Question about HP Photosmart C5180 All-In-One InkJet Printer
Jammed carriate on C5180 HP-all in one printer
I have a HP C5180 all in one printer. The carriage is stuck or jammed
  • ewil Dec 08, 2008
    I have a c5100 printer and it keep saying error carriage jam, open door, clear carriage jam, and then press ok to continue. I do that and it still say the same thing. Please help me.
    Puzzled
  • 679 Answers
SolutionStep one: Perform a power reset and connect the printer directly into the electrical outlet Remove all the paper loaded in the main input tray.Make sure that the product is turned off.
Disconnect the USB cable from the back of the product.
Disconnect the power cord from the product.
Disconnect the power cord from the electrical outlet and wait 10 seconds.
Reconnect the power cord directly into the electrical outlet and check for the following.
Make sure that the power cord used is the one provided with the product.
If a computer is connected to the product, make sure that the computer is connected to a grounded (three-prong) wall outlet.
Make sure that the power cord is firmly connected to both the product and the power supply.
Reconnect the power cord to the back of the product.
Press the power button ( ) to turn on the product.
Reconnect the USB cable to the back of the product.
If the issue is resolved, proceed to Step six: Print a self-test page.
If the issue continues, proceed to the next step.
for more information please go to below link>>
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458822&cc=us&lc=en&dlc=en
Thanks for using FixYa.
Posted on Feb 03, 2009
HP c5180 printer paper jam error
Please try these general troubleshooting steps for paper jam issue: Turn off your printer to allow the paper feed rollers to turn freely. Remove the rear access door and check the pressure rollers. Verify that they are clean and clean the rollers with a soft towel if needed. Check if there is any jammed paper in this section and remove the jammed paper from the rear access door opening. Make sure that there are no torn pieces of paper in the fuser area and duplexer slot. Check if the carriage moves freely. Use both your hands to remove the paper that is stuck in the roller in order to avoid tearing of the sheet. Discard any paper that is damaged, and then reload the paper into the paper tray. Unlock the print cartridge access door. Check if there is any packaging material or paper debris stuck on the small metal pressure rollers that ride on the main feed roller. Do not mix different types of paper. Load only one type of paper for a print job. Make sure that the paper meets the paper-handling specifications. Slide the paper-length adjuster against the end of the paper stack and do not overfill the input tray. Connect the power cord and turn on your printer. Try to print a sample and if the error persists, then try to reset the printer. Try to update the driver. If nothing works, then service the printer.
123 HP COM Setup Printer Quick Setup and Install Support
Mar 24, 2013 | HP Photosmart C5180 All-In-One InkJet...
Message telling me my carriage is jammed. I see nothing wrong when I open it. how do I unjam it?
hello, you might want to pull carriage from the right to the left, check to see if there is some paper in the right hand area, clear it out, then try again.
Sep 28, 2010 | HP Photosmart C5180 All-In-One InkJet...
Cannot clear CARRIAGE JAM on my c5180
There are a number of things that can cause a carriage jam. To prevent it from recurring, one should keep in mind a number of things. Always ensure that the paper tray is not overloaded as this might result in the paper being stuck inside. Also the paper being used should be as per the manufacturer's recommendations. Turn off the printer when removing bits of paper. If there is a broken gear, do not repair it yourself. Call an expert technician to mend it.
http://h30434.www3.hp.com/t5/Other-printing-questions/Paper-Jam-Error/m-p/305772#M20513
Carriage jam HP C5180 printer !
Visit this link to see the video on fixing carriage jam for HP C5180.
I hope this will solve your problem,
Good luck & have a nice day
Rating the solution is highly appreciated.
Aug 18, 2010 | HP Photosmart C5180 All-In-One InkJet...
Stylus CX9400 Photo Printer: paper jammed inside printer...
If paper is jammed, a Paper jam message will appear on the control panel display.
Follow these steps to clear the jam:
  1. Gently pull any jammed paper out of the output tray or sheet feeder.
  2. If the paper is stuck inside, turn off the Epson Stylus CX.
  3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
    alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
If paper jams inside the Automatic Document Feeder, clear the jam as follows:
  1. Open the Automatic Document Feeder cover and remove any jammed paper.
  2. If necessary, lift the document cover and remove any paper that has jammed inside.
  3. Press OK to clear any messages on the display screen.
May 18, 2010 | Epson Stylus CX9400 Photo Printer
HP j5780 printer sends "paper jam" message AFTER it prints one page. there is no apparent jam in all the places I have looked. I am in need of a repair manual (not an owners manual).
If you are getting a 'carriage jam' error as soon as you turn on your printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
Follow the steps for fix HP Printer Carriage Jam
Turn off the printer and open it to see where the paper is stuck.
Manually move the carriage toward the opposite side.
Check the paper path and remove any piece of paper or any other object that is stuck in the path.
Reconnect the power cord and turn on the printer.
http://www.fixya.com/support/t6088190-hp_7400_displays
May 12, 2010 | Office Equipment & Supplies
Won't print. Message says "carriage jam. Open door and clear carriage jam." There is no jammed paper or anything visible. Put door back on, still won't print. have turned on and off, and reinserted paper....
It is giving carriage jam not a paper jam the carriage is the part which carries cartridges on it. It seems your carriage is jam and can't move left and right so open the door and try to move your carriage with the help of rubber roller which moves your printer. Also clean the steel road on which the carriage moves just check at the corner of cartridge carriage if any paper bit is stuck or excessive paper dust has jammed it. If this does not solves your problem kindly comment back.
Jul 28, 2009 | HP Photosmart C5180 All-In-One InkJet...
Carriage cradle stuck on right side!
Carriage system is broken. Uneconomical to repair. Sorry
Dec 27, 2008 | HP Officejet 5610 All-In-One InkJet...
Paper jam in carriage
There is a latch at the back of your printer that opens so you can remove paper jams from the back. You can start there and then slowly peel away the rest of the paper that jammed...
Mar 10, 2008 | HP OfficeJet 7310 All-In-One InkJet...
HP Photosmart C5180 All-In-One InkJet Printer Logo
168 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
