Red glare on my projection tv model # pt5598hd
  • duvalqt87 Nov 17, 2008
    Thanks I will have my husband try it when he gets home.
  • 85 Answers
Dirty lens on red crt look down in it and see if there is a mold like substance growing in it. a bad red crt may cause this
Posted on Nov 14, 2008
AKAI PT5598HD will not turn on.
if you got to the following link and search by the model number you will find what your looking for.
Http://www.samsungparts.com/search/search.asp
The part number for the service manual is SM-PT5598HD
As the set is showing a blinking red timer light. you can check the following link out.
http://www.techlore.com/article/15444/
May 13, 2008 | Akai PT5598HD 55" Rear Projection...
Akai PT5598HD 55 in. Rear Projection HDTV-Ready Television tv looks like it is now 3d model with red out by about a half inch. will not adjust on converage settings
sounds like your convergence board has failed ...there may be a kit at tvrepairparts.com..there you can search your model number for a convergence repair kit...you will need to have someone with electronics repair experience install the parts if you do not know how yourself...these kits range from 40.00 to 100.00 and usually come with a cd or dvd to aide in installing these components.
Dec 20, 2010 | Akai PT5598HD 55" Rear Projection...
My Akai TV Model number PT5598HD shows two of everything, how do I fix this?
U can't.Ur convergence is dead.Try website Tv repair World.com to buy a Convergence board to replaced.Well solved the convergence problems.The Samsung/Akai use the same convergence board.
Feb 15, 2010 | Akai PT5598HD 55" Rear Projection...
Tv works but has red glare on screen
You have contamiated fluild in red tube remove old projection fluild and put in New this should then give you a clear picture. call Mats for projection fluild 1-800-628-1118
Sep 18, 2009 | Televison & Video
Akai 55
I used" Silerado 1st" solution. I have an Akai pt5598hdix/sms.
I had ghosting.Like 3 colors side by side.
Silerado said with TV off press "mute,1,8,2" then TV on.
I didn't see anything like a menu.He warned to write down any setting you saw before you change anything.But for me nothing came up. So as he said the next step try with TV "on" press "Mute,1,8,3" this is another set of adjustments for finer detail. I lined/overlapped all the lines up or down or side to side useing the channel and the volume buttons and then held the enter button down until the TV flashed 3 times.Then I shut it off and when I turned it back on It was perfect.
Thomas Fitzgibbon
Mar 23, 2008 | Akai PT5598HD 55" Rear Projection...
Won't turn on
If you're using a DVD player or other component using the Component cable hookup, try unplugging that from the mix, unplug the power cord for the TV from the wall and wait 15 seconds and plug it back in, then power the TV back on. Mine used to do this and I gave up on the component cable option and went back to composite (RCA).
Feb 09, 2008 | Akai PT5598HD 55" Rear Projection...
REAR PROJECTION TV NOT TURNING ON
I just got this tv free and it will stay on for 15-30 minutes and then turn off. Some times it will stay on all day, though, so its kind of weird. I have the 5499HD
Dec 29, 2007 | Akai PT5598HD 55" Rear Projection...
Akai PT5598HD
· http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
· http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 17, 2007 | Akai PT5598HD 55" Rear Projection...
AKAI PT5598HD ghost image the red is offset
Replace STK392-040 IC's with name brand only. No generics.
I use Panasonic brand with no recalls.....Let me know if you
need more help.......................T.
Please rate this solution...........thanks.
Nov 11, 2007 | Akai PT5598HD 55" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
