Question about Kenmore 62602 Electric Dryer
Please help kenmore electric dryer wont heat i replaced theromostat still wont heat check fuse box and cleaned vent still no heat
  • 62 Answers
Heating element
Posted on Nov 09, 2008
Why doesn't my Kenmore 110 98575120 dryer heat up?
Most likely the thermal fuse is bad. Here' the part as well as a video of how to check it. http://www.repairclinic.com/PartDetail/b6p17/Kenmore-Washer-Dryer-Combo-Thermal-Fuse/3399849/527775?modelNumber=110.98575120&ss=a17b6d170762&mr=1
You'll need to remove the back panel of the dryer to get to it. It'll be located on the outlet duct neat where the hose hooks up. Don't forget to clean out the vent all the way to the outside. Poor airflow is why they fail. If your vent is clear than replace the t-stat on the heat element as well as the fuse.
Hope this helps. Good luck,
John
Mar 22, 2015 | Kenmore Dryers
Kenmore Elite Oasis ST electric dryer does not heat
You need to replace the heating coil that is usually the problem when you get air and and the tumbler is moving but no drying you can also check the lint catcher and clear out your dryer outgoing vent remove the hose check the dryer vent where the vent hose is connected and the vent going outside the house before changing the heating coil .
Sep 04, 2014 | Kenmore Elite Oasis 6808 Electric Dryer
Is there a theromostat reset button on an Asko TL751 Electric Dryer
Have you clean the air vent out the one leading to the outside? One time we had one do the same thing because the vet was blocked it heated up to quick and sent the the message that the clothes was dry. I hope this helps
Sep 16, 2012 | Asko TL751 Electric Dryer
My Kenmore Elite Model# 110.63932101, is not heating. Will run but no heat. This happened once before and I thoroughly cleaned out all the vents, etc and it began to heat. The very next use, no heat again....
Take your vent pipe off at the dryer and see it it heats if it does
it is your outide vend stoped up. If it don't heat, check all fuses,
thermastats, cutoff fuse on heat box and the heating element.
Did you clean around the blower? Hope this helps. If you removed any wires are they connected correctly?
Dec 19, 2010 | Kenmore 64952 Electric Dryer
My Kenmore HE5 dryer will not run without blowing an internal fuse. The repairman replaced the fuse, and it blew again. The dryer heats up but will not turn it's heating element off until the fuse blows....
Has any one checked the exhaust vent,other than a bad thermostat the number one cause for the thermal fuse to open is a clogged or restricted exhaust vent flow, the entire vent system needs to be checked ( not just the hose from the unit to the wall) for proper air flow. Turn the unit on TIMED ,AIR DRY (NO HEAT) and go outside to the exhaust vent and check the air flow,if there is any question as to weather the air flow is sufishent get someone out to clean the exhaust vent ,it always a good idea to clean out every few years regardless to help prevent build up of lint witch could cause a fire......Hope this Helps Good Luck
Dec 14, 2010 | Kenmore HE5 Electric Dryer
Dryer wont heat up to dry. need to change fuse possibly, alrweady checked lint trap/hose/exhaust
these few things that you may want to do.
Roper Kenmore Dryers are almost the same therefore am sending this;
http://www.youtube.com/watch?v=lHkIK8oy1K4
How to Clean a Dryer Vent Video
http://www.youtube.com/watch?v=5Dj4im31lRY&feature=related
Why is so inportant to clean the lint?
http://www.youtube.com/watch?v=9kxbF31Oh4s&NR=1
If this wont solve the problem let me know.
It was helpful?
May 15, 2009 | Roper REX3614KW Electric Dryer
Kenmore 64942300 Electric Dryer runs, no heat
This may seem too simple of an answer based on your extensive troubleshooting thus far, but the most common reason for cold air running of any electric dryer is a broken heater coil. This is simply a coil of wire that is heated to warm the air in the fan duct. These often overheat and break if the vent duct is blocked, too long, or has odd bends that can restrict flow. Recommend replacing heater coil and use smooth wall vent pipe. Avoid coil type flexible duct.
Jul 03, 2017 | Kenmore 64942 Electric Dryer
Kenmore ultra fabric care dryer runs, but does not heat up
check the thermal fuse the operating therostat and the igniter is this a gas or electric dryer
Jan 12, 2008 | Kenmore 62602 Electric Dryer
My kenmore electric dryer wont heat mondel 110.86880100
I know you cleaned the lint filter so I won't even mention it:)
Is it possible that your vent hose runs along the floor (perhaps behind the dryer, or maybe even under a raised floor beneath your dryer - as mine used to) before going up and out to the outside vent? If so it could be that water has seeped in through the vent opening from outside and become trapped in the hose and is acting like a drain trap and blocking moist air from escaping which is causing the clothes not to dry.
This is what happened to mine once anyway. A cracked vent flap was all it took for the water to build up over time. Unfortunately mine ran under the floor and I had to actually tear up my floor in order to remove the water without having it flow all over my house. Fixed the drying problem though (and a new vent flap insured that it didn't happen again).
Jan 05, 2008 | Fisher and Paykel DEGX1 Electric Dryer
Kenmore 62602 Electric Dryer Logo
131 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
