TV turns its self off as soon as I turn it on.
  • 85 Answers
A shorted horizontal output transistor, high voltage divider shorted crt a variety of devices needs to be dug into
Posted on Nov 14, 2008
My Tv turns on as soon as you plug it than runs with a perfect picture for 1 mint than off & back on by it self & runs for about 5 mints than turns back off & doesn't turn back on until I unplug it!
The inside of your projection tv is dirty. Clean the bulbs but leave no fingerprints or oils on the lamps. Clean the mirror while you are inside it as well for a much brighter picture.
Mar 20, 2015 | Televison & Video
Toshiba Flat Screen TV Model TZ61V61 Serial #23960912 problem with wiggles and shadows in the corners
Could be video card or screen its self. Does it start out with distortion as soon as tv is turned on or does it distort as it warms up?
Mar 01, 2015 | Toshiba Televison & Video
Why the tv come on but a min after the red blinking come on an it turn off by it self what the problem?
tv had found a fault to troubleshoot use model number and search for the fault code on manual.some indicator may blink several times to release the symptom.
Dec 21, 2014 | Philips Televison & Video
Tv turning on & off by it self
There is a short circuit to its main board. Might be a shorted component, like IC or so. The system control IC detects this short circuit as soon as you switch it ON, it send a command to the main power supply board to shut it down, to prevent further damage. That is happening here. Your TV need a thorough check-up. Will be best to contact any service technician.If you wish to get some details, check the site linked here. Pull up older posts.
Dec 08, 2013 | Emerson LTDN42V68US 42" Class LCD HDTV
Samsung 50"dlp turns on&off by it self as soon as i plug it in
Sounds like a thermal problem. Check this link for more details.
Mar 04, 2013 | Samsung DLP HL-P5663W 56" TV
My tv turns on and has a picture, but soon will turn off, after a while will come back on but then turn off
hi there, try to check your power cord for any loose wiring or cut portion. If none I suggest you better inspect the power supply and check if there's any deform or bulgy capacitor. You can self repair it by replacing the capacitor by soldering it.
Hope it helps. please rate and vote.good day
Mar 21, 2011 | LG 32LC2D Television
TV screen turned on for only 10-15 secs then self turn off, followed soon after by the tv power another 10-15 seconds later. if i try this a few times screen wont light up at all.Is it the TV Lamp?
1) Can be dust do a good clean
2)Check for the fuse and change it if needed.
3) Capacitor needs to be changed, you'll have to findout which one.
Hope it helps, good luck
May 19, 2009 | LG RU-52SZ51D 52" Rear Projection...
PIONEER PDP-424MV Plasma TV
I have the same TV, well, nearly, PDP434.
The only part I ever sell for these is the main PSU (power supply).
The TV "checks" it self using a self diagnostic system. As soon as it discovers a problem, it shuts down and blinks an error code on the front LED.
It always seems to be the PSU.
I hope this helps at least a bit.
Mar 28, 2009 | Pioneer PureVision PDP-424MV 42 in. Plasma...
Mits 62525
take the lamp back out and reset the lamp
Dec 27, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Televison & Video Logo
95 people viewed this question
Top Televison & Video Experts
