer that isn't in use.
    President:
  • 2,961 Answers
Go to you printer icon in the printers folder, right click on both printers mentioned and cancel all documents. Firsly disconnect printer from usb or parallel port. Next uninstal both printers as the copy one refers to a second installation.(right click, then either uninstal or remove) Insert your cd driver disc and install driver, then when prompted connect printer. If again this fails, then either try another cable or connect in another port.
Posted on Oct 17, 2006
  • 59 Answers
First go to your PC. Press start, settings, printers and fax. Right click the printer icon and you can turn it online from there. there is most likely no online button on the machine itself.
Posted on Aug 10, 2007
Canon i1500 trying to print collecting printer status
Posted on Oct 11, 2009
4 Suggested Answers
SOURCE: canon pixmaip3000 states printer offline & does not print, flishing power lights green & orange
I have canon PIXMA ip3000. After power cut at night printer doen not print. I re installed the drivers but no result. When try to print message appears printer is offline. POwer button is flashing shorthly green after orange lights. Error code 5100.
Please advice what can I do urgently.
Posted on Mar 12, 2008
SOURCE: Canon Photo Printer iP4500
buy new printer
Posted on Sep 05, 2008
JongCur
  • 88 Answers
SOURCE: canon i860 error codes
Try this: With your i860 printer turned ON, press and hold the I/O switch then pull off the power cord. This will turn off your printer. But without lifting your finger on the I/O switch put back your power cord. the I/O switch will blink for a second and will go off, then turn-on your printer again and see if it works.
Posted on Oct 06, 2008
Printer offline
Depends on your OS you need find "printer and faxes" or "printer options on the hardware.
  • Open the Start menu and click on the "Devices and Printers" icon. This will open a window with a list of the printers currently set up on your computer.
  • Double-click on the icon of the printer you want to change to online. The status of the printer will be shown as either "Printer: Ready" or "Printer: Offline."
  • Click on "Printer: Offline" and the Printer menu will appear. Click on "Printer" in the menu bar and uncheck "Use Printer Offline." This action will change the printer from offline to online.
May 12, 2013 | Office Equipment & Supplies
I have got Canon i560 printer but not recieving print order the software is loaded what is the solution ?
Try i560 Reset Procedures for Canon i550, i560, i850, i860, i865, i9100, i9950 Printers
  1. Turn off Canon i550, i560, i850, i860, i865, i9100, i9950 Printers
  2. Hold down Resume button and press Power button.
  3. Keep holding down Power button and let Resume button go.
  4. Press Resume button 2 times then let BOTH buttons go.
  5. Green lights will flash and then stop blinking.
  6. When green lights are solid, press the Resume button 4 times.
  7. Press the Power button and the printer should turn off, if not, press the Power button once more.
  8. Your Canon i550, i560, i850, i860, i865, i9100, i9950 Printers should respond as normal.
Pl let me know if this works
Nov 12, 2010 | Office Equipment & Supplies
Receiving consistence "printer offline" message. Printer will not print although the printer is on and is properly connected. Have checked it with the pc and the laptop. The printer is fine. Is there...
Go to your Control Panel from the Start Menu. If your OS is Windows XP Click on Printers and other Hardware. Right click on your Canon Printer you are using .Scroll down to Properties. Click on Properties . It should give you the option to put the Printer in question "Printer Online". Click Printer Online. That should remove the option from Offline to Online .Then try to print from your Printer.
Jul 31, 2010 | Canon PIXMA iP1600 Printer
My Cannon i860 is blinking an amber light five times and then returns to green then blinks amber five times and so on. What is this error telling me?
I too went through all the cleaning processes on my i860 with its amber light blinking five times to one of green. After all that time and effort, I ordered a new head, replaced it, put the old ink carts back in, and presto, worked like a charm. Don't waste time and money doing anything else.
Jul 25, 2010 | Canon i860 InkJet Photo Printer
My printer blinks orange 5 times and them blinks green once ,and doesn't print anything at all
CAN YOU PLEASE REMOVE CATRIDGE AND SWITCH OFF THE PRINTER
AGAIN SWITCH ON THE PRINTER
PUT BACK CATRIDGES
CHECK BACKSIDE OF THE PRINTER
CLEAN
Oct 30, 2009 | Canon i860 InkJet Photo Printer
Canon pixma ip 3000 error message printer is offline
If the orange lamp blinking only it's the print head is not installed, or it is not properly installed.Open the cover remove the print cartridges then remove the print head and put back it on.If not help the print head is defective and need replace.
If the orange lamp blinking with green alternately it's ASF (cam) sensor error.The problem is in sheet feed unit.
Oct 15, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Canon i860 printer not working
The error code says that your printhead is bad and needs to be replaced. QY6-0049-000 around $40.00
Jun 30, 2009 | Office Equipment & Supplies
After a month or two of disuse my i860 6BK cartridge will not print. On a nozzle alignment printout the 6bk color bar below the 6y bar is absent. The square labeled "F" in the lower part of the printout is...
Hi
You can try this I found.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Mar 03, 2009 | Canon i860 InkJet Photo Printer
Canon i860 error codes
Sep 15, 2008 | Canon i860 InkJet Photo Printer
I860 False Paper Jam Message
Check the back of the printer. There should be door at the bottom. Your paper jam could be there.
If this helps you, please rate me. Thanks, Patty
Nov 06, 2007 | Canon i860 InkJet Photo Printer
Canon i860 InkJet Photo Printer Logo
9,657 people viewed this question
Clive
Clive
old marine
old marine
